Old 02-08-2011, 06:00 PM   #7036
This might be a stupid question but what pully fits the upro gear diff? Do I have to hack upp the ball diff pully or is there one that fits straight on?
chovden is offline   Reply With Quote
Old 02-08-2011, 06:02 PM   #7037
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
Top one-way pulley bolts right on.
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 02-08-2011, 06:07 PM   #7038
ChadB.'s Avatar
Trader Rating: 21 (100%+)
Originally Posted by Mr.A Morris View Post
Chad, let me know if you want to switch cars for reginals this weekend hahaha... Dont for get if you run the 21.5 class you need to add a tank worth of weight!!!!
See you there! I made some changes to my car... It should be faster
Hey there Aaron, you can keep that car of yours.lol I'm going to be running the 17.5 non-boosted class. How about you? See you up there.
Originally Posted by stiltskin View Post
Here's a couple of things to look at. For the chatter, check to see if the dogbone has worn on the pin. If so, it will cause the tire to jump when you turn the wheel on throttle. For the axle pin covers, I always put a thin film of black grease around the axle before I slide them on. Makes it alot easier to get them back off of the axle when its time to rebuild. HTH.
Tony, the axles on there now are newer and aren't pitted very badly. I will have to try the grease on the pin holders I am getting. Hopefully this will help.
Originally Posted by MikeXray View Post
A gear diff up front also fixes the chatter issue since both axles aren't fighting each other.
Any suggestions on a good gear diff? Have leaking problems been fixed? I have been wanting to try one, but it seems people have been having problems in the past.
Chad Burdick
*Mugen Seiki*Flashpoint Racing Products*9th Annual Timezone Grand Prix July 13th-16th 2017*Unique Air Design*TimezoneRacing*RoseCityScaleRacers* Daves RC Track
ChadB. is offline   Reply With Quote
Old 02-08-2011, 06:11 PM   #7039
Thanks, I have to order that one then..
Old 02-08-2011, 06:20 PM   #7040
hanulec's Avatar
Trader Rating: 27 (100%+)
the most leak-free gear diff is the Yokomo BD-5 gear diff by Yokomo.
another option for chatter-free front drive line is to run XRay ECS with (shameless plug) Side Piece Racing Mira Outdrives - www.sidepieceracing.com
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 02-08-2011, 11:25 PM   #7041
hanzo3's Avatar
Trader Rating: 55 (100%+)
My c joint keeps falling off. Does that mean the dogbone or outdrive is bad?
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 02-08-2011, 11:28 PM   #7042
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
i agreed....but some spec-r gdiff also never leak...maybe 1 over 10pcs...
i would suggest use spec-r double joint or Litemodz...
Give the best while u can !
kschu is offline   Reply With Quote
Old 02-09-2011, 12:09 AM   #7043
Sal Amato's Avatar
R/C Tech Charter Subscriber
Trader Rating: 26 (100%+)
The Spec r lcds ecs or double joints are not worth the money they break way to easy ....I have gone through 3 sets ....just spend the extra cash and get the xray ones with the side piece mira outdrives and u will be trouble free!
360 RC SPEEDWAY 2.0
AWESOMATIX USA-SANWA--BSR--TEAM SCREAM --SWEEP RACING USA--TQ WIRE--ROCHE USA--LRP
Sal Amato is offline   Reply With Quote
Old 02-09-2011, 01:25 AM   #7044
Travis S's Avatar
Trader Rating: 46 (100%+)
Has anyone ever flipped the belts on a 6 cell chassis? It looks like it could be done if the gear dif holes on the chassis were dremmeled out on the other side or just a big whole is made between the mounts. I cant justify spending 100 on a lipo chassis when a new narrow chassis is coming out in a few months. Any reason not to do this?
Unless someone is looking to trade their lipo chassis for 2 6 cell ones.
Travis S is offline   Reply With Quote
Old 02-09-2011, 01:50 AM   #7045
kschu's Avatar
u can change the 1.5mm pin to xray pin....then u wont have any prob,,,
Old 02-09-2011, 03:15 AM   #7046
mazmo's Avatar
Default x-ray 6 deg c-hub conversion
Guys,
Am gonna try x-ray 6 deg c hubs & steering knuckles.... do I need the x-ray c hub collars as well ... or will the top collars fit?
Thanks Alan
Team TOP Australia www.topracing.net.au
TOP Photon EX 17.5 + TOP Photon EX 21.5 + TOP Rebel F1 21.5
ORCA | Tekin RS Pro | Tekin Gen 2 RPM | Ko Pro-Po | EPIC Trinity
mazmo is offline   Reply With Quote
Old 02-09-2011, 03:28 AM   #7047
hanulec's Avatar
Originally Posted by mazmo View Post
Guys,
Thanks Alan
You need the metal bushings/collars too. Check my wiki ...
Old 02-09-2011, 03:31 AM   #7048
hanulec's Avatar
I think a lot of will disagree with you still. Changing the pin helps but then the bones bend or worse the latest design breaks more than bends.
This is the whole reason I made the Side Piece Racing Mira Outdrives -- to eliminate failure on the race track.
Old 02-09-2011, 04:22 AM   #7049
mazmo's Avatar
Guys,
Thanks Alan
Thanks for the speedy reply hanulec
Old 02-09-2011, 05:11 AM   #7050
kschu's Avatar
ok dude...
