Old 12-05-2010, 04:26 PM   #6481
old-man's Avatar
Originally Posted by 1shnot View Post
Little help here... first of all, I love this car.
But I'm having this naging leaking problem... I have change the orings ,added green slime , soaked the orings(40*) etc etc but half way into racing day i notice bottom of the spring retainer is all greasy with shock oil... is there anything else I can try other then getting v2's? I thought I heard someone trying muchmore pro orings did the trick, anyone else try it?
Thanx guys
Try these. They offer better seal.
http://www.rc-mushroom.com/product_i...ducts_id=15686
old-man is offline   Reply With Quote
Old 12-05-2010, 05:53 PM   #6482
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
Default springs?
What springs come in the Int'l Rubber Edition Kit?
Fishhook
ewashburnaf is offline   Reply With Quote
Old 12-05-2010, 05:59 PM   #6483
hanulec's Avatar
Trader Rating: 23 (100%+)
344 & 306 -- http://www.topracingusa.com/store/index.php?cPath=3_12
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-05-2010, 06:10 PM   #6484
Originally Posted by hanulec View Post
thanks! That was a quick reply!
Fishhook
Old 12-05-2010, 08:08 PM   #6485
hanzo3's Avatar
Trader Rating: 55 (100%+)
Is top coming out with a new photon? I see so many rollers for sale. I hope not.
hanzo3 is offline   Reply With Quote
Old 12-05-2010, 09:01 PM   #6486
DaveW's Avatar
Prolly cause the T3 '11 and the Tc6 were released over the past few weeks...
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 12-05-2010, 09:49 PM   #6487
Bishop's Avatar
Many drivers are always looking for the magic bullet of RC, hence why you will always find lots of anything up for sale at any given time, but yeah right now the TC6 just came out so that is the flavor of the month right now.
Actually TOP should fear the new TC6, at least in terms of value, it ain't bad, LiPo chassis, simular features to the Photon and it comes with some nice functional lipo mounts (which can perfectly use a TOP strap ).
Next revamp of the Photon package I think needs LiPo only chassis, but with included lipo mounts and strap in the kit...
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 12-05-2010, 10:05 PM   #6488
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
Also keep in mind that the Photon has been out for just under two years now. Therefore a certain number of those 200 or so kits that sold out right away are likely getting replaced by now.
mrrcguy is offline   Reply With Quote
Old 12-05-2010, 10:35 PM   #6489
TeamWTF's Avatar
Would also be nice to move the motor in on the chassis and mount the arms on the chassis instead of the bulkheads...
Had a moment on the weekend and turned in on the steel tubing we use on our sweeper.... sent the car flying.. broke a sway bar adjuster and pulled a srew out of the battery brace... though the tape held the pack in thankfully...
This was at full speed. Very impressed.... no tweak and no 'real' broken bits. Ruined 3 rims/tires in the crash when the car landed and rolled...
Wishing i had the LiPo chassis... The Velcro strap is a nice touch.
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 12-05-2010, 11:34 PM   #6490
vabroom's Avatar
On what side do you guys run the front belt? There's no info for placement of belts on setup sheet.
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 12-05-2010, 11:53 PM   #6491
Bishop's Avatar
I think with LiPo chassis now being common everyone is running the belt on the right side of the car, plenty of room with the packs set out to give the best balance, gives more room for electrics on the left side.
QRCCRA
www.qrccra.org.au
Old 12-06-2010, 12:01 AM   #6492
sosidge's Avatar
Like this?
Old 12-06-2010, 01:54 AM   #6493
TeamWTF's Avatar
Just like that... Actually i was going through the TOP Australia site and saw the Scythe blocks and the look very nice in red
How do you find the Scythe compared to the Photon?
Old 12-06-2010, 02:02 AM   #6494
sosidge's Avatar
The Scythe is very different - however the pic above is of a "Scyton" (Scythe chassis, Photon suspension hybrid) that I have built up. It runs quite a lot like a Photon but has a simpler chassis layout. The suspension blocks are chassis mounted, and the motor is about 1mm further in (although my big ESC won't fit under the centre bulkhead so you can't bring that bit of weight in much).
Just a bit of fun!
Old 12-06-2010, 02:16 AM   #6495
xray racer's Avatar
Trader Rating: 22 (100%+)
Just for a point of mention Sosidge,
You CAN fit the photon diff and spool in the scythe , you just have to modify the shock towers to clear, and run the 37t belt set-up.
Wasn't sure if you had tried this or not.
Cheers
Robbie
Robbie Lloyd
Yokomo * HobbyWing * Sanwa
xray racer is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
