Old 12-29-2010, 05:32 AM   #6691
gruman28's Avatar
Trader Rating: 16 (100%+)
Just finished building my Photon and everything went great. Everything fit together nicely until i got to putting in the motor.
I am using the lipo chassis and a tekin redline motor. The motor wont fit correcly between the motor guard. With the motor guard, it tweaks the motor on a weird angle. I took the motor guard off and all is fine. Anyone else have this issue?
I attached the motor guard to the bottom of the chassis and all is good. Just worried that is will scrape.
THANKS
Chris
gruman28 is offline   Reply With Quote
Old 12-29-2010, 05:46 AM   #6692
hanulec's Avatar
Trader Rating: 25 (100%+)
THANKS
Chris
Take the guard off the bottom - that wont work. Dremel the piece until it fits or get another motor. Trinity Duo, speed passion or novak motors fit.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-29-2010, 06:11 AM   #6693
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I've had a tekin motor in my car before. You have to get a different spur gear so it puts the motor towards the center of the hole.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 12-29-2010, 08:13 AM   #6694
1shnot's Avatar
For those who helped with my leaky shocks..thanx!!!
I still have the first gen photon, and really like it and I do not want to upgrade to another brand sake of changing... so question is, If i get the lipo chassis does the width of the chassis change? it appears to be the same, but I would like to have a narrower chassis if possible ( I did try "search" button LOL)
Thanx again guys
-Fast cats
-eXpress motorsports
-T.O.P
-Airtronics
1shnot is offline   Reply With Quote
Old 12-29-2010, 08:52 AM   #6695
macdude's Avatar
Thanx again guys
My understanding is that there is a narrow version of the chassis in the works. And you are correct the new lipo chassis is not any narrower than the six cell version. The real difference is there are some extra hole in the chassis so that you can move the lipo further to the right side, and it also gives you the ability to flip the diffs and run the front belt to the right side. The standard chassis does not offer this ability as there holes under the diffs in the front and rear are smaller.
Hope this answers your question.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 12-29-2010, 08:06 PM   #6696
Trader Rating: 20 (100%+)
Default layshaft spacer
Does anyone one know the size or pn for the layshaft spacer? I recently got a new to me 2nd photon. The gear set has a lot of slop and noticed its the wrong spacer. I dont have calipers to check the other one on my other car. I was going to make a parts order and just wondering on a part number or a susbsitute.
TLR 22
Desc410r
zleader_99 is offline   Reply With Quote
Old 12-29-2010, 09:12 PM   #6697
E.J. Evans's Avatar
Send a message via Yahoo to E.J. Evans
The outer diameter of the layshaft is 5mm. I use our TOP steel shims.
Shim Set M5x7mm 0.1,0.2,0.3mm (10 each) [PA-100507]
T.O.P. Racing | APEX Hobbies | R1 | Solaris | NorCal Hobbies |
Solaris Racing Products (SRP) Solaris Spec Tires!
www.solarisrp.com | www.apexhobbies.com | www.topracingusa.com
E.J. Evans is offline   Reply With Quote
Old 12-29-2010, 09:17 PM   #6698
hanzo3's Avatar
Trader Rating: 55 (100%+)
I still have trouble removing the bearings from the spur gear. I decided just to buy a new 20t pulley and bearings and shaft. The shaft that top sells is black and not the red version. What to do?
hanzo3 is offline   Reply With Quote
Old 12-29-2010, 09:24 PM   #6699
odpurple's Avatar
The black shaft is steel and supercedes the red alumium one. The steel shaft does not mushroom on the ends like the aluminum one and your bearings won't get stuck. You will have to space the spur gear assembly differently due to the tab on the steel shaft, use the shims EJ mentioned in the above post
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 12-29-2010, 09:24 PM   #6700
Pro10noob's Avatar
Buy the black one as it is steel instead of alloy.
You won't have trouble removing your bearings with the black shaft.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 12-30-2010, 12:56 AM   #6701
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Where can I get these items ?
TOP ALLOY Steering Crank set (POPCH25)
TOP ALLOY Camber Link Plate
OVA is offline   Reply With Quote
Old 12-30-2010, 04:29 AM   #6702
locked's Avatar
http://www.topracingusa.com/store/index.php?cPath=20_21
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 12-30-2010, 05:17 AM   #6703
MAD916's Avatar
instock at Timezone Franko.......
Timezone Raceway Park " on-road outdoor european style road course.
Timezone II 60'x100' indoor carpet track. Host of the ROAR 2011 Carpet Nat's.
Timezonehobbies.com your new source for online RC products.
MAD916 is offline   Reply With Quote
Old 12-30-2010, 11:22 AM   #6704
Default layshaft shim
Thanks for the help.
TLR 22
Desc410r
Old 12-30-2010, 11:28 AM   #6705
OVA
OVA's Avatar
Ohh...Didn't know ...well are you going to give it up...lol Please PM back with the price...Thanks
