Old 11-15-2010, 04:20 PM   #6286
pcar951's Avatar
Trader Rating: 19 (100%+)
3.8 was our FDR at IIC this year for 17.5 un-boosted. I ran 88/46.
pcar951 is offline   Reply With Quote
Old 11-15-2010, 04:25 PM   #6287
mickrcarver's Avatar
Trader Rating: 98 (99%+)
Thanks!!
www.ovrccc.com
www.speedybillsrc.com
mickrcarver is offline   Reply With Quote
Old 11-16-2010, 08:45 AM   #6288
Default SPARE PARTS
I am breaking up my old xray 008, and wanted to know if the 008 driveshafts, or indeed any parts can fit my photon. I particularly like the xray driveshafts, and if they are compatible I can save some cash on spare driveshafts
Let me know
Lohan is offline   Reply With Quote
Old 11-16-2010, 09:07 AM   #6289
Let me know
I was wondering the same,if xray shafts fit I have many 46mm laying around
www.ovrccc.com
Old 11-16-2010, 02:17 PM   #6290
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
Let me know
Hanulec runs a complete Xray drive train in his car. I don't see a need for it but if you have the parts already you can use them up and then revert back to stock. See link for install tips.
http://www.racerlog.com/wiki/T.O.P._..._gear_ratio.29
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 11-16-2010, 04:53 PM   #6291
hanulec's Avatar
Trader Rating: 27 (100%+)
the setup i'm using is based upon the 38 tooth xray pulleys. these pulleys were included with certain T2'008 EU models -- but not all of them. When these larger pulleys were used within the T2'008 you had a 2.375 internal gear ratio. i don't think the 'stock' EU drive shafts were 50mm though. Xray billed the 50mm shafts as 'foam' touring parts, and 52mm shafts as the 'rubber' parts.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 11-16-2010, 06:10 PM   #6292
Send a message via AIM to munrath
Tekno RC (RTM) / RadioPost / Tekin / Pro-Match Racing / AKA / PT Racing Oils/Diff Lube
Races for 2015:
PNB, AMS, E-Nats Warm-up, E-Nats, LCRC North East Challenge, RAC, LCRC Halloween, Badlands, ROAR Region 2 Series, and Local Club Racing
munrath is offline   Reply With Quote
Old 11-16-2010, 06:13 PM   #6293
macdude's Avatar
Running the diffs flipped on the new lipo chassis. Anyone notice the rear diff loosing up. Mine seems to be getting loose.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 11-16-2010, 08:50 PM   #6294
cheehtae's Avatar
Trader Rating: 15 (100%+)
The grub screw for the stabilizer bar ( in between the two flat screw ),how tight should it be? Will it make the car out of control if it's too tight?
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 11-16-2010, 09:24 PM   #6295
Bishop's Avatar
You want the sway bar to pivot, so they are just there to take up slop, and not be tight as that stops them acting like a sway bar.
I do them up till just tight, then back off the grub screw a touch, as far as I know that is the right way to set them up.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 11-17-2010, 11:54 AM   #6296
odpurple's Avatar
That is correct, the sway bars must pivot freely. Unfortunately the Photon is not mistake-proof, and at least half of the cars we check have that set screw tight on the sway bar. That really screws up the cars handling
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 11-17-2010, 12:03 PM   #6297
cheehtae's Avatar
That's the reason why my car was uncontrollable ..
Old 11-17-2010, 04:24 PM   #6298
Luppi Stefano's Avatar
Yokomo Gear Diff, Perfect Fit With 1,9mm spacer
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 11-17-2010, 04:32 PM   #6299
What fluid did you go with?
JETT is offline   Reply With Quote
Old 11-17-2010, 04:49 PM   #6300
Trader Rating: 55 (100%+)
where is the 9mm spacer?
Jamison R is offline   Reply With Quote
