Old 01-05-2011, 08:05 AM   #6766
DaveW's Avatar
Great info all around on the gear diffs!!
I have valve lapping compound in the garage... ill try that on mine. Has anyone messed with any synthetic axle greases used for 1:1 cars?
I have some 10k... i guess ill assemble it with that first, and will just have to wheel it for results.
Also... i have a ball diff apart and some Rulon pads that i am going to mod for a front slipper spool. It worked really well in my last car... so i figured it was worth a shot.
Anyone know where i can find 8 degree caster blocks? I would like that much caster with the front arms flat. My current spool setup would feel perfect in and out of a corner with that much caster...
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 01-05-2011, 08:07 AM   #6767
Luppi Stefano's Avatar
Originally Posted by Lutz View Post
Why donīt you use the original spool?
Spool with steel cup original work very well, but after 25/30 Run
Stell cup damaged plastic spool...
For this reason, I prefer to use litemodz Spool...
for The Rear diff, Use Yokomo Geardiff...
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 01-05-2011, 08:58 AM   #6768
Yes the steel outdrives damaged the plastic spool of my team mate, too.
I didnīt have this problem, but last I disassembled my car to fit a gear diff instead of the spool I noticed, that the steeloutdrives where a little loose in the spool. So I figure it would have damaged the spool the next packs, but tighten the screw would solve the problem and the spool would still last longer.
Lutz is offline   Reply With Quote
Old 01-05-2011, 03:23 PM   #6769
Trader Rating: 26 (100%+)
Originally Posted by E.J. Evans View Post
The uPro diffs are meant for 17.5 speed or slower.
I have tested the yokomo diff and it works well, even for modified.
Here is the part number:
Part# BD-500GS
BD-500GS - BD5 Gear Diff
They are a little hard to get right now.
Are these BD5 gear diffs a direct fit
eddie10 is offline   Reply With Quote
Old 01-05-2011, 04:20 PM   #6770
-WHEELMAN-'s Avatar
Trader Rating: 266 (98%+)
I have not done it myself but Ed told thereis shimming involved. No biggie!
BRETT T. RICHARDS = SUPPORT YOUR TROOPS, LOCAL TRACKS AND HOBBY SHOPS OR THEY COULD ALL BE GONE ONE DAY!
-WHEELMAN- is offline   Reply With Quote
Old 01-06-2011, 06:50 AM   #6771
Just some shimming and youīll need to sand down the blades a bit to make them thinner. Thats all and needīs maybe 5min
Old 01-06-2011, 07:17 AM   #6772
old-man's Avatar
I had the same problem over the weekend too.
old-man is offline   Reply With Quote
Old 01-06-2011, 02:06 PM   #6773
Steven Weiss use Standard Spool with plastic CUP, modified class indoor
no problem for you....
Lab F1-01
Old 01-06-2011, 05:44 PM   #6774
macdude's Avatar
Just tried my micro pro diff. I just removed 2 shims from the axil side of the planetary gears. This seems to free the thing up quite a bit. Since I was looking to break the thing in a little more I just left the stock silicon grease in and it was great. I really like the way it feels out of the corners.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 01-07-2011, 01:03 AM   #6775
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
i have been glueing my cups in my spool for about a year now, man i have had some bad wrecks also with no issues with them breakin thru or loosining up lol. i been using speaker glue from digital designs, its a thick black glue thats not brittle but hard as can be. i will prep the plastic by scoring the inside of the spool a bit with a exacto then sand the spool a bit to rough it up put a few drops in the spool and set it in and allow it to come up into the spool a bit then tighten it up with the screw and its ready to rock.
i have a spool in my tc that has 1.3mm shimms between the spool and cups glued in and about 2weeks ago i snaped a spool cup (steel!) in 2!! but glue held but it did trash the hole thing . did save the other cup using a dremel. lol
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 01-07-2011, 06:42 AM   #6776
Default lipo chassis ??
has anyone played with different chassis and top decks ??
ive just brought a super stiff lipo chassis kit ( with the bling bits ! ) , this car is only used on high grip carpet with sorex 32 tyres ... , when i normaly use the std 6cell chassis with a mod'd foam top deck ..
but i was wondering when it comes to changing all the bits over , whats the best top deck worth fitting ...
as i said its got the std 6cell chassis fitted at the moment and its set up pretty much how i like it !!
althou my other photon has a std lipo chassis fitted and that goes pretty well on carpet , even thou its mainly used for tarmac on sorex 32's
please help, i have an important race meeting coming up next weekend , and i dont wanna go backwards ...
shaun207 is offline   Reply With Quote
Old 01-07-2011, 11:15 AM   #6777
Difference in weight between bd5 gear diff and photon stock diff is big?
Tamyia TRF 417
Team Associated RC8Be
Team Durango DEX410 2010spec
ezh_m5 is offline   Reply With Quote
Old 01-07-2011, 03:11 PM   #6778
I've played around with the 6-cell vs Lipo chassis with each of the top decks. There's not a lot to choose between them, but I personally find the lipo chassis carries more corner speed while the 6-cell one is more pointy into and out of the corners
The wings are the key though !!!
CPD Racing
chris_dono is offline   Reply With Quote
Old 01-07-2011, 04:40 PM   #6779
hi chris
can you remember what you decided on in the end , chassis / top deck / std wings ???
cheers for your help
Old 01-08-2011, 02:33 AM   #6780
hi chris
Lipo chassis, medium top deck, medium wings all round is a good starting point on 32's
CPD Racing
