Old 03-18-2011, 09:02 PM   #7231
rcfiend's Avatar
Trader Rating: 28 (100%+)
Does Top make a 2 & 6 castor block? If not is any one using the Xray blocks and if so what parts are needed to make it work.
rcfiend is offline   Reply With Quote
Old 03-18-2011, 09:59 PM   #7232
pakk's Avatar
Trader Rating: 79 (100%+)
Only a 4 degree atm. There's a parts list around here some where. I'm sure someone will chime in soon enough. You need the xray caster blocks and bushings if I remember right.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 03-19-2011, 04:23 AM   #7233
hanulec's Avatar
Trader Rating: 23 (100%+)
Check my photon wiki (in my sig). I don't have the 2 degree pn so use nexusracing to find it
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 03-19-2011, 09:07 AM   #7234
rcfiend's Avatar
Thanks for the info guys. Hanulec I'll check your wiki.
Old 03-19-2011, 03:07 PM   #7235
Travis S's Avatar
Trader Rating: 46 (100%+)
Anyone know if you can buy the u-pro red gear dif spacers or anything like them. I lost one and don't want to use 20 shims unless I have 2. I'm not sure on the width but I'm thinking it's 2mm or 2.5mm.
Travis S is offline   Reply With Quote
Old 03-19-2011, 04:15 PM   #7236
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
Ok guys . I'm about to pull my hair out. 8months ago or so . I did some training and acquired 2 used ("lightly I was told") u-pro gear difs. 3months ago I striped one . Pulled it apart and cleaned it out, a gear had broke a tooth. And attempted to put it back together with no luck so I chucked it.
So last night I pulled my gear diff apart to change fluid,it was dry and worked fine just not smooth as I would have liked. Put 10,000 at in it to experiment. As I realigned The 2 halves back together and tightened the screws the mesh got so tight I could not rotate a outlive. And after 20 attempts to reassemble and tighten down screws. I also tried reshiming it several times as well and still it locks up as the 2 halves seat . I'm a experienced racer and do hours of work to my car before each race but 2 hours one 1 gear diff? I can build 3 flawless ball difs in this time. What did I, or could be the problem?
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 03-19-2011, 04:59 PM   #7237
stiltskin's Avatar
Trader Rating: 101 (100%+)
Here's a couple of ideas. If you overfill the diff, it will lock. If the gears aren't lined up correctly, it will lock. Make sure that both outdrives spin freely before final assembly. As you tighten the four screws, begin to rotate it as it tightens down. Tighten all four screws a few turns and spin the diff. Tighten a few turns and spin the diff. Keep doing it until the screws are snug. Don't overtighten them or you'll crush the o-ring. I have also seen regular wear on the center pin that holds the planetary gears. Make sure that there are no burrs on the pin and check that the gears spin freely on the pin. Good luck. LMK how it goes.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 03-19-2011, 05:39 PM   #7238
Did all that. But a few turns between checking it ... yea I went as far as check-in it every 1/4 turn on each screw. Lol no burns either Im only filling one side of the diff up , o even tried putin it together dry a few times with no luck. Right now it feels great with 10,000 at in it. But I had to seal the case with nail polish from the outside or else it would run out of the crack.. wonder if the case was warped in the past.
Justin & Matt Lyons
a800s sanwa m12s
Old 03-19-2011, 05:45 PM   #7239
stiltskin's Avatar
Are you positive that the gears are seating properly on the outdrive? If the case won't seat/seal properly, it will allow it to flex and strip the gears out. I would also believe that without the cases properly seated, it would cause undo stress on the larger diff bearings since the diff is now wider than expected.
Tony Rumple
Old 03-19-2011, 05:45 PM   #7240
Travis S's Avatar
If you haven't done the tooth paste breakin method found in the photon wiki I would do that for sure. http://www.racerlog.com/wiki/T.O.P._Photon. I rebuilt 4 of these difs the other day and it took me a WHILE before I was happy. From my understanding of the guide not all the shims are put back in.
Old 03-19-2011, 11:12 PM   #7241
Bishop's Avatar
They are kind of a tricky thing to build, they will bind if the case goes back the wrong way, and nipping up the screws is trial and error, mine were a fine line between fluid level and being put together just right, though I have not tried the past break in yet.
I'm not actually 100% sure my rear is going to hold up to 10.5T with zero timing, after one meet with stock fill, I went to prep my Photon for the next meet and found a notch in the diff, pulled it down and some teeth were chipped, cleaned and rebuilt with 10k and it felt smooth enough to use again, but I have no idea if it was a fluke or if it will chip more teeth, though it still feels smooth enough now I have run that meet.
So possibly 17.5T of some/any sort is there real limit for being problem free, though I'll likely do a rebuild kit on the rear, put some real effort into the build, and see just how hard I can run it before it faults again.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 03-21-2011, 06:52 AM   #7242
Trader Rating: 17 (100%+)
Well the the practice for nats starts in 2 days. Im getting super excited. I will try to keep the thread updated with how the "T.O.P" guys are doing. TZ is a fast track that has high traction so its going to be tuff! For those that are coming I look forward to meeting you!
T.O.P Racing USA
"This T-bird will put a spell on you"
Mr.A Morris is offline   Reply With Quote
Old 03-21-2011, 07:05 AM   #7243
MikeXray's Avatar
Trader Rating: 72 (100%+)
I'm not sure if larry or hanulec posted their snowbirds setup but since you are running the same tires there as snowbirds I would give it a try.
Good luck
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-21-2011, 07:07 AM   #7244
RC MARKET's Avatar
μ.PRO Released
Spool Outdrive Steel (For TP-0003 Photon Spool Set)
T.O.P. Racing "Photon" 1/10 EP Touring Car-mp-tp-0004.jpg
RC MARKET is offline   Reply With Quote
Old 03-21-2011, 08:28 AM   #7245
hmm , interesting modification !
Tamyia TRF 417
Team Associated RC8Be
Team Durango DEX410 2010spec
ezh_m5 is offline   Reply With Quote
