Old 06-10-2009, 04:46 AM   #616
Send a message via AIM to goop
use fishing line and lift the car off the ground very accurate way to balance
Hurricane Motorsports
Team Trinity
TOP Racing - Gravity Rc - Contact tires - KO Propo - Competition Electronics
goop is offline   Reply With Quote
Old 06-10-2009, 05:51 AM   #617
razzor's Avatar
but wouldnt hanging the car compared to balancing the chassis be different.
Balancing from below the chassis to me makes more sense and should be more accurate.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 06-10-2009, 05:59 AM   #618
Yes and no.
Yes you will see more difference.
But it's not more accurate. the result is the same.
When you are balancing from below it's easier to see the very small difference.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 06-10-2009, 06:21 AM   #619
Josh Cyrul's Avatar
Originally Posted by Besercoe View Post
It seems strange that the kit setup has the ackerman on the hubs in the forward position?
Could the hubs possibly be molded so that the rear hole is the extreme rear hole as used by the old xray hubs? So that the fwd hole is actually equal to the rear hold on other cars.
The shorter position is the same as the long position on the old HPI/HB steering blocks that we used to use (rubber tire). The longer position we used for foam tires here in the US.
Yes, the car is super light - Even with 5-cells at the Reedy Race and the 1425g limit I still had to add 55g to get my car to the legal limit - That's with a box stock kit with only titanium tie-rods added to the car. I did run a small servo but still I would have had to add quite a bit of weight.
As far as balancing, I prefer the holes in the shock towers as you don't need special balancing posts to check your car. You can simply use two xacto blades or even a 1.5mm wrench to lift the car. As long as the table you are checking on is close to level then you can feel very small differences in picking up/setting down the car to balance it (within 5g). I've double checked this with my 4 corner scales and I can get it closer this way than the balancing pins.
Trinity, Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Zenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 06-10-2009, 09:53 AM   #620
syndr0me's Avatar
Trader Rating: 32 (100%+)
All the pictures I've seen seem to indicate nobody is running a servo saver? Do you guys not blow up servos that way?
syndr0me is offline   Reply With Quote
Old 06-10-2009, 10:19 AM   #621
E.J. Evans's Avatar
Send a message via Yahoo to E.J. Evans
I'm running a servo saver because I need it. I run a Kimbrough black medium.
Josh doesn't but he also doesn't crash.
T.O.P. Racing | APEX Hobbies | R1 | Solaris | NorCal Hobbies |
Solaris Racing Products (SRP) Solaris Spec Tires!
www.solarisrp.com | www.apexhobbies.com | www.topracingusa.com
E.J. Evans is offline   Reply With Quote
Old 06-10-2009, 10:21 AM   #622
syndr0me's Avatar
Ah, cool. I was thinking about running the Tamiya one, it seems to feel more direct than the Kimbrough. I just need to get the arm anodized red instead of blue.
I'd be more willing to try no saver if Futaba sold its nylon gears in bulk. $40 for a full gear set it too rich for me.
Old 06-10-2009, 10:29 AM   #623
E.J. Evans's Avatar
Originally Posted by Skitee View Post
Probably by passing a piece of string through the centre of the car under the shock towers, then hang the car from the string which runs through the holes in the shock tower. We'll let E.J. confirm that though
Like Josh said, two exacto blades or 1.5mm wrenches on a relatively flat table. Set your ride height and droop, with your tires on and all electronics in the car including battery. LOL lift the car up and you can feel which side comes up first. You can also ask a friend to look at the tries while you lift.
I've also done it without tires on and just made sure that the chassis is parallel to the table. I think both ways will get the job done.
Old 06-10-2009, 11:00 AM   #624
KennyClark's Avatar
One of the guys I was racing with at the weekend was running a Photon and I got a chance to have a good look at it.
I have to say I was even more impressed with it in the flesh than in the pictures.
Im very tempted.
Perhaps next season!
Muchmore
Team Durango
KennyClark is offline   Reply With Quote
Old 06-10-2009, 01:15 PM   #625
R/C Tech Charter Subscriber
Default Photon
We should have 4 or 5 Photon's running at the Much-More UK GP this coming Fri/Sat/Sun. We're trying to get some video established but unsure if it will work until we get to the track on Thursday. Here's the link.
keithander is offline   Reply With Quote
Old 06-10-2009, 01:57 PM   #626
razzor's Avatar
Unfortunately my order is delayed but good things come to those who wait
The TOP guys are pushing to get orders out and are packing everything as quick as possible.
Casterracing ZX1.5R
Old 06-10-2009, 02:06 PM   #627
RC MARKET's Avatar
this is best case, but delay some days release .
RC MARKET is offline   Reply With Quote
Old 06-10-2009, 02:46 PM   #628
Dan415ms's Avatar
Thumbs up This weekend in Scotland - several Photon's racing
Hi All,
As Keith says, keep an eye on our live race feed here:
http://www.bbk-online.net/bbkRClive/
or
http://muchmoreracing.com/news/news-...-coverage.html
Potentially the most Photon's ever to race at one event in the world to date.....keep on eye on how the guys get on. There are also several Scythe's competing.
There is also a TOP European forum set-up which contains a Photon thread so keep an eye on it
http://www.top-racing-europe.eu/forum
Looking forward to racing my car again this weekend, it's sitting in front of me on my computer desk and looks raring to go.
Thanks,
Dan
Dan415ms is offline   Reply With Quote
Old 06-10-2009, 02:50 PM   #629
Dan415ms's Avatar
Im very tempted.
Hi Kenny,
If there's time at the weekend I'll happily let you have a few laps with the car, I'll have a much neater electrics install this weekend I promise!
I was very happy with the way the car performed right out of the box with the kit setup.
Cheers, see you in a day or so.
Dan
(must change my username to DanPhoton!)
Old 06-10-2009, 02:59 PM   #630
Trader Rating: 28 (100%+)
Reedy Race there were 5.
Team I'm Over It
racenut123 is offline   Reply With Quote
SEO by vBSEO 3.5.0
