Old 12-22-2010, 06:39 PM   #6646
locked's Avatar
What battery(over 5K mAh?) are you using pakk and how close to the belt is it in order to balance left/right?
What is the minimum weight in your area? Do you have to add a bunch of weight to make minimum weight? Min. weight where I am ranges from 1400-1450g, so I don't think it would make sense for me to flip the servo, but I was considering it on my new kit that is being shipped right now. Hopefully here they will soon follow European rules and drop it to 1350.
Sorry for all the questions
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 12-22-2010, 06:43 PM   #6647
pakk's Avatar
Trader Rating: 79 (100%+)
I run a protek 5600 50c. If you can see that I have spacers on the battery tray, I run my pack all the way against that and it balances well. I think the lowest I have been able to balance my car is 1320.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 12-22-2010, 06:56 PM   #6648
Trader Rating: 20 (100%+)
Default Servo install
I have also installed the servo inwards to the belts on both my Photons. I am using the LPF orion(Savox). Not sure about Pak but I had to trim the upper mount ear off the servo to stop the steering linkage from clashing.
TLR 22
Desc410r
zleader_99 is offline   Reply With Quote
Old 12-22-2010, 06:57 PM   #6649
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
I dont think your steering link isnt semetrical L/R. And ur angle seems to be off on ur saver to turnbuckle angle . It needs to be a 90' between the saver screw,and each end of the turnbuckle
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 12-22-2010, 07:08 PM   #6650
pakk's Avatar
I'm not quite following you, but what ill affects would I have?
*Photon* *SC10 4x4*
RCRD
Old 12-22-2010, 07:23 PM   #6651
MikeXray's Avatar
Trader Rating: 73 (100%+)
That's shoo goo'd in right, doesn't look like the tabs are even on anymore. I was wondering if the servo would fit that way, but the tabs were definitely in the way
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 12-22-2010, 07:26 PM   #6652
mess with ur circles L/R at max throw. And the speed thruout the sweep of the tire. It would be like adding or takin away expo on the servo. Depending on the angle between the bellcrank pivot/ and each end of the turnbuckle. It needs to be a mirror immage between left and right. Using a angle finder for math works great to figure that out if u want to get it perfect or just take 2 pics one to the left and the other to the right and photo shop them over each other to see the difference. The little details make a big difference more than some realize
Justin & Matt Lyons
a800s sanwa m12s
Old 12-22-2010, 07:28 PM   #6653
pakk's Avatar
I use 3m double side'd tape. It's been on there for 8months and has not moved. And yeah, I cut the tabs off. I also had to trim the case a bit because the bell crank was hitting it. The servo is right up against the belt, but not close enough to touch.
*Photon* *SC10 4x4*
RCRD
Old 12-22-2010, 09:57 PM   #6654
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
I did the same thing...we both must think the same ways..
OVA is offline   Reply With Quote
Old 12-22-2010, 10:00 PM   #6655
OVA
OVA's Avatar
yes you arre correct..I shoo goo my servo to the chassis...
Old 12-23-2010, 10:30 AM   #6656
Luppi Stefano's Avatar
technical question...
what difference by this 2 topdeck?
first Rubber STD
second Rubber LTD
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 12-23-2010, 10:44 AM   #6657
odpurple's Avatar
first Rubber STD
second Rubber LTD
T.O.P. made a running change to the top deck to accomodate battery packs with integral bullet connecters. Both of the decks in the pic are part # TC-PCHC004. The newer version is what is included in the Ltd. Edition kits
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 12-23-2010, 01:12 PM   #6658
This is clear.
so, nothing changes in the reaction of the model ...?
Lab F1-01
Old 12-24-2010, 12:55 AM   #6659
TF Racing have launched their fully universal carbon fibre battery tray. Made in 3mm carbon fibre they help hold batteries in place during an impact where tape would sometimes break. Light and universal it fits most touring car chassis’ and has adjustable positioning for fine tuning your chassis balance. Mounted on 2 rubber o-rings to avoid tweak, it can accept LiPo batteries up to 138mm x 47mm. larger sizes to follow
T.O.P. Racing "Photon" 1/10 EP Touring Car-battery_tray-pics_2.jpg
tfracing is offline   Reply With Quote
Old 12-24-2010, 05:43 AM   #6660
MikeXray's Avatar
This is clear.
I've had both on the same car and couldn't tell the difference. The clearance is nice even with a thunderpower battery though.
