Old 11-01-2010, 09:28 AM   #6076
Pro10noob's Avatar
Originally Posted by KingKarate757 View Post
Link????
Scroll down a bit and you find the pulleys 2
http://www.rc-mushroom.com/index.php?cPath=36_408
Regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 11-01-2010, 11:17 AM   #6077
Originally Posted by Pro10noob View Post
I know i am going to get some bad comments on this one but why don't you use the Sakura Zero centre pulley set on the Photon??
I know i do and it fít's like a glove. They are also half the price of the TOP pulleys.
No spacers needed at all and the spurs runs straight as an arrow.
You can even switch centre pulley's on it like 20,19 or 21 so you can create a different interal ratio.
Only thing that is different are the bearings.
You need to use the Tamiya F1 front wheel bearings on this pulley set.
regards Roy
I was thinking of using this as well. Do you still need to ream the spur gear?
cvccsi is offline   Reply With Quote
Old 11-01-2010, 11:31 AM   #6078
MikeXray's Avatar
Trader Rating: 72 (100%+)
ERhmmmmmmmmmmmmmmmm yes ther are but hardly seen
EZoff can make them silver its actually a good idea. Once I switched to the steel layshaft, I can't say that the plastic pulleys have given me any issues, and it weighs considerably less.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 11-01-2010, 11:49 AM   #6079
Pro10noob's Avatar
If you use Xenon or Kimbrough spurs no,you won't have to ream out the spurs.
regards Roy
l===/o\===l
Old 11-01-2010, 12:17 PM   #6080
regards Roy
Thanks..
Old 11-01-2010, 01:26 PM   #6081
cheehtae's Avatar
Trader Rating: 15 (100%+)
so do you have to have this one too to fit the pulleys?
http://www.rc-mushroom.com/product_i...ducts_id=21086
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 11-01-2010, 01:41 PM   #6082
hanulec's Avatar
Trader Rating: 23 (100%+)
Would it be possible to use the 3racing pulleys with different gear counts? Does it allow the left and right gear to be of different size/tooth counts? This could be interesting to create an over drive.
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 11-01-2010, 01:49 PM   #6083
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
Yes to all of it. I had those 3 racing pulleys on my HB Cyclone.
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 11-01-2010, 02:42 PM   #6084
Pro10noob's Avatar
Yes you have as that is the gear adaptor where the pulleys go on.
regards Roy
l===/o\===l
Old 11-01-2010, 02:48 PM   #6085
RC MARKET's Avatar
I'm had used this adapter change gear ratio for my drive style but no good ,
because the center pulley can't fixed in this spur gear holder ,
& need use old ver. alu. center shaft !
RC MARKET is offline   Reply With Quote
Old 11-01-2010, 04:40 PM   #6086
so is this right , all you need is ..
part no . 3r-sak-07 and the 3r-sak-vo5
and just the different size bearings and the original centre shaft ..
to be honest theres nothing wrong with mine ( both photons ) but its a nice cheap bit of bling !! and it serves a purpose too ..
shaun207 is offline   Reply With Quote
Old 11-01-2010, 04:50 PM   #6087
Pro10noob's Avatar
I believe the part number in red is the correct one
part no . 3r-sak-07 and the 3r-sak-vo5 = 3R-SAK-U05
l===/o\===l
Old 11-01-2010, 05:02 PM   #6088
Talking
Hey guys,
I am just building my shocks right now and was just curious what the total lengths of the shocks should be???
Any input would be appreciated.
Thanks,
Derek S.
Derek Siciliano
____________________________________________________________________________
CRC GEN XL/TOP PHOTON/TEKIN/LRP/COMPETITION ELECTRONICS/SMC/SANWA M11X/HUDY
Derek_Siciliano is offline   Reply With Quote
Old 11-01-2010, 05:10 PM   #6089
hanulec's Avatar
Originally Posted by Derek_Siciliano View Post
Hey guys,
Thanks,
Derek S.
61.5mm - http://racerlog.com/wiki/T.O.P._Photon#Shocks
i've collected one or two posts from Larry and threw them all together in one page. i've also added information that i've learned about the car in the three race weekends.
Old 11-01-2010, 05:21 PM   #6090
cheers mate , i stand corrected ...
i cant understand my own hand writing sometimes
SEO by vBSEO 3.5.0
