Old 03-12-2011, 06:50 AM   #7216
sprintcarracer's Avatar
Trader Rating: 23 (100%+)
Last night during racing I started off with low roll center blocks on the front and lows on the far rear and mediums on the front of the rear arms. All the cams in the coll center blocks were in the lowest setting. In the 1st heat the car had a sever push through out the turns which made the car slower than the others down the straights. For the 2nd heat I put high roll center blocks on the front cams in the low position and for the rear mediums on the far back lows on the front of the arms. The cams on the far back were in the high position and on the front of the arms they were also in the high position. This made the car look lose as hell but still felt like it had some under steer but it also had crazzy corner speed. I'm a little confused I always thought that the lower the roll center was the more grip was generated and made for an easyer car to drive. It was hard to drive with the low roll center blocks being used and fast and easy to drive with the high blocks. If someone can explains this to me it may help me in the future with car setups because I just dicided to throw the kitchen sink at the car after the 1st heat it was so bad. Thanks for any help, as may have helped in the past.
sprintcarracer is offline   Reply With Quote
Old 03-12-2011, 07:12 AM   #7217
MikeXray's Avatar
Trader Rating: 72 (100%+)
You have to break down the corner into entry, mid and exit, all settings affect different parts of the turn. The only time I know low low roll centers work is on very low bite tracks, everyone runs mid or high roll centers.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-12-2011, 10:13 AM   #7218
The track I race at runs off road trucks. We get half as many on road cars as there are trucks so there is no groove on the track. By the end of the night you can just start to see a groove. I just want to better under stand why the car likes high roll center blocks. Most of the guys at the track come to me for setup help since I'm one of the fastest cars every week and it would be nice to tell them how some if this stuff works.
Old 03-12-2011, 11:22 AM   #7219
bkspeedo's Avatar
If you don't have these books already I would get them as they explain all the various setup features on a Touring car.
XXX Main book - can be bought from most online retailers.
XRAY set-up book - Go to XRAY's website to download, here's the link.
http://www.teamxray.com/teamxray/products/proddwnld.php?prod_id=3606&kategoria=3606&catName=
This guide is geared more towards off-road but many concepts can be applied to TC. Plus a few concepts are explained in way more detail then the above mentioned books.
http://home.scarlet.be/~be067749/58/
Each is very good and explains various setup features slightly different.
I've reread each of these books dozens of times to understand each setup feature and still have to refer back every once in a while.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ ProtoForm ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 03-12-2011, 11:27 PM   #7220
Travis S's Avatar
Trader Rating: 46 (100%+)
Do people use any of the optional "Wings" for carpet rubber racing? I am about to place an order for some parts and was wondering if I should bother ordering the medium or hard wings or not.
Travis S is offline   Reply With Quote
Old 03-12-2011, 11:38 PM   #7221
Pro10noob's Avatar
Start with the basic(mentioned in the manual) setup and work your way from there.
I found out that this setup is a good reference for indoor and outdoor.
Both are mentioned in the manual.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 03-13-2011, 12:21 AM   #7222
OVA
OVA's Avatar
I wouldn't ..those option first came out, it was great for the 6cell batteries chassis ,Now the lipo kit chassis are stiffer...so you may not needs them...
OVA is offline   Reply With Quote
Old 03-13-2011, 08:15 AM   #7223
Medium all round the car even better with lipo chassis than 6 cell
CPD Racing
chris_dono is offline   Reply With Quote
Old 03-13-2011, 08:13 PM   #7224
TeamWTF's Avatar
My LHS is the importer for HB/HPI in Australia so i thought hmm... lets try....
Success! I do intend on updating to the LiPo chassis but since hearing about the new narrow chassis coming out I thought i would wait.
Also saw a few pages back a neat bit of machining.... The motor mount that moved the motor toward the center of the car! I want one... I will look back and PM the person.... If i can find it...
T.O.P. Racing "Photon" 1/10 EP Touring Car-photon-tcx-brace.jpg
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 03-15-2011, 10:57 AM   #7225
Hello,
It was on Site 267 I think.
If you get an answer from him, please could you post it here.
Regards
Pierre
cuberider09 is offline   Reply With Quote
Old 03-15-2011, 01:28 PM   #7226
vabroom's Avatar
I think this is the one you're thinking of:
http://www.rctech.net/forum/8613339-post6992.html
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is online now   Reply With Quote
Old 03-15-2011, 07:20 PM   #7227
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
Any body have a top one-way Ur willing to sell off? Will be placing a order tomorrow night with amain for a stock spec one if noone chimes in between now and then. Just thought I would ask
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 03-15-2011, 08:22 PM   #7228
Default Mico Pro Spool Outdrive - Steel for Photon
I see this in the website
http://www.top-racing.jp/Eng+JP/Cate.../u-Pro_JP.html
T.O.P. Racing "Photon" 1/10 EP Touring Car-mp-tp-0004.jpg
mr.ng is offline   Reply With Quote
Old 03-15-2011, 11:55 PM   #7229
TeamWTF's Avatar
Thats it
After further reading it would seem it need the chassis to go with it.
Now that I have this retainer I'm once again quite happy with the functionality of the standard chassis.
Taping was getting annoying...
Old 03-16-2011, 11:00 AM   #7230
vabroom's Avatar
Thats it
I asked him about using just the motor mount and he stated that the standard Photon chassis needs to be cut 3mm where the motor mounts and use his upper deck.
SEO by vBSEO 3.5.0
