Old 02-01-2011, 10:37 AM   #6961
New car with NIP parts for sale
TOP Photon lipo edt with parts
Reason for sale is sticking to 12 scale
Blink281 is offline   Reply With Quote
Old 02-01-2011, 10:47 AM   #6962
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
I would like to take a minute and thank EJ Evans from TOP for not only loaning me a car to drive for Snowbirds but treating me like a member of the team. The car was dialed, I wish the driver was
Thanks EJ!
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,KoPropUSA,JConcepts,Avid RC,MIP,SikLidz,ImagineItGraphx, FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 02-01-2011, 11:54 AM   #6963
pakk's Avatar
Trader Rating: 79 (100%+)
Originally Posted by DaveW View Post
Are your shock caps vented? If you move the shaft fast enough you can hear the air escaping through the hole...
This is with the cap off. Here's what I do.
I fill the shock with oil. Then move the shaft/piston up and down to get all the air out from under the piston. I normally let it sit over night. Then I do it again to make sure there is no air trapped under the piston. If I move it up and down fast enough I get bubbles which seem to be coming in through the bottome seal because I can't imagine that much air being trapped under there.
My question is, is this normal? Because I can't see my shocks ever moving that fast in a race situation. It also takes a few pumps before I get bubbles to come up.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 02-01-2011, 12:03 PM   #6964
Buckaroo's Avatar
Use a shock vacuum pump. You would be amazed at how much air can be trapped under the piston and in all the stuff under there. This will make your shocks SO much more consistent.
Click here for a link to Nexus Racing
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 02-01-2011, 03:47 PM   #6965
hanulec's Avatar
Trader Rating: 25 (100%+)
Thanks EJ!
Randy - it was great seeing you race onroad. I hope you do it again some time soon...
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 02-01-2011, 06:12 PM   #6966
rcfiend's Avatar
Trader Rating: 29 (100%+)
Does anyone use the alloy battery mount?
rcfiend is offline   Reply With Quote
Old 02-01-2011, 06:45 PM   #6967
locked's Avatar
I use them. I know a few guys that use them. I like using the velcro strap.
Most of the really fast guys I know that drive photons just use battery tape. Some use a chassis where the alloy mounts wouldn't be an option, but others don't for some other reason. Maybe price or perhaps it gives a slightly higher center of gravity, I don't really know.
the penny stuck to my chassis is there because at the last big race I was under weight by a gram and it was the quickest way to make weight before my qualifier started.
T.O.P. Racing "Photon" 1/10 EP Touring Car-photon-battery-mount.jpg
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 02-01-2011, 06:48 PM   #6968
pakk's Avatar
I don't doubt that. I'm sure that is a better method. But if what you are saying is true, eventually these air bubbles will stop showing up. They don't ever seem to go away.
*Photon* *SC10 4x4*
RCRD
Old 02-01-2011, 06:53 PM   #6969
rcfiend's Avatar
Most of the really fast guys I know that drive photons just use battery tape. Some use a chassis where the allow mounts wouldn't be an option, but others don't for some other reason. Maybe price or perhaps it gives a slightly higher center of gravity, I don't really know.
Thanks. I just bought one and didn't realize you needed two. I'm not sur I understood your post, can you use tape with it or is it just for the velco straps?
Old 02-01-2011, 07:02 PM   #6970
locked's Avatar
You can use battery tape with the mounts.
I meant most of the really fast guys I've seen just use the plastic tray or some custom CF hooks and then fiber battery tape under the chassis and over the battery in the typical fashion.
Dave Locke
Old 02-01-2011, 07:46 PM   #6971
rcfiend's Avatar
Gotch. One more question, what's a good FD for 13.5?
Old 02-01-2011, 08:09 PM   #6972
locked's Avatar
that depends on a lot of things like track size, ESC, boosted or 0 timing, motor, etc.
To give you a rough idea at least, last summer I ran boosted 13.5 on a big parking lot track. I was using a tekin rs pro and a boss (speed passion v3.) motor. Quite a bit of timing advance. I played with my FDR between about 6.8 and 8. I ended up liking it best around 7.1.
You definitely need to include details for a question like this and I'm sure I'm not the best person to answer it. I'm constantly learning new things in this hobby.
Dave Locke
Old 02-01-2011, 08:14 PM   #6973
rcfiend's Avatar
Locked thx for the info. Sorry about the vague question. The last time I raced I ran 6 cell batts and brushed motor. I'm relearning the hobby and the lipo Brushless thing is all new to me.
I'm not sure what esc I'll be running, but for now I have a lrp SPX and a 13.5 motor that I will be running to shake the dust off
Old 02-02-2011, 08:46 PM   #6974
I would like to thank the entire TOP Team whom attended the birds for their hard work and dedication. Special thanks goes out to EJ and Fairtrace for putting up with me while getting me up to speed with the lack of "NO" Sleep and wrenching on my car. I sincerly appreciate the team work!
Over the week of the snowbirds I have gained not only respect for the design and quality of the TOP Photon Sedan, but also for the good team that goes with this competitive rc car.
The car worked great all week, I am just a little rusty at the wheel. I would recomend this car to not only the serious racer, but the local weekend racers as well. The quality and precision is second to none. I am looking forward to the next race...
Mike Dumas is offline   Reply With Quote
Old 02-02-2011, 10:56 PM   #6975
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Great performance at the Birds Mike! Was very impressed that you did so well running so many classes.
BigDogRacing is offline   Reply With Quote
