Old 12-01-2010, 12:20 PM   #6406
jrp
jrp's Avatar
Trader Rating: 18 (100%+)
Originally Posted by munrath View Post
Larry/Schreff,
When running Larry's setup did you feel or notice when traction was low that the rear end was loose off-power? Like when coming down the straight into the sweep and as you start to lift up off the throttle the rear end wanted to swing out?
Mark
That was my experience with that setup on low/med bite carpet. I have made changes to make it better but now I have my car too bound in the corners. I am gonna reset the setup back to Larry's and start over.
Spektrum - CRC - Horizon Hobbies - RC America - XRay - Prolevel RC - Max Power - SRC
- RC Gears for Android - Find it in the Android Market
jrp is offline   Reply With Quote
Old 12-01-2010, 01:22 PM   #6407
Is one of you using the Cefx conversion kit for the Photon?
toptek is offline   Reply With Quote
Old 12-01-2010, 03:14 PM   #6408
Send a message via AIM to munrath
I'm not.
Tekno RC (RTM) / RadioPost / Tekin / Pro-Match Racing / AKA / PT Racing Oils/Diff Lube
Races for 2015:
PNB, AMS, E-Nats Warm-up, E-Nats, LCRC North East Challenge, RAC, LCRC Halloween, Badlands, ROAR Region 2 Series, and Local Club Racing
munrath is offline   Reply With Quote
Old 12-01-2010, 08:48 PM   #6409
cheehtae's Avatar
Trader Rating: 15 (100%+)
Need help here guys, I had my friend rebuild my car and when i got home to change shock springs I could'nt set my ride height. Shocks are set to max (not coiled down) and my height would be at 7-8 mm. I tried switching front shocks to rear, checking if anything is binding, negative. It was not like this before. BTW I'm using the rubber springs.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 12-01-2010, 08:54 PM   #6410
do you run on rubber or foam tires?
Old 12-01-2010, 08:58 PM   #6411
cheehtae's Avatar
Rubber tires on carpet, it was not like these before just after the rebuild.
Old 12-01-2010, 09:03 PM   #6412
locked's Avatar
I would check first that the spring retainers are seated all the way down on the ball cups.
Take the springs off and check the rebound while you're at it.
Which holes are they in on the arms and the towers?
Can you take some pictures?
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 12-01-2010, 09:06 PM   #6413
cheehtae's Avatar
retainers are seated all the way down, when shocks are not installed nothing is binding. Shock position is in the 3rd or middle hole.
Old 12-01-2010, 09:24 PM   #6414
locked's Avatar
if you are using sway bars, check that those set screws in the center of the shock tower mount area aren't tightened all the way down on the bar.
Rebuld your car
Dave Locke
Old 12-01-2010, 09:35 PM   #6415
cheehtae's Avatar
Rebuld your car
No sway bars attached, I guess I will be rebuilding my car.
Old 12-01-2010, 10:15 PM   #6416
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
you are using the photon springs?
OVA is offline   Reply With Quote
Old 12-01-2010, 10:33 PM   #6417
cheehtae's Avatar
I am using photon spring, I did try HPI's and tamiya. No luck. Rebuild the front still no luck.
Old 12-02-2010, 03:22 AM   #6418
Trader Rating: 54 (100%+)
Are you saying that you cannot set ride height below 7-8mm? What is the shock length? What exactly did your "friend" rebuild on the car?
Jamison R is offline   Reply With Quote
Old 12-02-2010, 03:27 AM   #6419
A Ilievski's Avatar
Trader Rating: 39 (100%+)
Droop screws
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIGE BEARINGS*
A Ilievski is offline   Reply With Quote
Old 12-02-2010, 03:30 AM   #6420
Originally Posted by kid TT-01 View Post
Droop screws
Thats why I asked if it "cannot" be set below 7-8 mm. If thats the case its not the droop screws. If it cannot go up that high I would say droop screws. Either way post some pics and there is plenty of help on this forum.
