Old 11-30-2010, 05:49 PM   #6391
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
Originally Posted by hanulec View Post
and four or fifth (depends who you talk to..) in 17.5T Stock Spec was Ron "The Goat" Goetter
Jason and Larry were in the A-main of 17.5 Super Stock but blew out in the A-main.
So we have 3 in the "A" for both classes then. Nice!
mrrcguy is offline   Reply With Quote
Old 12-01-2010, 06:47 AM   #6392
Trader Rating: 17 (100%+)
So I have been working really hard to get a good set up on my car, and we have a NWIC series race this weekend. They are pretty big local races for our area and there are a lot of fast drivers. For some reason I will go practice, and get my car to where it feels really good. My buddy will come out with his T3 11 (X-Ray Team driver as well) and he will be continuously 2-3 tenths faster. I cannot get my car to carry the corner speed for the life of me. Last night at a club race was the fastest I have got it so far and Iím scrubbing the crap out of the chassis. I will ask my friend for help and he just tells me to buy an X-ray LOL. Anyone have any suggestions.
Springs are 306 -344
Rear sway bar only 1.6 (gained over tenth by taking off the front)
I just changed to Low blocks in front with medium in rear the car seemed to dive in better but will push mid corner
Camber is about 2.5 all the way around. Planned on taking camber out as traction comes up.
About 2.5mill of up travel front and rear.
Mr.A Morris is offline   Reply With Quote
Old 12-01-2010, 07:02 AM   #6393
pmc
Hello
what is the surface carpet or asphalt??
You and your partner have the same esc and motor??
Only lose time in the rotation curve??
Best regards:
Pedro silva
pmc is offline   Reply With Quote
Old 12-01-2010, 07:10 AM   #6394
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
To me nothing about that setup sounds right so you might want to rethink your whole setup. Running a higher rear roll center than the front and only rear swaybar means you are way off IMO.
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 12-01-2010, 07:13 AM   #6395
jrp
jrp's Avatar
Trader Rating: 18 (100%+)
Larry,
How different was you setup from the US Indoor race from the one you posted here a few weeks ago ?
Thanks,
Jim Piersol
Spektrum - CRC - Horizon Hobbies - RC America - XRay - Prolevel RC - Max Power - SRC
- RC Gears for Android - Find it in the Android Market
jrp is offline   Reply With Quote
Old 12-01-2010, 07:20 AM   #6396
Originally Posted by jrp View Post
Larry,
Thanks,
Jim Piersol
It was identical, Jason, Ron and myself all ran that exact setup except with 1.75 front camber instead of 2 and we pretty much only sauced 1/2 of the front tire.
Other than that it was exactly the same as the setup posted.
Old 12-01-2010, 07:29 AM   #6397
Hello
Carpet.
Same ESC. I know he has more motor than I do.. I have some power coming my way which should help a little.
Yeah I know my set up seems weird but for some reason it works pretty dang good. There are a few other people running Photons in my area with (common) set ups and well.. I tend to be faster. I'm planning on going back to the same roll center all the way around. I just wanted to try it. I see a lot of X-rays like that. It made the car feel bound up mid corner.
Old 12-01-2010, 09:35 AM   #6398
L. Faritrace
I looked at your set up sheet you posted I will try it and let you know how it goes.
Its well A LOT different from what I'm currently running. LOL
one question though. what does the M-L roll center in the rear do? Sorry if that seems like a dumb question.
Old 12-01-2010, 10:17 AM   #6399
pcar951's Avatar
Trader Rating: 19 (100%+)
Just my .02 on this but, I was lacking corner speed, took a chance and went to the aluminum steering knuckles. Wow, the car turns in hard, and all the way through, had to raise the front roll to mid-high and reduce camber to 1.5. What a difference.
pcar951 is offline   Reply With Quote
Old 12-01-2010, 10:22 AM   #6400
schreff's Avatar
Send a message via AIM to schreff
L. Faritrace
I didn't read Larry's setup sheet, but I do know he's running a little anti-squat in the back. I think it's the Medium roll center block with the cam low in the front half of the rear and the rear most roll center block is the Low with the cam in the high position.
I, personally, ran the rear with low roll center blocks with the cam in the high position. That kept the rear pins level.
Antisquat helps the car with bumpy surfaces. I shoulda put that on my car as the Champs wasn't exactly a smooth track, but it wasn't bad.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 12-01-2010, 11:17 AM   #6401
OVA
OVA's Avatar
Trader Rating: 77 (100%+)
L. Faritrace
Hi Morris
I'm using Larry farirace set up , the car roll alittle too much for my taste..
right now the hangar30 grip is very close to TZ2...
I did some changed, pushout f/r shock one hole out and put on the 1.4 f/r sway bars and 50wt. losi f/r and front 2.00 camber 2.25 camber rear.... 3.00 deg. total rear toe end
The car got ton of corner speed and drive very close to new T3 xray...according from everybody watching me...
I might go with the longer camber link f/r ..I think is will smooth out the car ...
There's something i hated about the car ,the chassis rub ,even the ride height is 5mm f/ 5.5mm rear...suck
OVA is offline   Reply With Quote
Old 12-01-2010, 11:23 AM   #6402
Thanks for the FYI OVA hope you going make it down this weekend? It should be a fun race...the traction will be high for RC PLUS!
There are some pretty fast guys going to be racing it should be a pretty tight group in stock.
Old 12-01-2010, 11:28 AM   #6403
OVA
OVA's Avatar
Thanks for the FYI OVA hope you can make it down this weekend. It should be a fun race...the traction will be high for RC PLUS!
Hi Morris
I wish I could .but have to work this sat.....Be aware This will be another photon driver coming back soon....
Old 12-01-2010, 12:06 PM   #6404
Send a message via AIM to munrath
Larry/Schreff,
When running Larry's setup did you feel or notice when traction was low that the rear end was loose off-power? Like when coming down the straight into the sweep and as you start to lift up off the throttle the rear end wanted to swing out?
Mark
Tekno RC (RTM) / RadioPost / Tekin / Pro-Match Racing / AKA / PT Racing Oils/Diff Lube
Races for 2015:
PNB, AMS, E-Nats Warm-up, E-Nats, LCRC North East Challenge, RAC, LCRC Halloween, Badlands, ROAR Region 2 Series, and Local Club Racing
munrath is offline   Reply With Quote
Old 12-01-2010, 12:19 PM   #6405
Not really, If anything I feel like that setup pushes in the sweeper when traction is low.
The setup really works best in medium high/High traction.
I also adjust camber and saucing according to traction levels.
