Old 06-15-2009, 03:29 AM   #706
nocif13's Avatar
Send a message via MSN to nocif13
Originally Posted by RC MARKET View Post
Xenon
max 64p120T
ok
i used only 48DP
RW48DP 75P is good for stock 13.5?
thank
olivier
teamspec/petitrc.com/TEAM WAVE/T.O.P racing/CBRacing.fr/rcmanufactory/Alien POWER/Team Terribles
nocif13 is offline   Reply With Quote
Old 06-15-2009, 07:40 PM   #707
TRF4evr's Avatar
Default suspension swapping
To start the new photon looks awesome from the pics that I have seen ,and I can't wait to get one...I've got a question in regards to the suspension which i was told that you can use the old scythe arms as they are same geometry as the new one on the photon and also I have seen pics at the euro race and looks like the one of the racer was using on the photon was the scythe suspension front and back..any diffs or advantages with the old scythe suspension? can u interchange with the front c hubs and steering knuckle? can anyone ouththere who has the photon car give me some info regarding the suspension geometry between the photon and scythe.
TRF - HUDY - Much more - Ride
Proamp Lipo - Speedpassion
www.feralbatteries.com
TRF4evr is offline   Reply With Quote
Old 06-15-2009, 07:51 PM   #708
Patriiick's Avatar
the new arms were not ready yet at that time, thats s why they were running the old hpi-style arms.
Patriiick is offline   Reply With Quote
Old 06-15-2009, 08:17 PM   #709
Hi Albert
The suspension geometry seems to be approx the same, the euro car that was run at the ETS was received very shortly before the race, it seems that to be on the safe side they ran the old suspension, and sway bars as they ran on the old car.
I saw some of the suspension pieces in action on a scythe car, the parts are very beefy, and should survive an impact better, and they also allow you to change the shock mount position, the downside from the look and feel of them is that i think the old plastic HPI arms would be better on most of our low traction tracks, unless of course TOP comes out with some soft arms for the Photon.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 06-15-2009, 09:22 PM   #710
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Scythe? WTFIT!?
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 06-15-2009, 09:54 PM   #711
Originally Posted by John St.Amant View Post
Scythe? WTFIT!?
The original TOP car
Old 06-15-2009, 10:21 PM   #712
Scythe? WTFIT!?
Old 06-16-2009, 07:09 AM   #713
Josh Cyrul's Avatar
Beserco - From testing over the years I don't believe that softer (more flexi) suspension arms are good. In temperature changes their flex is effected more than just a very stiff/ridgid arm which makes it impossible to tune the car. Softer arms may give you a feeling that the car is easier to drive (it numbs the responce from the track) but never have I found it to be faster. Now, I know I don't quite race on the low grip tracks like in Europe but I look at two of the best rubber TC's out there (Tamiya and HB) and their suspension arms are quite stiff so while some will use this for tuning, I think it only hurts the performance/consistancy of the car especially in changing track/weather conditions.
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 06-16-2009, 07:23 AM   #714
I tried the high traction arms on my Scythe but i wasn't faster. the car drove easier but is was slower with it.
I looks like that the car slows down in the corners.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 06-16-2009, 07:34 AM   #715
Well I was fortunate enough to have held a Photon but I would love to see a few more pics of it. I went looking for some but all I could find is a set-up sheet.
Is the release date still the 22nd? Perhaps by July I can afford it.
Old 06-16-2009, 08:20 AM   #716
artwork's Avatar
Trader Rating: 56 (100%+)
Try this...
http://topracingusa.com/photon.htm
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 06-16-2009, 11:03 AM   #717
RC MARKET's Avatar
Originally Posted by nocif13 View Post
ok
i used only 48DP
thank
olivier
isn't said 48P75T is good or bad !
You need see your track & layout find which teeth fit for you ,
& keep check motor , ESC temp , will know !
RC MARKET is offline   Reply With Quote
Old 06-16-2009, 11:59 AM   #718
One obscure pic of Joshes car....
Better than none I suppose.
Old 06-16-2009, 12:15 PM   #719
syndr0me's Avatar
Trader Rating: 32 (100%+)
T.O.P. Racing "Photon" 1/10 EP Touring Car
syndr0me is offline   Reply With Quote
Old 06-16-2009, 12:57 PM   #720
Fabricio's Avatar
Send a message via MSN to Fabricio Send a message via Skype™ to Fabricio
Default correct date
I was looking at the thread and seems to be confusing to me, when the car is really going to be available?
ARC R10 - ORCA - SANWA - EPIC
Fabricio is offline   Reply With Quote
