Old 11-09-2010, 08:58 PM   #6196
pakk's Avatar
Trader Rating: 79 (100%+)
well you can put the nylon guide in it to make it smoother. That's what I did.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 11-09-2010, 09:50 PM   #6197
ChadB.'s Avatar
Trader Rating: 16 (100%+)
Originally Posted by hanulec View Post
You'll need to buy the 40 degree o-rings.. they are not the ones included with the new shocks.
The inside hole is the one usually used on the rear hub. You'll see it checked on Larry's setup above...
Thanks Mike.
Chad Burdick
*Mugen Seiki*Flashpoint Racing Products*9th Annual Timezone Grand Prix July 13th-16th 2017*Unique Air Design*TimezoneRacing*RoseCityScaleRacers* Daves RC Track
ChadB. is offline   Reply With Quote
Old 11-10-2010, 05:10 AM   #6198
ghostman24's Avatar
Trader Rating: 25 (100%+)
Originally Posted by L.Fairtrace View Post
Here is my most recent setup. It works very well. Our bite was really high this week and there was zero worry of traction rolling while many other cars were.
I suggest if you are going to try the setup please do the whole thing exactly how it is listed. Putting half a setup on is not trying the setup.
Change your shock orings to the 40 degree ones and put fresh ones in when do this setup. Its very important to have perfect working shocks for this setup to work good.
I would suggest reading my shock building tutorial on Hanulecs Wiki.
I can't get the file to open. Is anyone else having trouble with this also.
ghostman24 is offline   Reply With Quote
Old 11-10-2010, 05:59 AM   #6199
stiltskin's Avatar
Trader Rating: 99 (100%+)
Opened right up for me.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 11-10-2010, 06:18 AM   #6200
RC MARKET's Avatar
Originally Posted by RC MARKET View Post
TOP New Option Parts Release !
Alloy Camber Link Plate
Alum. Steering Crank insert !
T.O.P. Racing "Photon" 1/10 EP Touring Car-top-po-pch026rd.jpg
RC MARKET is offline   Reply With Quote
Old 11-10-2010, 09:12 AM   #6201
greenracing's Avatar
Can someone please list the upgrade parts this car have if i purchase one today?? (lipo chassis or new shocks)
AE RC8.2, OS Speed XZ-B
TLR 8ight T 3.0, Clockwork Modified RB F11
greenracing is offline   Reply With Quote
Old 11-10-2010, 10:32 AM   #6202
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
The current car if bought int he USA comes with an extra set of plastics.
It comes with the chassis I am running. It comes with the new shocks.
I would really only suggest you "need" the optional camber plates and all the Rubber springs 393,367,324,289.
The car pretty much comes with everything needed.
I have been liking the optional machined 1.2 pistons recently also. But that is not needed to be fast.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 11-10-2010, 10:47 AM   #6203
jrp
jrp's Avatar
Trader Rating: 17 (100%+)
What are the optional camber plates ?
Spektrum - CRC - Horizon Hobbies - RC America - XRay - Prolevel RC - Max Power - SRC
- RC Gears for Android - Find it in the Android Market
jrp is offline   Reply With Quote
Old 11-10-2010, 11:47 AM   #6204
Pro10noob's Avatar
Replacement of the carbon fiber parts?
cheers Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 11-10-2010, 12:18 PM   #6205
Professor's Avatar
hi larry
what is/are the advantages of the optional camber plates ???? & have u tried the new spool yet ?????
graham
VBC RACING-R1 WURKS AUS--HOBBYWING--SILVERBACK--MAD GRAPHICS--BLITZ
Professor is offline   Reply With Quote
Old 11-10-2010, 12:19 PM   #6206
MikeXray's Avatar
Trader Rating: 72 (100%+)
The holes are offset 1.25mm the plate is cut with a point instead of round like the stock one, and there is an additional really long link location.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 11-10-2010, 12:22 PM   #6207
Do you know what the advantage is for running a long link with the optional camber plate?
cvccsi is offline   Reply With Quote
Old 11-10-2010, 12:53 PM   #6208
What chassis are you running, the lipo one?? I ask because I will order the car shortly and I've seen in amain a lipo chassis for this car and if the kit doesn't have this chassis I'm willing to buy it, but if the car brung this chassis it is 117 bucks I'll spend in another things like air fare to the birds in Jan.
Old 11-10-2010, 01:13 PM   #6209
odpurple's Avatar
The current kit comes with both the six cell chassis and the Stiff lipo chassis. Larry is using the Stiff lipo chassis. The optional camber link plates he's talking about are the 1.25mm graphite ones which make for a longer camber link. There are now also the optional aluminum camber link plates in standard or 1.75mm.
There is quite a list now of option parts available for the car, but as Larry says you don't need much to make the car fast. Just start out with the extra springs and maybe some 1.4 sway bars and spacers for suspension adjustments. After you've run the car you will have a better idea of what option parts you might want.
We have compiled a list of all the option parts for the car and it's available to anyone who wants a copy. Just contact us at topracingusa@yahoo.com
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 11-10-2010, 01:34 PM   #6210
hana166's Avatar
Hi, I run cefx and use the long link in the front, over the bulkhead. For me this makes more mid corner steering and seems much more consistent all the way out of the corner. The front seems to roll deeper into the corner. Love the way it makes the car feel.
I guess its personal but I don't like the link in any other position. I think Paul Lemieux has done something similar with the xray.
Having said that I know a number of very good drivers who hate this arrangement.
Just an opinion !
hana166 is offline   Reply With Quote
SEO by vBSEO 3.5.0
