Old 09-30-2010, 08:14 PM   #5821
Default Spec-R BD5 Diff
I have a Spec-R diff for sale in the for sale forum if anyone is interested.
Spec-R Gear Diff for Yokomo BD5 40T
cvccsi is offline   Reply With Quote
Old 10-01-2010, 03:19 AM   #5822
Trader Rating: 55 (100%+)
Originally Posted by MikeXray View Post
hmm, I figured you'd run them like (.)(.)
thats how I like mine
Jamison R is offline   Reply With Quote
Old 10-01-2010, 03:40 AM   #5823
hana166's Avatar
What are the reasons for different diff cone arrangements?
hana166 is offline   Reply With Quote
Old 10-01-2010, 03:43 AM   #5824
sosidge's Avatar
It gives a different spring tension. Fitting fewer washers was a solution for the blade breakages but not relevant any more.
In my opinion the standard arrangement works perfectly well for setting the diff, I see no reason to change.
Old 10-01-2010, 06:45 AM   #5825
Trader Rating: 17 (100%+)
Are there any T.O.P drivers heading to the TZ GP race?
Mr.A Morris is offline   Reply With Quote
Old 10-01-2010, 06:52 AM   #5826
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Ej is going to the Timezone race I believe.
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 10-01-2010, 07:04 AM   #5827
Yeah I just saw his name on the Drivers sheet. I'm looking forward to meeting some team drives. Now I just need to learn how to drive LOL
Old 10-01-2010, 09:18 AM   #5828
UK.hardcore's Avatar
Originally Posted by Luppi Stefano View Post
hi!
Spec-R Gear Differential for Yokomo, Fitting on Photon?
thank's
I'd like to know too.
Do the photon driveshafts work in the outdrives???
A racecar is only as good as the mechanic who build it.
UK.hardcore is offline   Reply With Quote
Old 10-01-2010, 09:33 AM   #5829
hana166's Avatar
I agree. But just curious you never know what you can find out on this forum eh
I use all 6 to get the tension I desire, and with the plates all the same way it takes up much less space.
I found with 5 plates and 1.5mm under the diff screw head I was able to run the 46mm driveshafts reliably with clearance for the blades, 44.5 on there at the mo but now my set up is a little wider than before I might revert to the 46mm
Old 10-02-2010, 11:28 AM   #5830
yokemad's Avatar
I haven't shimmed the front end to make it wider so far , on many setups people use wider front with 1mm shim etc.
What effect can happens by making front end wider?
yokemad is offline   Reply With Quote
Old 10-02-2010, 06:20 PM   #5831
Luppi Stefano's Avatar
possible solution, use Spec-R outdrives for Tamiya Gear Diff....
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 10-02-2010, 08:12 PM   #5832
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Spec-r Geardiff 40t anyone ?
Give the best while u can !
kschu is offline   Reply With Quote
Old 10-02-2010, 09:11 PM   #5833
Trader Rating: 10 (92%+)
does anyone use the gear diff made for the photon?
is it just for stock class, or can the diff cope with mod?
http://rcmarket.com.hk/product_info....oducts_id=8969
captain stacker is offline   Reply With Quote
Old 10-02-2010, 09:46 PM   #5834
Hi, are there any distributors on here that would send TOP Photons and their parts to New Zealand? We want to run them here.
If so my email is: [email protected]
jeremy mac is offline   Reply With Quote
Old 10-02-2010, 09:57 PM   #5835
Bishop's Avatar
I think just about all the gear diffs were designed for stock classes (mainly 17.5), but it's not stopped anyone from using them in mod, wear being the main issue, with them maybe needing to be rebuilt more often, depending on how light the oil and how much power you put through them.
Not so keen on ball diffs myself so I'm going to put the Top diff you linked in my 10.5 SS and see how it goes, considering even if it wears faster I think the rebuild kit is like $8, so I figure if it gets maybe 6 meets between rebuilds or something like that I'm good with it.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
