Old 11-14-2010, 07:01 PM   #6271
Trader Rating: 20 (100%+)
Default U-pro
MikeXray
not trying to start anything.. No issues with Top USA.. Just tossing it out there and trying to support our LHS... tyring to keep the $$$ in the Americas..
Having said that I am a proud owner of two photons.. A converted mi4 runner.
TLR 22
Desc410r
zleader_99 is offline   Reply With Quote
Old 11-14-2010, 07:52 PM   #6272
Muchhobby is out of stock, but it's a nice website. I'll keep them in mind for other stuff.
I'll give top USA a call tomorrow. I wasn't sure if they carried them.
DJG24 is offline   Reply With Quote
Old 11-14-2010, 08:23 PM   #6273
hanzo3's Avatar
Trader Rating: 55 (100%+)
I got a Protek 5000mah lipo. It is a pretty tight fit. Would this tweak the chassis? I am using 6 cell rubber chassis. I have to have the bullet connects at the rear of the car. Anyone use bullet hard cased lipos?
hanzo3 is offline   Reply With Quote
Old 11-14-2010, 09:20 PM   #6274
Pro10noob's Avatar
Yup me,different brands also.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 11-14-2010, 10:03 PM   #6275
Bishop's Avatar
I'm using 5000mah IP packs with bullet plugs, no issues at all, but then I'm also using the lipo chassis, with the old chassis the battery sits a lot further in stock, so from what I have seen if you want an easier fit the idea is to set it up so the pack sits further out.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 11-15-2010, 02:19 AM   #6276
TeamWTF's Avatar
Use longer screws on the long battery brace and space it out around 5mm... This should be pretty good for balance with only a few grams needed on the battery side. Also, turn the battery brace upside down so it sits higher then the chassis level to prevent rubbing on the track when cornering...
Also this gets the battery plugs away from the top deck...
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 11-15-2010, 06:36 AM   #6277
MAD916's Avatar
We have some of the gear diff's in stock.....
[email protected]
Timezone Raceway Park " on-road outdoor european style road course.
Timezone II 60'x100' indoor carpet track. Host of the ROAR 2011 Carpet Nat's.
Timezonehobbies.com your new source for online RC products.
MAD916 is offline   Reply With Quote
Old 11-15-2010, 06:51 AM   #6278
Email sent to you. Thanks for the help!
Old 11-15-2010, 12:00 PM   #6279
Default Puzzled by xxx main
Here's something that has puzzled me for awhile, and with every car I've used.
when one lays down front or rear shocks, the XXX main book says it softens that side of the car, thereby allowing it to roll more and generate more grip (in a nutshell)
However, when I lay down the rear I find it rotates around faster, and when I stand it up it seems to gerate more grip - especially the initial bite.
Am I a complete spud, or do others agree with me on this?
Lohan is offline   Reply With Quote
Old 11-15-2010, 12:55 PM   #6280
sosidge's Avatar
Bolded the relevant bit.
Although the car will generate more ultimate grip with a layed down shock, the stood up shock gives a more direct feel.
Old 11-15-2010, 02:09 PM   #6281
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
Well its a ratio between the X and Y axis of the shocks when u lay then in they travel a shorter distance (the shock) even tho the chassis is moving the same makin the spring rate seem softer . Same applies the opposite when goin out with them at the top. Now if u change the bottom location it will make a regressive change in the shock spring rate like if u go out with the bottom the shock will be softer at first and then firm up as travel increases . And same applies to goin in with them. I started running them out wide in the front to allow the car to role more at slower speeds and firm up as loads increase
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 11-15-2010, 02:19 PM   #6282
mickrcarver's Avatar
Trader Rating: 98 (99%+)
ok why am I missing this?? what is the gear ratio of the photon? 2.0?
www.ovrccc.com
www.speedybillsrc.com
mickrcarver is offline   Reply With Quote
Old 11-15-2010, 02:24 PM   #6283
Default cheers
I am gonna hav a play around
Old 11-15-2010, 02:38 PM   #6284
stiltskin's Avatar
Trader Rating: 102 (100%+)
Yes. 2.0
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 11-15-2010, 02:46 PM   #6285
Thanks Tony ,going back to no boost what were you guys running spur gear and pinion wise for 17.5 on a lrp stoc spec esc?
www.ovrccc.com
