Old 02-09-2011, 07:01 AM   #7051
MikeXray's Avatar
Trader Rating: 72 (100%+)
Originally Posted by ChadB. View Post
Any suggestions on a good gear diff? Have leaking problems been fixed? I have been wanting to try one, but it seems people have been having problems in the past.
I use the spec-r, I had bad luck with the u-pro's myself. Up front with 500k oil it leaks very little, and I think that is usually just excess oil working its way out, they seem to work best when you can cram as much oil as it will fit.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 02-09-2011, 07:08 AM   #7052
Kwikvdub's Avatar
Trader Rating: 89 (100%+)
Send a message via AIM to Kwikvdub
Thumbs up
Originally Posted by Sal Amato View Post
....just spend the extra cash and get the xray ones with the side piece mira outdrives and u will be trouble free!
Thanks Sal!!
Alex Valdes
TQRacing / 360 V2 RC Raceway
Kwikvdub is offline   Reply With Quote
Old 02-09-2011, 11:23 AM   #7053
Sal Amato's Avatar
R/C Tech Charter Subscriber
Trader Rating: 26 (100%+)
Originally Posted by kschu View Post
u can change the 1.5mm pin to xray pin....then u wont have any prob,,,
I beg to differ I broke a bone and didnt even hit anything
360 RC SPEEDWAY 2.0
AWESOMATIX USA-SANWA--BSR--TEAM SCREAM --SWEEP RACING USA--TQ WIRE--ROCHE USA--LRP
Sal Amato is offline   Reply With Quote
Old 02-09-2011, 12:52 PM   #7054
-WHEELMAN-'s Avatar
Trader Rating: 263 (98%+)
Originally Posted by hanulec View Post
the most leak-free gear diff is the Yokomo BD-5 gear diff by Yokomo.
another option for chatter-free front drive line is to run XRay ECS with (shameless plug) Side Piece Racing Mira Outdrives - www.sidepieceracing.com
What length ecs shafts? Any link would be helpful.
BRETT T. RICHARDS = SUPPORT YOUR TROOPS, LOCAL TRACKS AND HOBBY SHOPS OR THEY COULD ALL BE GONE ONE DAY!
-WHEELMAN- is offline   Reply With Quote
Old 02-09-2011, 12:55 PM   #7055
Sal Amato's Avatar
the mira outdrives will accommodate either the 52 or 50 mm xray ecs I would recommend the 50 mm .. For the spec r fans you can also use the t3 ecs with the mira outdrives... which allows for the xray blade to be used
360 RC SPEEDWAY 2.0
Old 02-09-2011, 02:50 PM   #7056
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
I have to say i have been running the ecs shafts by spec-r and havnt had any issues. I am running the xray pins. And 6deg blocks. I did break one ecs bone but it was a hard hit . And i have beat the crap out of my car oover the past 4 races. New layouts at 3 diff tracks. Lol im very pleased with them
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 02-09-2011, 05:51 PM   #7057
ChadB.'s Avatar
Trader Rating: 16 (100%+)
Thanks for your help guys. I want to be able try the gear diff, where can I find all of them? I know where to get the Spec- R gear diff, but not the others. Would the Yokomo gear diff be a direct fit?
Chad Burdick
*Mugen Seiki*Flashpoint Racing Products*9th Annual Timezone Grand Prix July 13th-16th 2017*Unique Air Design*TimezoneRacing*RoseCityScaleRacers* Daves RC Track
ChadB. is offline   Reply With Quote
Old 02-09-2011, 06:18 PM   #7058
smoke81's Avatar
Send a message via AIM to smoke81 Send a message via Yahoo to smoke81
You can get the uPro diff from TOPusa. The yokomo diff will have to come from japan most likely. Although driftspeed.com is showing them, but have been out of stock for awhile...
It will need some shimming, and you will need either bd5 blades, or tc5 blades.
Dustin Layne
smoke81 is offline   Reply With Quote
Old 02-10-2011, 07:07 AM   #7059
sprintcarracer's Avatar
Trader Rating: 23 (100%+)
I just put a gear diff in the rear of my car, I run 17.5 non boosted. I filled the diff with Associated 2,000cst gear lube. I know the cst rated oil is diffrent from the others that go by weight, so my question would be is this oil to light should I run something heavier? I also want to run a gear diff up front also what is a good starting point. I've seen some post that they run as high as 200,000wt.
sprintcarracer is offline   Reply With Quote
Old 02-10-2011, 07:10 AM   #7060
MikeXray's Avatar
Depends on which diff you are running, the spec-r has 4 spider gears and you use lighter oil than the upro with 2 spider gears. Up front 500k is the way to go.
Old 02-10-2011, 07:39 AM   #7061
Guess I forgot to put in my post that I'm using a u-pro
Old 02-10-2011, 09:30 AM   #7062
Bishop's Avatar
My gear diffs and repair parts showed up today, the U-Pro really is a marvel in how tiny and light it is, 'very' notchy out of the packet though, how many runs do they usually take to smooth out if you just fit and go?.
I may just use mine as is for a few runs, I'm curious to see how they work out of the pack, before I go putting the 10k and 100k I also bought to tune mine with, likely if they still feel rough I'll toothpaste them also.
If you can't tell from the pic, club is trying with 10.5T with Zero timing right now, with added novelty of foams for a few reason on outdoor ashpult, could be interesting finding setups to suit it.
One thing I though worth mentioning, with the repair parts I got, new spur pulley came with end caps pre-glued, and they fit my spur with no mods, updated bits maybe?, likewise new rear belt seems to have a different surface on it.
T.O.P. Racing "Photon" 1/10 EP Touring Car-geardiffs.jpg
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 02-10-2011, 11:15 AM   #7063
Trader Rating: 54 (100%+)
Which 500k oil are you using?
Jamison R is offline   Reply With Quote
Old 02-10-2011, 11:23 AM   #7064
MikeXray's Avatar
Traxxas is the easiest to find, that's what I have now.
Old 02-10-2011, 12:07 PM   #7065
Trader Rating: 17 (100%+)
Well nats at TZ is coming up pretty quick are any of you guys heading there?
Mr.A Morris is offline   Reply With Quote
SEO by vBSEO 3.5.0
