T.O.P. Racing "Photon" 1/10 EP Touring Car >
Like Tree9Likes
Old 11-01-2010, 04:21 PM
  #6091
thanks!
Derek_Siciliano is offline
Old 11-01-2010, 11:45 PM
  #6092
RC MARKET's Avatar
Originally Posted by shaun207
so is this right , all you need is ..
part no . 3r-sak-07 and the 3r-sak-vo5
and just the different size bearings and the original centre shaft ..
to be honest theres nothing wrong with mine ( both photons ) but its a nice cheap bit of bling !! and it serves a purpose too ..
SAK-07 was stop !
SAK-U05 now !
RC MARKET is offline
Old 11-02-2010, 01:16 PM
  #6093
hanzo3's Avatar
Trader Rating: 55 (100%+)
Hi do I get a 3.5 fdr with a photon? Fdr is calc by using spur/pinion x 2?
hanzo3 is offline
Old 11-02-2010, 01:25 PM
  #6094
Trader Rating: 23 (100%+)
88 spur / 50 pinion X 2-IR = 3.52
pcar951 is offline
Old 11-02-2010, 01:29 PM
  #6095
jrp
jrp's Avatar
Trader Rating: 19 (100%+)
Or you could download "RC Gears" for your Android phone and let it do all the calculations for you
jrp is offline
Old 11-03-2010, 05:50 PM
  #6096
Kwikvdub's Avatar
Trader Rating: 100 (100%+)
Thumbs up
Nice stuff from the TOP Camp: http://www.redrc.net/wp-content/uplo...obbyShow-5.jpg
http://www.redrc.net/wp-content/uplo...obbyShow-6.jpg
Kwikvdub is offline
Old 11-04-2010, 04:10 AM
  #6097
R/C Tech Elite Member
Jamison R's Avatar
Trader Rating: 66 (100%+)
Aluminum inserts look nice
Jamison R is offline
Old 11-04-2010, 11:16 PM
  #6098
DZ
Hey Guys,
Has anyone measured the arm roll centres in comparision with other manufactures.
i.e. Medium high is equal to 1.5mm under TCX toe blocks
It would be great to get an understanding on this?
cheers
Dz
DZ is offline
Old 11-04-2010, 11:58 PM
  #6099
RC MARKET's Avatar
Yes coming soon !
Attached Thumbnails T.O.P. Racing "Photon" 1/10 EP Touring Car-img_0020.jpg
Old 11-05-2010, 07:27 AM
  #6100
Kail's Avatar
Are those new front harder UJs? I am searching for something stronger than photon's alum UJ but not the steel ones. Haha. Any good 3rd party recommendations?
Kail is offline
Old 11-05-2010, 07:33 AM
  #6101
sosidge's Avatar
Why not the steel ones?
Because if you are really that concerned about rotating mass, they make no discernible difference. But they are very reliable and inexpensive.
sosidge is offline
Old 11-05-2010, 07:34 AM
  #6102
Kail's Avatar
Ok sure, will try them. Anyways, have any of you guys tried fitting Spec-R C.V. Universal Swing Shaft on your TOPs? Any of those fits?
Kail is offline
Old 11-05-2010, 08:01 AM
  #6103
stiltskin's Avatar
Trader Rating: 103 (100%+)
I know that Jason Schreffler and Larry Fairtrace have run them. I believe that it requires widening the hole in the c-hub to allow for the larger diameter driveshaft. May also require a different bearing, but I'm not positive.
stiltskin is offline
Old 11-05-2010, 08:02 AM
  #6104
sosidge's Avatar
Originally Posted by DZ
Hey Guys,
cheers
Dz
I can tell you that a MH block places the centre of the suspension shaft is 7.5mm above the bottom of the chassis plate (2.5mm chassis).
As I'm sure you already know there is 0.5mm difference between each insert position.
I can't tell you what the equivalent setting on a TCX is. For comparison, on a TOP Scythe, 0mm under the blocks gives a 7.5mm pin centre.
By the way, the lower arms on the Photon are the same length as the TCX (and Pro4 and Cyclone), the front c-hubs have the same geometry (although the knuckles have 1mm wider offset), and the rear hubs are the same height if you add a 2mm spacer, although they upper link position is 1mm outboard. (by my measurements )
sosidge is offline
Old 11-05-2010, 08:15 AM
  #6105
DaveW's Avatar
Almost all modern TC's are very close to Yokomo's MR4 TC SP design dimensions. The Tc3 was almost indentical to the MR4 TC (i know, i owned both). Ideally they are all clones, with exception to the last Losi offering.
Whip out your micrometers... spend a few hours comparing parts. You will be surprised.
DaveW is offline
