Old 09-13-2010, 09:53 PM   #5701
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
Originally Posted by ChadB. View Post
I am looking for a set-up sheet for the 17.5 class for carpet. Can somebody point me in the right direction or post there set-up from the IIC. Thanks for any help.
Try this one
Old 09-13-2010, 10:22 PM   #5702
Trader Rating: 17 (100%+)
I need Help. I took my car out for the first time tonight. It actually did pretty good considering the following....
I could not hit ride height!!! shocks all the way up car sat at 7mm up front, and could barley hit ride height in the rear. 5.5mm. I'm running rubber tires. It is supposed to be a rubber car but I feel like it might have foam shock towers on it.... can someone please help.. DO they make taller shock towers?
Mr.A Morris is offline   Reply With Quote
Old 09-13-2010, 11:32 PM   #5703
smoke81's Avatar
Send a message via AIM to smoke81 Send a message via Yahoo to smoke81
Dustin Layne
smoke81 is offline   Reply With Quote
Old 09-14-2010, 12:15 AM   #5704
*SBH*'s Avatar
Smoke81> That would be the opposite problem then.
A Morris> You can take out the black shims between the spring and the bottom cup that holds the spring. - But maybe You have some wrong springs as well?
Good luck
*SBH* is offline   Reply With Quote
Old 09-14-2010, 12:22 AM   #5705
smoke81's Avatar
Good luck
Durrr.. My bad.. I guess I really should work on catching up on my sleep ..
I guess the question would have to go.. Shock Length, you shouldn't have a problem using the shims although make sure your only using one per spring ( I know they come with a extra per shock or something like that).
Dustin Layne
Old 09-14-2010, 07:59 AM   #5706
There are no shims in the springs. I'm using X-Ray springs, but they are the same length. Ehhh frustrating...
Old 09-14-2010, 09:00 AM   #5707
OVA
OVA's Avatar
Trader Rating: 72 (100%+)
I did the same thing with the tamiya springs . I when back to photon hop up spring ....If you needs the photon harder springs for carpet lmk....
PS xray may be the same length but spring rated is stiffer than photon...
OVA is offline   Reply With Quote
Old 09-14-2010, 02:52 PM   #5708
paraletic's Avatar
Throw the Original kit springs into the car and see if the problem is solved, ie you can achieve ride height etc
if so get the genuine top springs in the required rate your after
Losi XXX-S G+..................Tamiya M03.......................TOP Photon
Losi XXX-4 G+.................HoBao ST Pro electric........Losi Micro SCT
Losi XXX-CR....................Losi Mini Baja.....................Losi XX-4 W/E
ASSociated RC12L4
T.O.P PHOTON EX & Tamiya M05 - currently undergoing rigorous crash testing!
paraletic is offline   Reply With Quote
Old 09-14-2010, 03:05 PM   #5709
OK I will try that tonight. I will try and post some pics of the car tonight its looks pretty good.. Where can you buy a spring kit? I have only found individual spring sets. or what are the most popular spring rates so I can aleast get those. Thanks
Old 09-14-2010, 09:36 PM   #5710
syndr0me's Avatar
Trader Rating: 32 (100%+)
Here's Dustin Layne's winning 17.5 stock setup from IIC. His car looked fantastic all weekend, especially when his electronics were working.
http://igearchart.com/setups/dustin_layne_iic2010.pdf
syndr0me is offline   Reply With Quote
Old 09-14-2010, 10:02 PM   #5711
smoke81's Avatar
Thank you Adam!
The only thing I can think of to add right now is. I ran Alumn spool outdrives and 44.5mm bones in the front.
Dustin Layne
Old 09-15-2010, 06:02 PM   #5712
You should check your droop screws on the rear/front, they can limit the shock travel. My rear droop is set to 1. (to get a ride height of 5.5mm)
Cheers
Ant.
anthony_ling is offline   Reply With Quote
Old 09-15-2010, 06:51 PM   #5713
stiltskin's Avatar
Trader Rating: 99 (100%+)
Cheers
Ant.
Droop screws would only limit the cars ability to obtain a higher ride height. They won't stop it from going lower.
Measure your shock lengths. My shocks are @57mm from hole to hole.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 09-16-2010, 04:25 AM   #5714
I had the same thing when I tried xray springs, rear wouldn't get much below 7mm, try different springs (top ones work fine as do hpi etc)
CPD Racing
chris_dono is offline   Reply With Quote
Old 09-16-2010, 07:34 AM   #5715
yokemad's Avatar
I use xray springs no problem at all
Shocks around 62.5 from top to buttom...
Droop F=5.5 or 6 ,R=5 or 4.5( I remove rear upright to measure)
Ride height F=5 ,Rear=5.5
yokemad is offline   Reply With Quote
SEO by vBSEO 3.5.0
