Old 03-21-2011, 10:30 AM   #7246
hanulec's Avatar
Trader Rating: 23 (100%+)
Originally Posted by Mr.A Morris View Post
Well the the practice for nats starts in 2 days. Im getting super excited. I will try to keep the thread updated with how the "T.O.P" guys are doing. TZ is a fast track that has high traction so its going to be tuff! For those that are coming I look forward to meeting you!
Originally Posted by MikeXray View Post
I'm not sure if larry or hanulec posted their snowbirds setup but since you are running the same tires there as snowbirds I would give it a try.
Good luck
I still think we are keeping that setup on the "down low"... unfortunately i don't know of any of us 'right coasters' showing up at this event. i would of been there if it wasn't for business trips to india.
Morris - if you've been running Larry's setup "correctly" (this often isn't done w/o a little smacking around -- at least in my case) then we might have a few hints to help when grip comes up, let us know.
and don't forget -- change those o-rings often and don't forget the green slime!
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 03-21-2011, 10:33 AM   #7247
hanulec's Avatar
Originally Posted by ezh_m5 View Post
hmm , interesting modification !
looks easy to do. im not sure what is really going to buy anyone though. i think he'd be better off with some Side Piece Mira Outdrives and some XRay ECS in that thing [shameless plug]
Old 03-21-2011, 03:06 PM   #7248
Trader Rating: 17 (100%+)
Thanks for the heads up. I tried running larrys set up and well. It didnt go so well the first time. My car feels pretty good right now. time will tell with lots of tuning.
T.O.P Racing USA
"This T-bird will put a spell on you"
Mr.A Morris is offline   Reply With Quote
Old 03-21-2011, 04:47 PM   #7249
Luppi Stefano's Avatar
I had thought two months ago .. but I've never used it, I try it this Sunday!
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 03-21-2011, 04:59 PM   #7250
vabroom's Avatar
Are we talking about the servo setup?
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is online now   Reply With Quote
Old 03-21-2011, 06:16 PM   #7251
Trader Rating: 20 (100%+)
Default In that picture
In the picture with NEW servo mount idea, why is the top deck not using the back two screws?
TLR 22
Desc410r
zleader_99 is offline   Reply With Quote
Old 03-21-2011, 06:42 PM   #7252
smilekt's Avatar
the top deck not using the back two screws maybe to give more flex chassis ..
Kuala Terengganu Rc Club Facebook
http://www.facebook.com/group.php?v=wall&gid=357083332025
smilekt is offline   Reply With Quote
Old 03-22-2011, 03:00 AM   #7253
Default Gear diff Oil
Appreciate some advice on gear diff oil. Currently running a Spec R Gear diff with 600 WT Much More Shock oil. The track is a relatively low grip concrete and fairly tight. car had no rear end grip on power. Would a thinner oil say 300 give better grip level. Running a MOD 5.5 turn motor. Any advice would be a great help. Thanks.
Novice MS is offline   Reply With Quote
Old 03-22-2011, 03:22 AM   #7254
GONZO-Racing's Avatar
Hi
1. NEW Servo mount= better Balancing the Car
2. Steven dont using the back screws (front and rear top deck), for more Flex in the Corner
Gruss Daniel "GONZO" Ghirlanda
GONZO-Racing is offline   Reply With Quote
Old 03-22-2011, 03:57 AM   #7255
Originally Posted by GONZO-Racing View Post
Hi
Where bye new servo mount, or its handmake?
Tamyia TRF 417
Team Associated RC8Be
Team Durango DEX410 2010spec
ezh_m5 is offline   Reply With Quote
Old 03-22-2011, 04:00 AM   #7256
Hi
Handmake
Old 03-22-2011, 04:40 AM   #7257
Bishop's Avatar
You can try it, the Photon wiki shows using as light as 350, but I think the lighter you go the more it will stress the diff, more so with mod, but I think the SpecR has shown to hold up well these days in general.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 03-22-2011, 08:32 AM   #7258
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
I have got a question on front gear. diff,spool,one-way.
Which works best on carpet; low traction,mid,med-high,high.
Track will be 50 x90 with 8" lanes and I'm sure moderately technical. This will be used in 17.5 no boost.
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 03-22-2011, 08:44 AM   #7259
Hi
Front Spool
Rear Yokomo Gear Diff witz Dot1 or Dot2
Old 03-22-2011, 10:00 AM   #7260
Try 2000cst oil in the spec-r diff, works well for mod
CPD Racing
chris_dono is offline   Reply With Quote
