Old 12-03-2010, 02:10 AM   #6466
sosidge's Avatar
Originally Posted by Derek_Siciliano View Post
Hey guys,
Just curious how do you properly set the droop on the photon?
The Photon is no different to any other car. Just use the droop screws in the arm.
The hoop on the rear hub makes the droop measurement look a bit different from the other cars on the market. As a guide, it's about 4mm lower than the bottom edge of the wishbone.
I have my car on 5.5 front, 1 rear (on the gauge) for rubber/carpet. Seems about right!
Old 12-03-2010, 02:28 AM   #6467
Trader Rating: 55 (100%+)
Originally Posted by RCFREAK View Post
Dave, did you just post "steering rack"? Let the TC3-4 go already!
Thats some funny $hit right there
Jamison R is offline   Reply With Quote
Old 12-03-2010, 05:34 AM   #6468
Ok, my other question is how do you set the tweak after you have the set the droop?
Derek Siciliano
____________________________________________________________________________
CRC GEN XL/TOP PHOTON/TEKIN/LRP/COMPETITION ELECTRONICS/SMC/SANWA M11X/HUDY
Derek_Siciliano is offline   Reply With Quote
Old 12-03-2010, 06:24 AM   #6469
sosidge's Avatar
I just lift it with the holes in the middle of the shock towers and adjust the pre-load. But there are many ways to set tweak on these cars. It's just the same as any other RC car in that respect.
Old 12-03-2010, 09:50 AM   #6470
hanzo3's Avatar
Iam trying to change the spur gear. I can seem to remove the bearing. How do I do this?
hanzo3 is offline   Reply With Quote
Old 12-03-2010, 10:45 AM   #6471
try to push the ball bearings a bit back and break the edge. rhan is your problem solved.
toptek is offline   Reply With Quote
Old 12-03-2010, 06:10 PM   #6472
Professor's Avatar
RW Racing here in the UK make some machined one-piece centre pulley/spur combos.
Haven't tried one myself, but I reckon they would be a good option for people struggling with the plastic pulleys.
do you have a link or a site where these can be viewed/purchaced
thanks
VBC RACING AUS--HOBBYWING--RC MAKER--
MAD GRAPHICS--BITTY DESIGN
Professor is offline   Reply With Quote
Old 12-03-2010, 09:32 PM   #6473
HappyHippo's Avatar
thanks
http://www.rwracing.co.uk/cars.html
HappyHippo is offline   Reply With Quote
Old 12-04-2010, 10:53 AM   #6474
1shnot's Avatar
Little help here... first of all, I love this car.
But I'm having this naging leaking problem... I have change the orings ,added green slime , soaked the orings(40*) etc etc but half way into racing day i notice bottom of the spring retainer is all greasy with shock oil... is there anything else I can try other then getting v2's? I thought I heard someone trying muchmore pro orings did the trick, anyone else try it?
Thanx guys
-Fast cats
-eXpress motorsports
-T.O.P
-Airtronics
1shnot is offline   Reply With Quote
Old 12-04-2010, 11:22 AM   #6475
sosidge's Avatar
Thanx guys
I have the Tamiya o-rings (from #53574) and have no leaks. This is using the original shaft guides too.
Old 12-04-2010, 03:24 PM   #6476
stiltskin's Avatar
Trader Rating: 102 (100%+)
Thanx guys
Make sure that your shock shafts are not scratched up. They may be cutting into the o-rings and causing the leak.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 12-04-2010, 09:41 PM   #6477
DaveW's Avatar
I picked up an extra set of shock shafts and they are greyish in color compared to the shiny color of the ones that came in the kit. Nothing is specified on the package as to why... any ideas?
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 12-05-2010, 08:04 AM   #6478
gruman28's Avatar
Trader Rating: 16 (100%+)
I am ordering a photon, I run on an indoor high traction asphault track, 17.5 spec, can I use the spool or should I buy another ball diff for the front?
I am kind of new to touring. I have only ran ball diff's. Just dont want to get to the track only to find that my car isnt as driveable as it should be.
Chris
gruman28 is offline   Reply With Quote
Old 12-05-2010, 08:34 AM   #6479
MikeXray's Avatar
Trader Rating: 73 (100%+)
Chris
Most run spools, some are running gear diffs with thick fluid, not many would run ball diff up front with rubber tires.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 12-05-2010, 10:20 AM   #6480
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
Chris
If you are going to run a diff in the front I recommend getting gear diffs up front use 120,000 diff fluid and 10,000 in the rear and you should be set. That set up also works very well outdoors.
RACE OPT USA
Bartolo Racing R/C
