T.O.P. Racing "Photon" 1/10 EP Touring Car
#6421
Check the roll centre blocks.
Check the shock tops and bottoms.
Check the pre-load adjusters haven't been screwed on upside down.
#6422
Anyone who has a good setup with foam tires
#6423
I have done everything you guys told me to do, miraculously when I installed a Tamiya shocks I can set the ride height anywhere I want. I will be taking pictures with the Tamiya shocks on and with the Photns. Maybe the car just want a little blue in it.
#6427
check your shock shafts, on some of them there's a 4mm piece unthreaded on the end of the shaft itself that stops you from shortening the shock much more than 63mm
#6428
I know there is something I'm missing because it was not like these befor. Take a look at the pictures. Note: blue ball stud is by tamiya which I think should not matter,I have been using TOP stud and ride height is the same.
#6429
Incorrect shock bottoms. Tamiya? Put the TOP ones back on.
#6430
some more. BTW rea has no problem. Also one picture with the shock is, is that the right link for it or maybe the shorter one.
#6431
#6432
#6434
#6435
PS that blue ball stud is too small for the TOP shock ends.
Don't give your car to your friend to work on any more. It's all over the place with parts. Strip it back down yourself and build it like the manual says. It will run a lot better.
