Old 06-12-2009, 07:57 AM   #676
CanyonCarverR1's Avatar
Originally Posted by Josh Cyrul View Post
Craig - Usually front arm sweep will increase steering responce getting the car into the corner better - Sometimes it will make the car "twitchy" or hard to drive on the straights if you have too much. Usually though, once the car has set into the corner, I think it actually makes the car understeer a little more than straight pins. I've never been a big fan of this so I usually run only a small amount where EJ runs more than I do (always) but complains at times about his car going straight...lol...
Are you talking about putting spacers on the front/front arm mounts so that they are further away from the centerline than the front/rear arm mounts?
CanyonCarverR1 is offline   Reply With Quote
Old 06-12-2009, 09:12 AM   #677
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Originally Posted by mikky32 View Post
Yep a "W" is a "W" but as 21 drivers were in an other final and the 13,5T driver is faster. What is a "W" than!!
My car was very nerves last race. I drive TOP Scythe full optioned.
Hat the front to blocks 1 and 0. think that i will put the 1,5 and 0 back.
After a few laps my rear tires got more grip and than it was better but not as good as it was before with the 1,5 and the 0. I got more steering but this was to much.
A rose is a rose is a rose...
Do I have to spell it out for you ?
And I still want a Photon. Or hasn't anyone figured that out yet?
Seems to me I make a statement about one thing that is not positive reinforcement and all the (Fill in the blank) holes think they gotta slam me.
Well for one this is nothing more than opinion quota,,,
Take it as you will and get off my "neck".
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 06-12-2009, 09:40 AM   #678
Front rake is like adding more washers to the front pivot ball and making the hinge pins not parallel. Like adding toe out to the lower control arms but not to the steering blocks. Pretty neat trick.
Old 06-12-2009, 10:02 AM   #679
Can't wait till i got my Photon.
It looks like my Scythe is slowing down but it isn't.
I'm now the one that must make shore that the races on our club go well and that has cost me 2 qualifications and 1 final. The first race of the season was my own mistake. The other 2 because i'm arranging everything to keep every body happy and make shore we have race leaders and a technical commission.
All the questions and people complaining about there disqualification is disastrous
for my own race.
I'm thinking to stop racing in the super stock at our club and keep it ad the M-chassis class next year and start racing in the national championship again.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 06-12-2009, 12:33 PM   #680
RC MARKET's Avatar
next week will release wait moment
RC MARKET is offline   Reply With Quote
Old 06-12-2009, 10:43 PM   #681
syndr0me's Avatar
Trader Rating: 32 (100%+)
EJ,
What are you using to hold the fans on your motor in this picture? Where can I get one?
http://edseb.smugmug.com/gallery/853...420_VPgKM-A-LB
syndr0me is offline   Reply With Quote
Old 06-12-2009, 11:05 PM   #682
Trader Rating: 28 (100%+)
Team Tamale made a fan mount just like that.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 06-13-2009, 06:05 AM   #683
That is one of my fan mounts. I haven't made any of those in a while. They are kind of a PTA. I have had contact with someone who is looking into getting these made cheaper than I can. These worked great. On brushed motors we saw a 20-40 degree temp drop. One of the rubber tire racers at our local carpet track used this last weekend on his 13.5 and saw about a 40 degree cooler temp using just 1 fan.
teamtamale is offline   Reply With Quote
Old 06-13-2009, 08:16 AM   #684
syndr0me's Avatar
Ah, cool, I'm really interested in trying a fan, but most solutions seem to add quite a bit of weight. With all the fancy new ESC's throwing around a ton of timing, and switching to a spool, it seems like getting motors hot is a lot more common.
Old 06-13-2009, 06:34 PM   #685
lore's Avatar
Send a message via MSN to lore Send a message via Skype™ to lore
Default Photon - Rubber Set Up
EJ,
Any tips for a rubber set up in mod and 10.5 class?
My Photon is on the way!!!!
Thanks in advance.
Lorenzo
RB6 / RT6 / ZX6 / SC6
AE12 R5.1 / F104 Exotek / Tamiya Mini 500 Abarth
Orion R10 Pro all the way
lore is offline   Reply With Quote
Old 06-13-2009, 08:53 PM   #686
Send a message via AIM to goop
hey guys i have a modifiable setup sheet that you can put x's in the boxs then print out a filled out setup sheet. it also has a spot were you can put your spur pinion tire diameter and it will automatically calculate rollout and final drive ratio. it will also calculate toe just by putting the shims you use to space out the arms. the only problem is that the file is too large so if you want this file please email me at goopdienes69@hotmail.com i will try to get this to you as fast as possible. i would like to thank a good friend Alex Cortez he helped me do this.
Hurricane Motorsports
Team Trinity
TOP Racing - Gravity Rc - Contact tires - KO Propo - Competition Electronics
goop is offline   Reply With Quote
Old 06-13-2009, 09:19 PM   #687
i put it in a zipped folder hopefully this will work
File Type: zip Photon Setup Sheet.zip (480 Bytes, 83 views)
Team Trinity
Old 06-13-2009, 09:49 PM   #688
artwork's Avatar
Trader Rating: 56 (100%+)
Does not seem to work for me...says the file is invalid.
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 06-13-2009, 10:56 PM   #689
adamge's Avatar
File size of 480 bytes is way too small to be legit. Something didn't work with the zipping process.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 06-14-2009, 02:22 AM   #690
bender's Avatar
Goop,
Looks like you've zipped a shortcut to the file, rather than the actual file itself.
If you want, send me a pm and I'll give you my email address, then i can upload it to my site. It will save me the hassle of making one up myself
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
