Old 01-26-2011, 10:37 AM   #6901
1shnot's Avatar
Any more news on narrow chassis?
-Fast cats
-eXpress motorsports
-T.O.P
-Airtronics
1shnot is offline   Reply With Quote
Old 01-26-2011, 11:01 AM   #6902
OVA
OVA's Avatar
Trader Rating: 77 (100%+)
Here is my mod chassis...it is 90mm wide
T.O.P. Racing "Photon" 1/10 EP Touring Car-narrow-photon-chassis-001.jpg   T.O.P. Racing "Photon" 1/10 EP Touring Car-narrow-photon-chassis-2-001.jpg
OVA is offline   Reply With Quote
Old 01-26-2011, 11:21 AM   #6903
1shnot's Avatar
is that homemade?
-Fast cats
-T.O.P
-Airtronics
Old 01-26-2011, 11:25 AM   #6904
TAMAK's Avatar
Trader Rating: 28 (100%+)
What would be the main benefit for this type of mod? I have a similar chassis, but not that narrow..
TAMAK is offline   Reply With Quote
Old 01-26-2011, 11:30 AM   #6905
OVA
OVA's Avatar
Originally Posted by 1shnot View Post
is that homemade?
yep
Old 01-26-2011, 11:37 AM   #6906
OVA
OVA's Avatar
well ,during the race , I've noticed the bottom of my stock chassis is rubbing on the carpet...So If I could narrow chassis it will solve my problem...
If you read pages back ,there was a person names martin C. who did his done and it works great...lot of new high end TC are come with narrow chassis are standard...
btw it is not the cexf
I also have bell crank custom made as well .
Old 01-26-2011, 11:45 AM   #6907
EJ had a handful made, a few of us locals bought some. Just switched over will try out this weekend. EJ seems to like it. I believe he's at the snowbirds and running the narrow chassis
thomasf is offline   Reply With Quote
Old 01-26-2011, 12:00 PM   #6908
1shnot's Avatar
Does he have anymore?
-Fast cats
-T.O.P
-Airtronics
Old 01-26-2011, 01:33 PM   #6909
TAMAK's Avatar
Do you grind the bumps off the bottom of your batteries?
Old 01-26-2011, 03:11 PM   #6910
locked's Avatar
I know they do exist, but I have never seen a battery yet that has any bumps on the bottom. I'm sure if you only had those kinds of batteries, then yes, you would need to cut the bumps off to use a chassis that doesn't have the cutouts for the bumps, like those prototype narrow ones.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 01-26-2011, 05:20 PM   #6911
hanulec's Avatar
Trader Rating: 27 (100%+)
To everyone running the Side Piece Racing Mira Outdrives and XRay 50mm ECS. We have found out that adding a 1mm shim behind the spool cups helps prevent any plastic blade breakage. If you do have a blade break though these super tough outdrives just take it w/o wear .... but don't forget to change the blade for the next run!
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 01-26-2011, 05:34 PM   #6912
macdude's Avatar
Any advantage of running the shorter 50mm as oppose to the 52mm? That would eliminate the need for the shim.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 01-26-2011, 05:45 PM   #6913
Buckaroo's Avatar
The Venom batteries in the dark green transparent cases have bumps. 8 of 'em!
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 01-26-2011, 06:15 PM   #6914
If you look back a couPle of pages Pakk had posted a pic of the narrow chassis
Old 01-26-2011, 06:24 PM   #6915
pakk's Avatar
Trader Rating: 79 (100%+)
More photos....
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
