Old 09-16-2010, 07:56 AM   #5716
Trader Rating: 17 (100%+)
Put the photon springs on and the problem went away!! Thank for all the help you guys!
Anybody know where you can get a spring kit?
Mr.A Morris is offline   Reply With Quote
Old 09-16-2010, 07:58 AM   #5717
RC MARKET's Avatar
T.O.P Photon News :
Coming Soon !!
1.1mm , 1.3mm , 1.5mm Stabilizer Bar Set
Suspension Mount Set V2
T.O.P. Racing "Photon" 1/10 EP Touring Car-top-anti-roll-bar.jpg   T.O.P. Racing "Photon" 1/10 EP Touring Car-top-suspension-mount-set-v2.jpg
RC MARKET is offline   Reply With Quote
Old 09-16-2010, 07:58 AM   #5718
MikeXray's Avatar
Trader Rating: 72 (100%+)
They don't come in a kit, a main has all the spings, you can use the black pro-4 hpi set as well, they are almost identical.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 09-16-2010, 08:20 AM   #5719
A driver i knew had this problem.....
You sure the adjusting nut for the shock is the right way round? His wasnt and so couldnt drop the ride height.
Craig Morgan - Tamiya 417
Slick990 is offline   Reply With Quote
Old 09-16-2010, 08:51 AM   #5720
Originally Posted by RC MARKET View Post
T.O.P Photon News :
What's new about them? New design or just different material?
Fastfreddy74 is offline   Reply With Quote
Old 09-16-2010, 09:02 AM   #5721
OVA
OVA's Avatar
Hey Morris
What spring do you need? I may have them nip...lmk
OVA is offline   Reply With Quote
Old 09-16-2010, 09:08 AM   #5722
MikeXray's Avatar
Hopefully a harder plastic like the V2 spool.
Old 09-16-2010, 11:03 AM   #5723
RC MARKET's Avatar
Yes harder !
Old 09-16-2010, 02:34 PM   #5724
Trader Rating: 20 (100%+)
I did not know there was a quality issue with the old ones. Maybe I need to drive the chassis harder.
TLR 22
Desc410r
zleader_99 is offline   Reply With Quote
Old 09-16-2010, 02:37 PM   #5725
MikeXray's Avatar
Its not bad, but they can shift after a hard hit.
Old 09-16-2010, 04:00 PM   #5726
yokemad's Avatar
metal suspension mount insert starts to play when you tighten the screw ,
You have to hold it with Pliers when tighten the screw to manage the notch straight on top or buttom...
yokemad is offline   Reply With Quote
Old 09-16-2010, 04:34 PM   #5727
locked's Avatar
You should double check your suspension mounts Mike, you might find one or two where the notch isn't quite lined up right.
A couple of mine are doing this. If I don't hold them with pliers when tightening them, it will spin the metal piece with the notch inside the plastic mount and makes a few other settings slightly off.
I'll have to pick up a set of these new ones.
locked is offline   Reply With Quote
Old 09-16-2010, 04:59 PM   #5728
DaveW's Avatar
Tony (Stiltskin) loaned me a Photon for a race this weekend. Ive spent the better half of the afternoon going through it, and mind you this was NOT a new kit.
What complaints i have seem to follow what most have already mentioned. The suspension mount cams rotate when you tighten them up. The screws seem sub par in material quality. The wheel hexes seems a little fragile. ETC.
The aluminum LiPo retainers are pimp, but seem best suited for packs with bullet connections. My wired Trinity or SMC packs arent the most convenient for the mounts.
I dig the adjustability of the design. Totally. Flippable arms for lower shock mounting holes. The vertical inner camber plates are sweet and simple. The car has both form and function. I may have found my next car!
Now to see how it does with some HP.
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 09-16-2010, 05:28 PM   #5729
Default Thanks Dave(locked)
Your right I took a better look at the mounts and saw what you were talking about.
I'll have to put those on the list.
Any idea where to run this fall and winter? The Depot track was rained the last 3 weeks.
TLR 22
Desc410r
Old 09-16-2010, 06:27 PM   #5730
locked's Avatar
No idea bro. I'm just hoping someone can manage to organize something nearby before it gets too cold.
Yeah, the timing for rain has been horrible this summer. I think we need to get a massive tent that will cover the entire depot track.
SEO by vBSEO 3.5.0
