Old 03-22-2011, 10:14 AM   #7261
hanulec's Avatar
Trader Rating: 27 (100%+)
Originally Posted by jlfx car audio View Post
I have got a question on front gear. diff,spool,one-way.
Which works best on carpet; low traction,mid,med-high,high.
Track will be 50 x90 with 8" lanes and I'm sure moderately technical. This will be used in 17.5 no boost.
front spool w/ XRay ECS
rear ball diff
gear diffs, in my opinion, are made for modified motors (carpet) and asphalt racing.
you could also consider a ball diff up front with thick grease (losi brown) -- but frankly it is probably not worth even trying it.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 03-22-2011, 10:28 AM   #7262
Luppi Stefano's Avatar
Originally Posted by vabroom View Post
Are we talking about the servo setup?
no, I Talking about servo position
The idea came to me in December ... but I never used, because it was arrived CEFX.
this is Old Photo (1/12/2010)
T.O.P. Racing "Photon" 1/10 EP Touring Car-01-12-10_2057.jpg   T.O.P. Racing "Photon" 1/10 EP Touring Car-01-12-10_2058.jpg
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 03-22-2011, 01:13 PM   #7263
Ahhh, looks like you beat me to it Luppi. I just did this mod yesterday. Anxious to try it out. I like how it allows you the room to place a fan in front of the motor and also keep all electronics between the servo and motor.
CEFX Photon/Boss motor sports/Thunderpower motors/Savox/Airtronics
Tommy Kitchens
aka: STRAIGHT LINE
devilsquid is offline   Reply With Quote
Old 03-22-2011, 01:32 PM   #7264
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Can you get full steering lock with this mod? It looks to me like the ball cup or rod will hit the bulkhead and stop it from getting full throw.
Also what is really the point? Just for more space?
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 03-22-2011, 02:46 PM   #7265
with Bellcrank Rearward, Your Impression si Right!
with Medium or Forward no Problem!
steering is very fast, Maybe too much!
is just an idea, isn't guaranteed to function perfectly, in fact you have to use a lot of Exp on radio...
but Steven used this mod...I'm waiting for a response from him to find out why he used this configuration, from what I see in the picture must have a very aggressive steering.
I know something just write it
Lab F1-01
Old 03-23-2011, 01:19 AM   #7266
Default SHOCK LENGTH
Hi can some give me the definitive shock length to use please I've tried all sorts of lengths but I'm not happy with anything I've used.............
Tfracing......Muchmore Uk... Top Racing Uk........Tekin
tfracing is offline   Reply With Quote
Old 03-23-2011, 06:29 AM   #7267
Trader Rating: 17 (100%+)
From ball cup to ball cup mine are 60MM. Works for me.
T.O.P Racing USA
"This T-bird will put a spell on you"
Mr.A Morris is offline   Reply With Quote
Old 03-23-2011, 06:46 AM   #7268
pakk's Avatar
Trader Rating: 79 (100%+)
63mm
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 03-23-2011, 07:09 AM   #7269
When I build my shocks I measure them with the cap off to the top of the shock body and to the bottom of the eyelet. This distance is 49.5mm
Old 03-23-2011, 08:02 AM   #7270
thanks guys I will give it a go, a few variations there though...........
Old 03-23-2011, 10:27 AM   #7271
hanulec's Avatar
+1 -- doing the measurement with the cap off is key to getting the shocks perfectly equal
Old 03-23-2011, 10:58 AM   #7272
Mike Haynes's Avatar
...and proper diet is the key to code browns....get some
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 03-24-2011, 09:59 AM   #7273
this weekend, Roar Carpet National....
There will be updates to the photon?
Narrow Chassis for Example...ecc
Lab F1-01
Old 03-24-2011, 10:11 AM   #7274
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
I index my shock caps to insure that they r identical lengths every time I change fluid. And also index the spring adjuster so I know howmany turnes I make changing height
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 03-25-2011, 11:01 PM   #7275
EJ is running a narrow chassis and is doing really good
In mod! His car is looking great! He is also putting it down in 13.5 12th (6th)!!
Me on the other hand......... well still working on a good run for 17.5 and 5th in 21.5
And still trying to find a good FDR.
T.O.P Racing USA
