Old 02-15-2011, 08:36 AM   #7111
hi, has anyone tryed the litemodz front and rear cvs on the photon , r they any good ?
thanks
stcc ssb tires, ko ,gm motors, demon products lipos, hobbywing speedo
mwoods is offline   Reply With Quote
Old 02-16-2011, 06:05 AM   #7112
RC MARKET's Avatar
TOP Released Ti-Rod Wrench for Photon
T.O.P. Racing "Photon" 1/10 EP Touring Car-top-new-parts.jpg   T.O.P. Racing "Photon" 1/10 EP Touring Car-top-pt-tw01rd.jpg
RC MARKET is offline   Reply With Quote
Old 02-16-2011, 06:53 PM   #7113
old-man's Avatar
Not sure if this was mentioned earlier before but has anyone noticed that the diff halves supplied in the kit are hard coated and the one purchased as replacement parts are not hard coated?
I have 2 diff halves that was purchased as replacement parts did not last as long as the kit supplied ones combined even with regular replacement of the C blades.
The other thing I noticed is the the color is also different. The kit ones are slightly darker in color probably caused by hard coating and the replacement parts are similar color with all other allow parts of the car.
I am interested in getting the ones supplied in the kit. Does anyone know of a part number specific to it?
old-man is offline   Reply With Quote
Old 02-16-2011, 09:49 PM   #7114
Bishop's Avatar
There would only be one part number, but you could have been in a situation where the kit you bought was newer stock than the spare parts?.
TOP have made running changes to parts, like with the spur pulleys I got last week, which now come pre-glued and fit my kawada spurs with no mods.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 02-17-2011, 02:10 AM   #7115
What grease is reccomended for the ball diff...for the diff and the thrust bearings?
Old 02-17-2011, 03:02 AM   #7116
Trader Rating: 54 (100%+)
AE Diff lube works good, as well as NifTech.
Jamison R is offline   Reply With Quote
Old 02-17-2011, 08:19 AM   #7117
Mr. Bubby's Avatar
Yup, AE diff lube for the diff and AE BLACK GREASE for the thrust
Do not use the diff lube for thrust, bad idea.
Schumacher MI6 (SMC Powered) Touring Car
Xray T4 '16 (SMC Powered) USGT
Xray XB2 2WD (TSR Powered) Stock Buggy
No 1/12 scale till they run with rubber tires!!!
Mr. Bubby is offline   Reply With Quote
Old 02-17-2011, 08:21 AM   #7118
Trader Rating: 17 (100%+)
I use AE black on the thrust and AE clear on the other.. butter every time!
Mr.A Morris is offline   Reply With Quote
Old 02-17-2011, 08:27 AM   #7119
Mr. Bubby's Avatar
thanks
Got a complete set a while ago, front and rear. The rear ones are great, hardly any backlash at all when used with the top blades.
But the front ones are a different story, the coupling CVS is a little too big for the C-Hub opening and would hit the sides of the C-hub when turning sharp. I ended up dremeling out a larger opening for the C-hub. Also there is some rubber tubing that comes with them and you need to cut it very precisely to make up for the slop in the diff outdrive. I must've not cut precisely enough cuz I didn't even make it through one race, tagged a corner and the front ones blew up into millions of pieces.60 bucks down the drain.
But I've still got the rear ones on and they are great. Many many races and still very very minimal backlash.
Old 02-17-2011, 09:48 AM   #7120
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
What blew up the plastic pipe on the pins or the bone?
I have the spec r front ecs and love them i installed xray pins and C hubs and all is well. I have had some realy hard sweeper hits in spec class and still turning
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 02-17-2011, 11:25 AM   #7121
Cool thanks guys...that's what I used...AE diff grease and AE black grease. The diff is very smooth but it felt like it had a little drag in it so I wanted to make sure the black grease wasn't too thick.
Old 02-17-2011, 07:36 PM   #7122
stiltskin's Avatar
Trader Rating: 99 (100%+)
It will free up after run-in.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 02-17-2011, 07:51 PM   #7123
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
i use shumacher diff grease and AE black grease....the diff grease last longer for me if compare with other diff grease...
Give the best while u can !
kschu is offline   Reply With Quote
Old 02-17-2011, 08:12 PM   #7124
locked's Avatar
I haven't tried them all, but ever since I started using Schumacher diff grease, I haven't felt the need to try any other ones. That stuff works great.
I'm using TRF thrust bearing grease right now. There might be better grease, but it's what I've got and seems to work well enough. Is AE better for thrust bearing grease?
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 02-17-2011, 08:38 PM   #7125
pakk's Avatar
Trader Rating: 79 (100%+)
That's horrible. All the performance gains are suppose to be from the front shafts. At least that is what I thought. Have you contacted them on this?
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
SEO by vBSEO 3.5.0
