Old 02-23-2011, 05:48 AM   #7171
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Only use the spec r drive shafts if you want to be disappointed with breakage.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 02-23-2011, 05:49 AM   #7172
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
No u need xray c hubs and bushings as well and thats it
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 02-23-2011, 05:51 AM   #7173
I have been runnimg them all winter with. Only 1 to breat and i took some hard hits
Justin & Matt Lyons
a800s sanwa m12s
Old 02-23-2011, 06:59 AM   #7174
Im already using the xray hubs .. Are they like the xray shafts?
L.Fairtrace . Wat problems have u had with them?
stcc ssb tires, ko ,gm motors, demon products lipos, hobbywing speedo
mwoods is offline   Reply With Quote
Old 02-23-2011, 07:59 AM   #7175
Yes same as xray ecs but with.smaller bulb at spool end to fit the top steel cups. U can use x ray's also but u have to either get diff cups or grind down the "bulb" to fit the.cups like i did when i broke a bone in a bad wreck and didnt have a spare. Still running it now with no issues
Justin & Matt Lyons
a800s sanwa m12s
Old 02-23-2011, 08:01 AM   #7176
Me and all the people at our track had nothing but problems with the spec r ones breaking, bending or generally failing.
Now I use xray ecs's and sidepiece spool cups. Failproof.
Old 02-23-2011, 08:06 AM   #7177
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
I agreed.... I have two Spec R and they are alittle weak material made part..
OVA is offline   Reply With Quote
Old 02-23-2011, 10:21 AM   #7178
Originally Posted by JETT View Post
Does anybody know how to run a yokomo gear diff in the front of a photon. I've shimmed for clearance on the bottom and using 46mm steel bones in the front with yokomo blades. My problem is binding when the wheels are turned. And they don't have to be at full throw either??. Anyone?
Nevermind. Fixed it.
Originally Posted by hanulec View Post
you used 44.5mm front shafts, right?
I checked and they are 46 mm shafts. I went from some aluminum ones that were worn to some new steel ones. Put the new ones in and binding occured when turning. So I shaved the "bulb" on both ends and problem no more.
JETT is offline   Reply With Quote
Old 02-23-2011, 10:53 AM   #7179
Think i will keep the top drive shafts for now dont realy spend
40 and they break ....
Old 02-28-2011, 09:33 AM   #7180
Trader Rating: 17 (100%+)
I got to run a high traction track last weekend (TZII), the 6.2mm (front) hex with a the front end at +2mm worked great. It put the car right at 190mm! It helped it from traction rolling with super quick transitioning and lots of corner speed!
Mr.A Morris is offline   Reply With Quote
Old 02-28-2011, 10:42 AM   #7181
OVA
OVA's Avatar
Great news...How did you do? could you share your set up ?
Old 02-28-2011, 10:59 AM   #7182
It was my first time out with a new a new car and I finished building it at the track LOL, but all and all I did ok.. I switched motors right before A2 and gained about .4sec... so I would have qualified A LOT better if I would have done that sooner . Then changed the set up right before A3 and it would have been great but I could have used more camber, as it was wanting to push.
But in general
Short arms in front
Long in back
2 hole pistons in front with 3 holes in the back (1.2)
Long camber links all the way around
6.2 Hex front Standard in rear..
The standard sway bar in front. none rear. (thats what I changed beofore A3)
Ride height was a little over 5 front and 5.5 rear
Hope that helps OVA see you in a coulpe weeks at the final NWIC race!
Old 02-28-2011, 12:33 PM   #7183
OVA
OVA's Avatar
It was my first time out with a new a new car and I finished building it at the track LOL but all and all I did ok.. I switched motors right before A2 and gained about .4sec... so I would have qualed A LOT better if I would have done that sooner . Then changed the set up right before A3 and it would have been great but I could have used more camber it was wanting to push.
But in general
Short arms in front
Long in back
Hope that helps OVA see in a coulpe weeks at the final NWIC race!
New car?? did you get the lipo version?
I just might run my Photon next NWIC instead the 12th
Old 03-05-2011, 08:13 AM   #7184
rcfiend's Avatar
Trader Rating: 29 (100%+)
Hey where on the car do you guys adjust the droop. Do you adjust it at the arms? I tried doing it under the hub in the rear but there is no real edge to it.
rcfiend is offline   Reply With Quote
Old 03-05-2011, 09:00 AM   #7185
Luppi Stefano's Avatar
I adjust Droop under the arms
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
