Old 10-25-2010, 02:26 AM   #6001
Professor's Avatar
Default new parts
Originally Posted by RC MARKET View Post
Micro Pro is Spool !
when will these nwe parts be available ???????
VBC RACING AUS--HOBBYWING--RC MAKER--
MAD GRAPHICS--BITTY DESIGN
Professor is offline   Reply With Quote
Old 10-25-2010, 02:50 AM   #6002
RC MARKET's Avatar
around this week !
RC MARKET is offline   Reply With Quote
Old 10-25-2010, 06:01 AM   #6003
hanulec's Avatar
Trader Rating: 27 (100%+)
I just wanted to thank Larry for all of the help over the past two weeks. My new Photon was really dialed at the Halloween Classic in stock touring this weekend. The only thing I adjusted the entire weekend (successfully) was camber on the car. The medium Solaris premounts were great too -and seemed to get faster the more I ran the tires.
One more BIG shout out to The GOAT for helping resolve my shock drama Sunday morning after wrenching until 3am. I'm still learning the car, and the necessary maintenance points but hopefully next time out I can do even better.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 10-25-2010, 03:00 PM   #6004
Martin Crisp's Avatar
Default Martin Crisp Setup for Halloween Classic Race
http://cid-443b72fc715a2f26.office.l...e.aspx/.Public
This is a link to my public folder on microsoft live
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
Old 10-25-2010, 03:31 PM   #6005
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
NP bro. Glad one of US had are head out of are hind parts there
Good job Martin. Your car looked great all weekend...
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 10-25-2010, 09:09 PM   #6006
Martin, long time since I have seen you at a race. Curious to hear what your camber settings were for the front and rear of your car?
Mike Dumas is offline   Reply With Quote
Old 10-26-2010, 01:18 AM   #6007
Professor's Avatar
around this week !
thanks i will keep a look out on the website
Old 10-26-2010, 01:20 AM   #6008
Default setup
what to setup for low traction/slippery track with same tires..
susp.block: L/M/H ??
camber link??
shock??
etc..
QDriver is offline   Reply With Quote
Old 10-26-2010, 01:25 AM   #6009
sosidge's Avatar
camber link??
shock??
etc..
Is this a general question?
If the grip is low, consider dropping a spring rate (or maybe two) all round. Maybe dropping a bar rate also. Should compensate for the lower grip.
No need to change too much if the car is well balanced already.
Old 10-26-2010, 05:47 AM   #6010
pakk's Avatar
Trader Rating: 79 (100%+)
Originally Posted by hana166 View Post
Can anyone help..
I've got the original shocks.
Is there anything I can do to improve the sealing and get them to work like the new shocks, if possible
What do the o ring grades 20 30 40 mean?
Also please recommend piston for indoor carpet
Using TRF shocks but would like to get the TOP shocks working, they don't look to be a whole lot different TBH
Cheers in advance
http://www.amainhobbies.com/product_...ng-Guide-Set-4
That is a link to the Teflon guides that go in the v2 shocks. They will work in the v1 shocks and make your v1 shocks very smooth with out having to buy the whole v2 shock set.
As far as sealing, I can't get mine to seal completely. They always seem to leak a little bit, but that's ok for me because I rebuild them before every race.
And for the o-rings, I have been told they don't matter. Which makes me wonder why they have different ones.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 10-26-2010, 06:13 AM   #6011
Bishop's Avatar
I gather, but it's part guess, o-ring type/grade will have to do with tightness, a tighter fitting o-ring will likely leak less, but the catch is probably give more friction, it's also got to do with oil thinness your using as well.
This applies to all the shock parts, hence why you can get lower friction pistons, and even shafts, less friction means a better working shock, but really I try to build my shocks leak free so far, I don't really enjoy building shocks that often.
Big tip I know from some of the pros has always been some slime on the o-rings during the build, it's supposed to make them smoother and leak less I think, I'm using like synthetic brake grease on mine, super slippery and won't react with anything plastic or rubber.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 10-26-2010, 06:19 AM   #6012
RC MARKET's Avatar
Today released !
T.O.P. Racing "Photon" 1/10 EP Touring Car-mp-tp-0003.jpg
Old 10-26-2010, 06:32 AM   #6013
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I will only use the 40 degree o rings. They just feel like they make the shocks smoother to me. But I'm crazy picky about my shocks so its just my opinion.
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 10-26-2010, 06:44 AM   #6014
Hey Mike...it has been a long time....hope you are doing well.
I ran 2.25 in the rear and 2.0 in the front.
Martin Crisp
Old 10-26-2010, 07:07 AM   #6015
Trader Rating: 55 (100%+)
Set up sheet sheet is blank.
Jamison R is offline   Reply With Quote
