Old 02-13-2011, 09:12 PM   #7096
pakk's Avatar
Trader Rating: 79 (100%+)
Anyone using the LW arms? Did it make a noticeable difference? How much lighter are they?
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 02-13-2011, 10:10 PM   #7097
My car had the LW arms on the car when I got it from my friend...the car itself ran great today but I was down on power due to turbo fade. I didn't have the other arms on the car to compare with though...but the car did handle very well.
Old 02-14-2011, 12:29 AM   #7098
RC MARKET's Avatar
LW 8g
RC MARKET is offline   Reply With Quote
Old 02-14-2011, 12:45 AM   #7099
Bishop's Avatar
Does anyone have any base setups or tips for setup that may work with foam on outdoor asphalt, with no traction compounds either.
I ran a few times late last year with the basic rubber setup on foam, and it was fairly good, but I can't help feeling it could be a lot better, thinking possibly thicker bars and maybe less toe to pick up speed on the foams, cause they seem to wash some off.
There is the foam setup in the manual, but that seems geared to high grip carpet with sauced tyres, likely too stiff on more bumpy outdoor.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 02-14-2011, 05:21 AM   #7100
Default saber
Hi did any of u oks driven the saber and how is it
Are ther gone be a thread for SABER
diffscrew is offline   Reply With Quote
Old 02-14-2011, 06:09 AM   #7101
Sal Amato's Avatar
R/C Tech Charter Subscriber
Trader Rating: 26 (100%+)
put them on you will not be disappointed
360 RC SPEEDWAY 2.0
AWESOMATIX USA-SANWA--BSR--TEAM SCREAM --SWEEP RACING USA--TQ WIRE--ROCHE USA--LRP
Sal Amato is offline   Reply With Quote
Old 02-14-2011, 07:40 AM   #7102
do they give more grip?
stcc ssb tires, ko ,gm motors, demon products lipos, hobbywing speedo
mwoods is offline   Reply With Quote
Old 02-14-2011, 07:44 AM   #7103
Kwikvdub's Avatar
Trader Rating: 89 (100%+)
Send a message via AIM to Kwikvdub
Thumbs up
Thanks Sal!!
Alex Valdes
TQRacing / 360 v2 RC Raceway
Kwikvdub is offline   Reply With Quote
Old 02-14-2011, 09:20 AM   #7104
pakk's Avatar
Originally Posted by RC MARKET View Post
LW 8g
8g each? 8g lighter each? 8g lighter total? more info my friend.
Yes sir. Where can I find the?
*Photon* *SC10 4x4*
RCRD
Old 02-14-2011, 09:42 AM   #7105
Sal Amato's Avatar
Try T.O.P racing USA they were out of stock but they should be getting a shipment sometime this week
360 RC SPEEDWAY 2.0
Old 02-14-2011, 12:24 PM   #7106
RC MARKET's Avatar
total 8g
http://rcmarket.com.hk/index.php?cPa...sort=2a&page=3
Old 02-14-2011, 12:31 PM   #7107
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
They are not 8 grams lighter each.
They are about 3.5 grams lighter each.
I personally didn't notice a huge handling difference switching arms but some people seem to.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 02-14-2011, 05:53 PM   #7108
drcw197's Avatar
ive tried both and i think there is just a slight bit more traction with the regular arms ,if ur going to lose some grams try to take a little weight of the top of the car some things i did were ,dremel and shave the top of the shock towers a little,cut body post low,and things like that will make a more noticeable difference but overall its not really going to be much that is noticed but thats just me
Albert Woodard / Boomer
DRCW / TLR RACING 22 / TOP PHOTON / tekin / sorex / parogon / integy /spektrum
drcw197 is offline   Reply With Quote
Old 02-14-2011, 07:25 PM   #7109
pakk's Avatar
I should hopefully have a set this weekend. I'll post what I find.
I'm only replacing mine because I found that one of my arms have a bit of play in it. So I figured I might as well try these new arms out.
*Photon* *SC10 4x4*
RCRD
Old 02-15-2011, 03:44 AM   #7110
hanulec's Avatar
with the upcoming (or current... not really sure) ROAR touring car weight of 1380 -- and the IFMAR standard of 1350 I think the light weight arms so be apart of anyones "program". it is the easiest way to save weight....
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
