Old 11-18-2010, 09:56 AM   #6316
Luppi Stefano's Avatar
Originally Posted by JETT View Post
What fluid did you go with?
for first run, Use original 700 cps
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 11-18-2010, 09:59 AM   #6317
macdude's Avatar
Originally Posted by jrp View Post
Anyone have a pic of an explanation on how the lipo center weights mount in the car ?
I am referring to TOP PO-PCW030 like this http://rcmarket.com.hk/product_info....oducts_id=6794
The center weight is tapered to accommodate the belt droop. The two o-rings that come with it go into the recesses on the bottom to keep the thing from slipping. Mine did not come with a nut so you will need to find a nut that fits into the cut out on the top. The hole in the chassis centerline closes to the motor mount is where you screw it in. If you have the lipo chassis you will have an extra set of holes in the middle. I use the ones furthest to the battery side of the chassis because I am running the drive train flipped.
hope this helps.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 11-18-2010, 10:27 AM   #6318
odpurple's Avatar
Originally Posted by macdude View Post
Any chance of just getting the aluminum inserts?
Originally Posted by Kwikvdub View Post
Anybody know where I can get a TOP Battery Strap here in the states??
Thanks!
In stock at TOP Racing USA
topracingusa@yahoo.com
650-583-8898
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 11-18-2010, 10:35 AM   #6319
mickrcarver's Avatar
Trader Rating: 98 (100%+)
anyone have a good base rubber tire setup for new very loose carpet?? I have the new version car and I have the optional camber links if needed 17.5 no boost class,Thanks
www.ovrccc.com
www.speedybillsrc.com
mickrcarver is offline   Reply With Quote
Old 11-18-2010, 10:43 AM   #6320
Originally Posted by old-man View Post
6 x 0.3mm + 1 x 0.1mm.
On each side of the diff 3 x 0.3mm with one side an additional 0.1mm.
Originally Posted by hanulec View Post
TOP sells them - T.O.P. PA-101012 10mm Shim Set
http://racerlog.com/wiki/T.O.P._Photon#Gear_Diff
Thank you!
cvccsi is offline   Reply With Quote
Old 11-18-2010, 11:35 AM   #6321
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
i have one posted a few pages back it should get you in the ballpark
Old 11-18-2010, 11:44 AM   #6322
Looks good Marcos,but I'm running a front spool and gear diff in rear just wonder what the effects of that change would be??
www.ovrccc.com
Old 11-18-2010, 11:47 AM   #6323
Super Moderator
Marcos.J's Avatar
i ran the same set up with the spool and rear gear diff, when i added the front gear diff all i had to do was to dial down the dual rate on the radio because i gain so much more steering with the gear diff. Besides that is the same set up
Old 11-18-2010, 11:59 AM   #6324
ok,I'll give it a try,Thanks
www.ovrccc.com
Old 11-19-2010, 05:27 PM   #6325
cheehtae's Avatar
Trader Rating: 15 (100%+)
what diff pulley do you use for the gear diff?
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 11-19-2010, 05:35 PM   #6326
Super Moderator
Marcos.J's Avatar
TOP oneway pulley
Old 11-19-2010, 06:47 PM   #6327
cheehtae's Avatar
TOP oneway pulley
Is it the same as the one for spool?
Old 11-19-2010, 06:49 PM   #6328
MikeXray's Avatar
Trader Rating: 72 (100%+)
No, the spool doesn't have a separate pulley, its all one molded piece with separate outdrives.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 11-19-2010, 06:59 PM   #6329
cheehtae's Avatar
Thanks for the info, i am ready to order it's a good thing I've ask first. Thank you too MJ. Also how is it compared to spec r?
Old 11-19-2010, 07:59 PM   #6330
DaveW's Avatar
What is a good servo suggestion (metal gears) with transit speeds below .10 sec? Im partial to my Sanwa servos with transit speeds of .06, but they are aging and i feel bad putting either of them in this spankin new car...
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
SEO by vBSEO 3.5.0
