Old 11-09-2010, 03:25 AM   #6181
hanulec's Avatar
Trader Rating: 25 (100%+)
Originally Posted by old-man View Post
Spec-R or X-ray parts - Do you mean the CV shafts? Had a set of Spec-R's CV few months ago and it only lasted a pack till the cross joint broke. I thought the X-ray's CV shafts are a little too long, 52mm I recall. Unless I am missing something here.
Using chatter free front drive shafts allows you to run the car with full steering lock. So far I've done this two different ways - both of which I've documented and included parts lists.
You can easily fix that broken cross pin with piano wire from any hobby store. This is also documented.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 11-09-2010, 04:27 AM   #6182
Trader Rating: 54 (100%+)
http://www.nexusracing.com/product_i...oducts_id=3266
can these be used with x-ray c blocks? Or are they too long?
Jamison R is offline   Reply With Quote
Old 11-09-2010, 04:41 AM   #6183
hanulec's Avatar
The atomic /spec-r shafts designed for XRay t2/t3 are 50mm long but these will ONLY mate up with XRay diff/spool parts. You cannot use them with the TOP diff/spool parts. The size of the "mating" connector on XRay parts is different than TOP. GET IT?
Old 11-09-2010, 04:44 AM   #6184
Originally Posted by hanulec View Post
The atomic /spec-r shafts designed gor XRay t2/t3 are 50mm long but these will ONLY mate up with XRay diff/spool parts. You cannot use them with the TOP diff/spool parts. The size of the "mating" connector on XRay parts is different than TOP. GET IT?
I see. So the BD-5 shafts will fit TOP diff/spool outdrives, with the xray blades. Correct?
Old 11-09-2010, 05:00 AM   #6185
hanulec's Avatar
Yes.
The xray blades just appear to hold up longer in the documented configuration. Others might work too.. but I didn't have any other brands in my pit box to try ..
Old 11-09-2010, 05:53 AM   #6186
sprintcarracer's Avatar
I just bought a photon and was wondering what a good baseline setup for a tight low grip carpet track would be. Or will the box stock setup work good?
sprintcarracer is offline   Reply With Quote
Old 11-09-2010, 06:30 AM   #6187
RC MARKET's Avatar
TOP New Option Parts Release !
Alloy Camber Link Plate
T.O.P. Racing "Photon" 1/10 EP Touring Car-top-popch02xrd.jpg
RC MARKET is offline   Reply With Quote
Old 11-09-2010, 07:24 AM   #6188
Hi,
I am running a photon gear diff u-pro or m-pro which ever you prefer!!!
It comes with 2 red alloy rings that look like out-drive protectors but they are far to slack and would just fall off, can any one tell me what they are for??
cheers
michael.branth is offline   Reply With Quote
Old 11-09-2010, 07:29 AM   #6189
MikeXray's Avatar
Trader Rating: 73 (100%+)
Originally Posted by michael.branth View Post
Hi,
cheers
Spacers, they go on the inside of the bulkheads so the diff doesn't slide left to right.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 11-09-2010, 09:50 AM   #6190
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Here is my most recent setup. It works very well. Our bite was really high this week and there was zero worry of traction rolling while many other cars were.
I suggest if you are going to try the setup please do the whole thing exactly how it is listed. Putting half a setup on is not trying the setup.
Change your shock orings to the 40 degree ones and put fresh ones in when do this setup. Its very important to have perfect working shocks for this setup to work good.
I would suggest reading my shock building tutorial on Hanulecs Wiki.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 11-09-2010, 10:37 AM   #6191
ChadB.'s Avatar
Trader Rating: 21 (100%+)
i have the old shocks still on my car and I need to upgrade to the new ones. I was wondering if the new shocks have the 40 degree orings with them? Also, I noticed on the set-up sheets, it is not shown which hole everybody uses on the rear hubs. Which one does everybody use?
Chad Burdick
*Mugen Seiki*Flashpoint Racing Products*9th Annual Timezone Grand Prix July 13th-16th 2017*Unique Air Design*TimezoneRacing*RoseCityScaleRacers* Daves RC Track
ChadB. is offline   Reply With Quote
Old 11-09-2010, 02:16 PM   #6192
You know I see "RC Market" always on here looking for business, so I finally order a gear diff for my Photon on Monday, pay for express shipping, and now my status says processing for 2 days! Is this normal? Seems weird to pay for expedite shipping and then have it sit for a few days before shipping
DJG24 is offline   Reply With Quote
Old 11-09-2010, 05:43 PM   #6193
hanulec's Avatar
You'll need to buy the 40 degree o-rings.. they are not the ones included with the new shocks.
The inside hole is the one usually used on the rear hub. You'll see it checked on Larry's setup above...
Old 11-09-2010, 06:05 PM   #6194
Trader Rating: 20 (100%+)
Default old shocks
Can the old shocks be upgraded to the new shocks by replacing the internals? Sorry if this has been asked before. Second question how can I tell if the new to me photon has the older or new shocks?
TLR 22
Desc410r
zleader_99 is offline   Reply With Quote
Old 11-09-2010, 07:50 PM   #6195
LARRY F SR's Avatar
no the shock are totaly different the new even the body
T.o.p. USA - Photon - EX - S4 - Rebel 12
The Beaver raceway - Horsham raceway - Jackson rc racing - Austintown Hobby
LARRY F SR is offline   Reply With Quote
