Old 10-11-2010, 08:31 AM   #5896
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
Here is the set up
Old 10-11-2010, 09:31 AM   #5897
cheehtae's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Marcos.J View Post
I think I posted a carpet set up with dual gear diffs a few pages back try it out it worked very well at my local track.
Hey Marcos,
Will the a gear diff be overkill to use in a small track? or is well suited for a large flowing track?
tnx
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 10-11-2010, 10:18 AM   #5898
MikeXray's Avatar
Trader Rating: 72 (100%+)
Here is the set up
I've compared your setup before, I run a pretty similar setup with the roll center block and springs as the biggest changes. Expierience tells me to use lower roll centers when I have a traction rolling issue, but we'll see how much traction the Gayte actually has. I'm bringing 2 cars for stock and one for mod (which I'm only running a 13.5 in).
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 10-11-2010, 10:25 AM   #5899
Super Moderator
Marcos.J's Avatar
Originally Posted by cheehtae View Post
Hey Marcos,
tnx
i dont feel that it is , i ran it indoors in carpet and outdoors asphalt in mod (5.5 motor) and ran great.
Old 10-11-2010, 10:26 AM   #5900
Super Moderator
Marcos.J's Avatar
i ran it on new carpet medium to high bite
Old 10-11-2010, 11:01 AM   #5901
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
In an acutal high bite situation I feel that the car will most likely traction roll in with the high roll center blocks on it.
Schreffler and I always run the medium roll center blocks and mostly in the low position on carpet and i have never once traction rolled my car and its almost always very good.
I ran the gear diff for the first time this weekend and it produced great laptimes and more steering than I previously had. My on power steering was increased tot he point where I lowered my Dual rate 20 points to compesnate.
It made the car roll more than with a ball diff and to combat this I put on sway bars a 1.4 front and 1.2 rear. It still needs a little tweaking for the setup to be perfect with the gear diff but I think it felt like there was quite a bit of potential.
Still running the standard spool up front though.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 10-11-2010, 11:22 AM   #5902
cheehtae's Avatar
Here is the set up
I see that your running the lipo chassis, did it really made a big difference between the 6 cell chassis?
Old 10-11-2010, 12:35 PM   #5903
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Sorry to ask ..what chassis are you running ? ( .standard 6 cells ,lipo med,stiff,extra stiff)
OVA is offline   Reply With Quote
Old 10-11-2010, 12:40 PM   #5904
Lipo Stiff. With Rubber topdeck and Rubber wings.
Old 10-11-2010, 01:44 PM   #5905
OVA
OVA's Avatar
Old 10-11-2010, 03:49 PM   #5906
Hi, has anyone had problems with the gear diffs?
My friend has already broken 2 of them on carpet in open 13.5, although it was just the "soft" lrp vector x11 stock spec 13.5 with gm genius 90 v2
The first one got broken after he removed shims, the seccond one broke after he has breaked it in on the table, till it felt useful. (but it never got too hot)
both geardiffs broke while running the first run.
Now we are using the spec-r diffs fpr the yokomo and they are fine.
But I have 2 u-pro geardiffs left and would like to use them in the second car, but what if the break in the first run, too?
Is there anything we have to keep in mind before using them?
How do you guys make it last even with 5.5 motors in it?
regards
Chris
Lutz is offline   Reply With Quote
Old 10-11-2010, 04:01 PM   #5907
Trader Rating: 54 (100%+)
I have had 3 uPro gear diffs break on me. Back to ball diff. I run in 17.5 boosted class.
Jamison R is offline   Reply With Quote
Old 10-11-2010, 04:14 PM   #5908
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
It's important that if you take the shims out from behind the gear you put it back in on the outside of the out drive. I spent quite a few hours last week figuring them things out and found that they need to have both those shims or the diff out drive will actually push back in and bind the gear causing them to break.
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 10-11-2010, 05:24 PM   #5909
Super Moderator
Marcos.J's Avatar
regards
Chris
I've ran a full race day with a 5.5 with no issues , i guess is how you drive the car
Old 10-11-2010, 05:33 PM   #5910
How are you suppose to mount the weight next to the battery? They just kind of sit in there but are not held in. What is the way to do this correctly?
DJG24 is offline   Reply With Quote
