Old 11-08-2010, 04:14 PM   #6166
DaveW's Avatar
Originally Posted by chris_dono View Post
... the shock shaft itself... there's a 4mm 'stub' on the end where you thread the ballcup on, check if yours has this and grind it off. No more ride height issues.
If you grind off the stub on the end of the shock shaft, and thread it into the ballend further, and your threaded collars were already all the way up... then you just increased preload on your spring.
Yes, your rideheight will be lower... but spring preload=bad.
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 11-08-2010, 04:32 PM   #6167
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Buy Top springs and run them. I have been able to get rideheight with both TOP and HPI springs with no problem.
Stop drilling a bunch of unnecessary holes in graphite.
The car comes with 344/306 so you need to buy 3 pairs of springs to have all you will ever need for rubber tire
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 11-08-2010, 04:37 PM   #6168
RCFREAK's Avatar
Trader Rating: 17 (100%+)
DAVEW... not just the dremel... the keyboard also!!!
Arv.
RC AMERICA// EA MOTORSPORTS// KO PROPO// ORCA
RCFREAK is offline   Reply With Quote
Old 11-08-2010, 04:40 PM   #6169
RCFREAK's Avatar
Originally Posted by DaveW View Post
I wonder if Dremel would sponsor me... Cant be any worse than having Chick Fil A as a sponsor...
Dave, if they did, you would be trying to open the Dremel and find another 450RPMs out of it by using your dyno...
Arv.
Old 11-08-2010, 04:57 PM   #6170
hanulec's Avatar
Don't make Larry angry... you don't want to see him angry!
Build Instructions -> http://racerlog.com/wiki/T.O.P._Photon#Shocks
Parts to buy -> http://racerlog.com/wiki/T.O.P._Photon#Shocks_2
Don't be a failure!
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 11-08-2010, 05:18 PM   #6171
DaveW's Avatar
Don't be a failure!
Thanks for the heads up. I love tickin people off, and strive for perfect failure.
Old 11-08-2010, 06:23 PM   #6172
What are ratings for the additional 3 pairs of springs? Thanks.
cvccsi is offline   Reply With Quote
Old 11-08-2010, 07:01 PM   #6173
ChadB.'s Avatar
Trader Rating: 16 (100%+)
Don't be a failure!
Mike, did you notice a difference in performance when changing to the 1.9 internal ratio?
Chad Burdick
*Mugen Seiki*Flashpoint Racing Products*9th Annual Timezone Grand Prix July 13th-16th 2017*Unique Air Design*TimezoneRacing*RoseCityScaleRacers* Daves RC Track
ChadB. is offline   Reply With Quote
Old 11-08-2010, 07:05 PM   #6174
hanulec's Avatar
nah-- nothing i could feel. i ran the car successfully in stock non-boosted so i suspect it should work in other configs too. it is all about making sure the drive train is super free...
Old 11-08-2010, 07:09 PM   #6175
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
344 spring 19.2 lbs
324 spring 18.1 lbs
306 spring 17.1 lbs
thats pretty much all you need for outdoor asphalt
I run 344 fronts and 306 rears indoor and outdoor rubber for a while now and I haven found the need to even run any other kind of springs
Old 11-08-2010, 07:15 PM   #6176
ChadB.'s Avatar
Good to know. You saved me a bunch of money.
Chad Burdick
Old 11-08-2010, 07:18 PM   #6177
hanulec's Avatar
the chatter-free front drive train setup is important. it can be done either way - spec-r parts or xray parts. i've also heard good things about hot bodies universals, but haven't tried them myself personally.
Old 11-08-2010, 07:40 PM   #6178
Originally Posted by Marcos.J View Post
344 spring 19.2 lbs
324 spring 18.1 lbs
306 spring 17.1 lbs
Great, thanks/
Old 11-08-2010, 10:30 PM   #6179
old-man's Avatar
Spec-R or X-ray parts - Do you mean the CV shafts? Had a set of Spec-R's CV few months ago and it only lasted a pack till the cross joint broke. I thought the X-ray's CV shafts are a little too long, 52mm I recall. Unless I am missing something here.
old-man is offline   Reply With Quote
Old 11-09-2010, 04:22 AM   #6180
georgec's Avatar
Xray also makes 50mm shafts. But for the cost difference I run 50mm Atomic/Spec-R on the rear or my T3 (gear diff) and have had no problems with premature wear or failure =)
georgec is offline   Reply With Quote
SEO by vBSEO 3.5.0
