Old 01-23-2011, 05:35 PM   #6871
stiltskin's Avatar
Trader Rating: 102 (100%+)
Originally Posted by gruman28 View Post
Thanks for the info on the gear diffs, Should I get 1 or 2? Some guys at our track run them up front, some run them in the rear, and others run them in both.
I will be running on high traction super smooth asphalt in 17.5 spec. I was going to get 2 and just experiment.
Thanks for any suggestions.
Running two gear diffs is dependent on track conditions. When grip was low on the asphalt, I liked the dual gear diffs with 100k front and 10k rear. When the grip came up, the spool worked better with improved lap times. Inside on the carpet now and I'm running 80k in the front gear diff and a ball diff in the rear. The car is very good, so I haven't tried to play with the rear gear diff in awhile.
Originally Posted by haywood View Post
Could you tell me what parts I would need to convert to Xray 6 degree blocks while using a front ball diff? Thank you!
If you're using the stock Photon drivetrain, you will need the Xray c-hubs, Xray bushings and a 1mm shim on top of the steering knuckle.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 01-23-2011, 05:39 PM   #6872
hanulec's Avatar
Trader Rating: 27 (100%+)
Thanks Tony ... I have the necessary part numbers posted here - http://racerlog.com/wiki/T.O.P._Photon#Front_C-Hubs_2
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 01-23-2011, 05:53 PM   #6873
locked's Avatar
Originally Posted by zleader_99 View Post
Hey Locked I could not go because of work. However I watched blurry footage via the seaway mall web cam! Are you running gear diffs? I was out at Lou's on saturday for practice. Wow I need a lot more. Take a few months off and I was kissing the board all morning. I had my 17.5 and 21.5 out.
Glad you had a good time at the Nats.
Hows the new chassis running? How many classes did you run? I could have loaned you my 13.5 boss.
Planned to run 2 classes. Had a few issues Friday during practice and decided to just race my new car in 17.5. It was a tight, technical track.
I love my new car.
I think my old car is going to become a VTA/"GT2" car now.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 01-23-2011, 05:57 PM   #6874
hanulec's Avatar
Yesterday we had a lot of successful runs with the new Side Piece Racing Mira Outdrives at Horsham. Myself, Larry, The GOAT, and Ralph Morella all ran them in our Photons. There was a mixture of 50mm and 52mm ECS shafts all successfully being run.
I know a lot of you are having trouble finding the XRay ECS shafts as they appear to be out of stock at RCAmerica. I've had some luck getting them from Hong Kong-- and rcmarket has them at VERY good prices, althought they are out of stock now.
Old 01-23-2011, 06:43 PM   #6875
pakk's Avatar
Trader Rating: 79 (100%+)
Originally Posted by Luppi Stefano View Post
more photo to this chassis?
home made?
Originally Posted by OVA View Post
look good
I'm about ready to do mine as well....If TOP Racing don't come out asap...
I didn't make it. I pit next to EJ and took it when he was racing.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 01-23-2011, 09:57 PM   #6876
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
It look like 3mm chassis....looking from the motor deep clearance
OVA is offline   Reply With Quote
Old 01-24-2011, 06:25 AM   #6877
pakk's Avatar
It's 2.5mm.
*Photon* *SC10 4x4*
RCRD
Old 01-24-2011, 06:40 AM   #6878
MikeXray's Avatar
Trader Rating: 73 (100%+)
I like running front gear diff rear ball diff on carpet, I am using the spec-r BD5 ones though with ofna diff locker, its almost spool like, but turns in better. For me I find that its easier to correct your line than with a spool, but I will counter that by saying that I have driven cars with spools that handle better than mine does. (Hanulec's with his side peice racing gear) I don't find a need for ECS driveshafts with a front diff too.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 01-24-2011, 09:02 AM   #6879
Pro10noob's Avatar
Is it a prototype from TOP??
Home made?
Aftermarket?
Questions,questions,questions
regards Roy
It's 2.5mm.
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 01-24-2011, 09:37 AM   #6880
locked's Avatar
I'm pretty sure it's a TOP prototype narrow chassis.
I could be wrong though.
Dave Locke
Old 01-24-2011, 09:44 AM   #6881
Bishop's Avatar
I needed some repair parts for the starting season here, so I ordered two of the upro diffs, I forget what oil weight comes in them though?, I figured I'd buy some oil with the order, so got some 10000 and 100000, I figure an ok start point for a medium bumpy low traction fast open asphalt track?.
Hoping from what I have read they will hold up well, it's going to be either of 10.5 no timing, 17.5 open or 17.5 fixed, no mod for me.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 01-24-2011, 10:01 AM   #6882
TAMAK's Avatar
Trader Rating: 28 (100%+)
So far so good for me, I have noticed I break a bunch of steering knuckles. Could be driver error though....
TAMAK is offline   Reply With Quote
Old 01-24-2011, 10:57 AM   #6883
Smile
Canadian Nationals - Welland Ontario - Martin Crisp TQ's with his TOP TC and wins both 17.5 and 13.5 Canadian National Titles
Congratulations.
Number 49 Lou's Speedway Canada, Honda House www.hondahouse.com
ElliotCanada is offline   Reply With Quote
Old 01-24-2011, 11:36 AM   #6884
Luppi Stefano's Avatar
congratulation Martin!
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 01-24-2011, 11:52 AM   #6885
DaveW's Avatar
You arent the only one... just drop in some Xray steering knuckles, and youll be much happier.
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
