Old 11-06-2010, 05:14 PM   #6136
hanzo3's Avatar
Trader Rating: 55 (100%+)
Do u guys buy your spares from TOP or from amain? TOP is probably cheaper?
hanzo3 is offline   Reply With Quote
Old 11-06-2010, 10:08 PM   #6137
RC MARKET's Avatar
http://rcmarket.com.hk/
RC MARKET is offline   Reply With Quote
Old 11-06-2010, 10:18 PM   #6138
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Originally Posted by RC MARKET View Post
How come Rcmarket selling price is the same as USA?
It much cheaper buy from USA ( usa shipping is much cheaper)
OVA is offline   Reply With Quote
Old 11-07-2010, 04:52 AM   #6139
cheehtae's Avatar
Trader Rating: 15 (100%+)
yep, their shipping is outrageous.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 11-07-2010, 05:35 AM   #6140
If you live elsewhere in the world RC Markets shipping is the same price and they ship quite a bit quicker. As well because of different trade agreements there is quite often no tax or duty from Hong Kong. RC Mushroom ships the fastest of all to where I live, Stormer second, RC Market third.
I ordered my TOP from A Main and it was $31 shipping, it took 11 days and it cost me $52 in customs and shipping or a total of $83 to my door.
I ordered all the batteries diffs, swaybars springs and accesories from RC Mushroom and it cost my $37 for freight and had my stuff in 5 days, no duty or taxes.
Stormer is always 7 days delivered and I have to pay duty and taxes as well.
"we need to do at least 11.2 km/s to break earths orbit or almost the speed as Cam's car"
Neil Armstrong 1968
Cammer is offline   Reply With Quote
Old 11-07-2010, 08:37 AM   #6141
OVA
OVA's Avatar
your right....I was refering for usa buyer,to buy their top parts from usa..
Old 11-07-2010, 10:16 AM   #6142
odpurple's Avatar
We actually ship a lot of orders to Canada. By using the right carrier and the correct customs code you can avoid duty fees
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 11-07-2010, 11:24 AM   #6143
jrp
jrp's Avatar
Trader Rating: 18 (100%+)
Default shock balls
What is the trick to get the balls freed up in the shock ends ? I have a ball link reamer for my helis but it is too small for these. Does someone make a larger one, or is there something else ?
Spektrum - CRC - Horizon Hobbies - RC America - XRay - Prolevel RC - Max Power - SRC
- RC Gears for Android - Find it in the Android Market
jrp is offline   Reply With Quote
Old 11-07-2010, 12:04 PM   #6144
Jerry P's Avatar
Trader Rating: 44 (100%+)
If they are bound up you may have threaded the shock shaft to far into the end. I did that and it actually dimpled the inside and bound up the shock real bad. I changed the ends and didn't thread them in as far and all was fixed.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 11-07-2010, 03:40 PM   #6145
GCT69's Avatar
yep just USA shipping, and also price in amain and rcmarket is about the same.
GCT69 is offline   Reply With Quote
Old 11-07-2010, 05:25 PM   #6146
smoke81's Avatar
Send a message via AIM to smoke81 Send a message via Yahoo to smoke81
Like was posted before. You could have them threaded in to far. Also a tip to free up all the ball cups on the car. Take a body reamer and lightly ream the top side of the cup. It should free the ball up nicely.
Dustin Layne
smoke81 is offline   Reply With Quote
Old 11-07-2010, 06:41 PM   #6147
Mangoats's Avatar
I flipped the drives over on my car as suggested. Thanks for all the good info here. Planning on getting the rest of the stuff ordered this week. Looking forward to driving the car.
Chris
I'm a noob!
Mangoats is offline   Reply With Quote
Old 11-07-2010, 06:52 PM   #6148
hanzo3's Avatar
Do you guys take off the upper deck to change spur gears? We can only use top or xenon spur gears? How do you take out the aluminum post from the spur gear?
Old 11-07-2010, 07:50 PM   #6149
stiltskin's Avatar
Trader Rating: 102 (100%+)
I roll the belt off the front diff and slide the pulley out the back. If you have the original RED layshaft, you may have to use some force to get the post out. After removing the assembly from the car, put a screw in one side of the layshaft just a few threads. Support the opposite side bearing somehow so the layshaft is free to slide out. You could center it on an old wheel. The rim will support the bearing and let the layshaft slide out. Use a mallet or hammer and tap the inserted screw until it comes free. If you're reusing the layshaft, you'll have to sand the burrs off the ends to let it slide through the bearings easier. HTH.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 11-08-2010, 07:39 AM   #6150
DaveW's Avatar
My kit came with the black steel layshaft. Any idea what to do with the tab on the end of it? It just spins around as i try to tighten the two layshaft screws. Seems pointless.
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
