Old 10-26-2010, 07:22 AM   #6016
DaveW's Avatar
Originally Posted by L.Fairtrace View Post
I will only use the 40 degree o rings. They just feel like they make the shocks smoother to me. But I'm crazy picky about my shocks so its just my opinion.
Shocks are everything in TC. As important as tire choice if you ask me. You gotta be crazy picky.
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 10-26-2010, 07:51 AM   #6017
Bishop's Avatar
Actually it just hit me, with numbers like 20-30-40 etc, that is like shore durometer ratings, so hardness of the o-ring material, higher the number harder the material.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 10-26-2010, 08:39 AM   #6018
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
Default T.O.P. WINS VTA AT HALLOWEEN CLASSIC
http://www.youtube.com/watch?v=gpIsQslSEtc
mrrcguy is offline   Reply With Quote
Old 10-26-2010, 09:58 AM   #6019
cheehtae's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Martin Crisp View Post
Chassis:
I am using the lipo chassis that comes with the kit, but I narrowed it by 5mm on both sides from stock. This is important when going with the soft sprint rates I am running, otherwise the chassis will rub on the carpet.
Can you post a picture of your chassis, Juts want to see how you narrowed it where the motor guard is.
thanks
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 10-26-2010, 11:26 AM   #6020
hana166's Avatar
Originally Posted by pakk View Post
http://www.amainhobbies.com/product_...ng-Guide-Set-4
That is a link to the Teflon guides that go in the v2 shocks. They will work in the v1 shocks and make your v1 shocks very smooth with out having to buy the whole v2 shock set.
As far as sealing, I can't get mine to seal completely. They always seem to leak a little bit, but that's ok for me because I rebuild them before every race.
And for the o-rings, I have been told they don't matter. Which makes me wonder why they have different ones.
Thanks I will use the guides. I have been advised by a friend to use 40 grade seals, and that it does matter. So far it seems every detail counts. I'm fairly fussy I use TRF shocks, shim the pistons 0.1mm, and drill them 1.2mm and drill the caps to kill rebound but use the standard o ring. I think these shocks are very good set like this and I'm sure the TOP shocks have the same potential. Tamiya make a blue o ring I might try. It seems their diaphragms are the item of choice of a lot of racers no matter the brand of car. Perhaps the shocks the next most important area after tyre preparation
I have always used xray springs until recently and have tried TOP, they have been very good providing intermediate steps between xray grades. But I want to try Tamiya springs also, apparently they have a different feel, I'd like to try.
Sorry it might not be the right thread to ask this but been told to get white and blue (carpet) although the springs are completely white. Well some are black. Some coloured..Any recommendations/ part numbers?
hana166 is offline   Reply With Quote
Old 10-26-2010, 03:18 PM   #6021
Martin Crisp's Avatar
thanks
I don't have any pictures handy, but I will see if I can post them later.
i took off the motor guard and shaved off 5mm on both sides of the chassis using a dremel.
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
Old 10-26-2010, 03:20 PM   #6022
Originally Posted by KingKarate757 View Post
Set up sheet sheet is blank.
i tried the download myself, and initially it looks blank, but eventually it does load all of the data....just give it a min or so.
Martin Crisp
Old 10-26-2010, 03:33 PM   #6023
Not really sure about which Martin, setup you are asking for but his last one is here and you can get it from this page.
Arn0 is offline   Reply With Quote
Old 10-26-2010, 03:38 PM   #6024
locked's Avatar
Yeah, that is the sheet he was referring to I think. Sometimes it takes a minute for the data to load.
Martin, you left a few bits on the sheet blank. Are you still using the #12 (largest space between holes) ackermann insert?
locked is offline   Reply With Quote
Old 10-26-2010, 03:47 PM   #6025
Trader Rating: 54 (100%+)
It will not load for me. Im gonna try a different computer.
Jamison R is offline   Reply With Quote
Old 10-26-2010, 03:50 PM   #6026
cheehtae's Avatar
So your not using the motor guard?
Old 10-26-2010, 04:17 PM   #6027
E.J. Evans's Avatar
Send a message via Yahoo to E.J. Evans
Originally Posted by mrrcguy View Post
Congratulations Quinton!! Great job. You take a break and come back with a win!
T.O.P. Racing | APEX Hobbies | R1 | Solaris | NorCal Hobbies |
Solaris Racing Products (SRP) Solaris Spec Tires!
www.solarisrp.com | www.apexhobbies.com | www.topracingusa.com
E.J. Evans is offline   Reply With Quote
Old 10-26-2010, 04:42 PM   #6028
haywood's Avatar
Trader Rating: 48 (100%+)
Default Photon
Great job Q!
haywood is offline   Reply With Quote
Old 10-26-2010, 05:46 PM   #6029
Regional Moderator
mrrcguy's Avatar
Originally Posted by haywood View Post
Great job Q!
Thanks guys. Time to hang up the VTA though in order to focus on TC. Sitting in the middle of the "B" just isnt gonna cut it.
Old 10-26-2010, 05:53 PM   #6030
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
I know the feeling Q...
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
