Old 03-30-2011, 06:56 AM   #7321
I Think your screws were better.
Countersunks`s were a little bit to unstable and tourn around very fast, becaus of the little inbus.
cuberider09 is offline   Reply With Quote
Old 03-30-2011, 02:25 PM   #7322
Originally Posted by JoJiAuE View Post
Final test...
Seeking distributors...
Very nice...let us know when they are for sale!
Old 03-30-2011, 02:27 PM   #7323
Originally Posted by MikeXray View Post
I have used ca glue from time to time. I recently just switched to regular ball ends and ball studs up front only.
Which ones did you use?
Old 03-30-2011, 06:24 PM   #7324
MikeXray's Avatar
Trader Rating: 72 (100%+)
Losi because I had them around and I think the M3 threads were too big if I remember right.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-31-2011, 07:14 AM   #7325
mazmo's Avatar
Default Low grip track - Remove wings?
Race on a low grip concrete on rubber tyres 17.5 & mod.
I have the 'stiff' lipo chassis.
Thinking of removing the chassis wings to increase flex / improve grip.
Has anyone tried this? Would appreciate the feedback please.
Alan
Team TOP Australia www.topracing.net.au
TOP Photon EX 17.5 + TOP Photon EX 21.5 + TOP Rebel F1 21.5
ORCA | Tekin RS Pro | Tekin Gen 2 RPM | Ko Pro-Po | EPIC Trinity
mazmo is offline   Reply With Quote
Old 03-31-2011, 07:36 AM   #7326
Trader Rating: 17 (100%+)
Alan
I havent ran on concrete but you would think your going to want more flex. You need the old 6 cell chassis!!! Thats why I plan on running out doors this summer.
T.O.P Racing USA
"This T-bird will put a spell on you"
Mr.A Morris is offline   Reply With Quote
Old 03-31-2011, 08:36 AM   #7327
Alan
Simple answer = yes
CPD Racing
chris_dono is offline   Reply With Quote
Old 03-31-2011, 08:40 AM   #7328
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Can some one point me to a asphalt parking lot stock car set-up please?
And a Tekin Stock ESC setup would be most welcomed also....
THX in advance....
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 03-31-2011, 08:42 AM   #7329
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
Just remove the riser from the outer point of the wing. If u remove the entire wing with nothing to connect the car to the top deck it will bow the chassis and pop belts off
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 03-31-2011, 11:37 AM   #7330
Default pulley problem
hello, can you please help me with something asap. i am trying to change the stripped spur gear and i cant get it out. i have alloy 20T center pulley (not the plastic one). How do i get the red center pulley shaft out? its stuck. i hear you guys saying use the black shaft in the forum but before i can use that i need to take red one out. where do i get it? i really need to do it asap.
ok now if i decide to go with black shaft, what parts can i reuse? i see parts in use are:
1. 20t center pulley
2. pulley shaft (red or blac)
3. 5x10x4 bearings
4. screws
5. Mold L-07-1 spacers (i dont even know where i can get these. i dont see it anywhere)
6. spur gear
ok. so whats my next step. with above parts in hand and extra black pulley shaft. where can i see how to fit it ? (basically step 7 from manual). how does the step 7 in manual change with new black pulley shaft in picture? does new black pulley have have threads inside like red one to screw it up? does anything change because of my alloy 20T center pulley (not the plastic one). Please help.
neupane00 is offline   Reply With Quote
Old 03-31-2011, 12:56 PM   #7331
odpurple's Avatar
3. 5x10x4 bearings
4. screws
6. spur gear
To remove the bearings and disassemble the 20 tooth pulley you will have to grind the od of the red shaft, it has become enlarged from tightening the screws. Then you can build your new 20t assembly with the Alloy pulley on the steel (black) shaft. You can reuse the 5x10x4 bearings or replace with new. The steel shaft uses the same screws and the red one. The Mold L-07-1 plastic spacers come with the kit plastic 20t pulley, and not separately. Because of the tab on the steel shaft the spacing will be different, you can use one of the plastic spacers (Mold L-07-1) and sand the other one thin enough to space the shaft properly. Alternately, you can use one of the plastic spacers and some metal shims to space the pulley, or all metal shims, just make sure that in either case that there is a little free play so the bearings spin freely. For metal shims the TOP Racing # PA-100507 shim set will work great. Reuse the spur gear or replace
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 03-31-2011, 01:47 PM   #7332
Regarding more flex for low grip surfaces Steven Weiss left away the inner top deck screws as well as the middle screws of each bulkhead. This shoul give you the more flex you might want. If itīs not enaugh: you can change the single screw in the motor mount to a set screw only to fix the position to the chassis without making it stiffer cause of the screw. You can even grind of the bulkhead where you left away the middle screw so that the bulk doesnīt touch the chassis at this point. If that is not enought, too, change to the moderate lipo chassis
By the way: We have a facebook group around Steven Weiss: itīs called: "T.O.P Racing" Sadly I donīt know facebook well enough to give you a link to this group...
Lutz is offline   Reply With Quote
Old 03-31-2011, 01:58 PM   #7333
thank u michael.. that was quick response.
Old 03-31-2011, 05:03 PM   #7334
Luppi Stefano's Avatar
Yes, Steven use only 4 Screw on topdeck, more flex in corners.
But isn't for low grip surface...he uses this configuration with mid-high grip
is working hard to improve the car, and to bring in A-main in Europe and World Event.
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 03-31-2011, 06:13 PM   #7335
mazmo's Avatar
Originally Posted by chris_dono View Post
Simple answer = yes
Thank you all for the prompt and helpful responses.
Think I'll try removing screws from top deck first, easiest adjustment and makes sense.
Alan
SEO by vBSEO 3.5.0
