Old 01-10-2011, 06:11 AM   #6796
MikeXray's Avatar
Trader Rating: 73 (100%+)
Originally Posted by hanzo3 View Post
My universal c is loose in the aluminum outdrive. Does this mean the outdrive is bent? This is on the RR of the car. How would this affect performance?
check for wear on the ball and the outdrive, if the outdrive has a notch in it, it could cause some weird handling issues.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 01-10-2011, 11:03 AM   #6797
Luppi Stefano's Avatar
my setup Carpet Indoor, Medium/High Grip
Uploaded with ImageShack.us
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 01-10-2011, 12:22 PM   #6798
Trader Rating: 17 (100%+)
http://www.trovamodellismo.com/media...a%20Libera.pdf
Cant get it to open
Mr.A Morris is offline   Reply With Quote
Old 01-10-2011, 12:29 PM   #6799
Originally Posted by Mr.A Morris View Post
Cant get it to open
Edit
sorry
Lab F1-01
Old 01-10-2011, 02:29 PM   #6800
hanzo3's Avatar
Trader Rating: 55 (100%+)
Is http://www.topracingusa.com/store/ not working for anyone else?
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 01-10-2011, 02:41 PM   #6801
locked's Avatar
Yeah. Looks like they might have been hacked. There is a questionable Java installer popping up. Probably one of those fake antivirus things again.
OD, whoever handles the site, you should probably get them to change the password for ftp access to your host. Make it something complex (Upper and lower case letters + numbers + symbols and no words or names)
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 01-10-2011, 08:09 PM   #6802
odpurple's Avatar
Thanks for the heads up guys, and the good advice Dave. It appears that we have indeed been hacked. We are new to this and not prepared to handle it in short order, it's not the sort of thing we need when we are as busy as it is right now. We'll try to get things working and keep everyone posted. In the meantime you can always send us an email to order or visit one of our online dealers, like A Main Hobbies or Speedtech RC. Of course your LHS can also order for you from us as well.
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 01-10-2011, 08:10 PM   #6803
Big Features's Avatar
Servo mounting looks a tad odd. Any hints? I've seen a bunch of guys Shoe-goo them in instead of using the mounting hardware and 50 shims.
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 01-10-2011, 08:32 PM   #6804
hanzo3's Avatar
Speedtech does not carry any photon parts.
Chris TRF419 TA05V2
Old 01-10-2011, 08:40 PM   #6805
hanulec's Avatar
Trader Rating: 27 (100%+)
What servo are you using Kling? A few of us have been running within a hole for the outside wing, and drilling an additional mounting hole. This works for the JR 8800S or Spektrum 6040 servo (along w/ a little dremel work on the servo case).
http://racerlog.com/wiki/T.O.P._Photon#Servo_Mounting
I can pull together some measurements tomorrow if people are interested...
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 01-10-2011, 09:14 PM   #6806
OVA
OVA's Avatar
Trader Rating: 77 (100%+)
does any ones know if TOP Racing working on narrow chassis for Photon in the furture?
OVA is offline   Reply With Quote
Old 01-10-2011, 09:32 PM   #6807
odpurple's Avatar
As of today they do.
Yes.
Old 01-10-2011, 09:35 PM   #6808
TeamWTF's Avatar
Whats the point of a narrower chassis if the motor is in the same position... and the batteries are still moved far out to compensate?
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 01-10-2011, 09:41 PM   #6809
OVA
OVA's Avatar
Well so far my bottom outside edge of the chassis is rubbing on the carpet even the ride height is 5mm front 5.5 rear...
Old 01-10-2011, 09:42 PM   #6810
smoke81's Avatar
Send a message via AIM to smoke81 Send a message via Yahoo to smoke81
The weight location isn't the point to the narrower chassis. The point to narrowing the chassis is to allow the car to roll more without touching the racing surface.
That being said..... I would assume one of the next steps would be moving the motor in as well.
Dustin Layne
smoke81 is offline   Reply With Quote
