Old 09-03-2010, 06:26 PM   #5566
paraletic's Avatar
Default Gear diff fluod
Where is everyone getting there fluid from??
I can only find 100,000
Ive looked around a bit and I havnt seen 110,000 or 120,000 etc anywhere so far
Losi XXX-S G+..................Tamiya M03.......................TOP Photon
Losi XXX-4 G+.................HoBao ST Pro electric........Losi Micro SCT
Losi XXX-CR....................Losi Mini Baja.....................Losi XX-4 W/E
ASSociated RC12L4
T.O.P PHOTON EX & Tamiya M05 - currently undergoing rigorous crash testing!
paraletic is offline   Reply With Quote
Old 09-03-2010, 06:55 PM   #5567
Trader Rating: 17 (100%+)
Hello... So I'am just getting back into the sport and I just picked up a Photon. I didn't really feel like looking through 300+ pages of info LOL. Just wanted to know if there is anything I should know about a head of time and what parts are I should stock up on... It will be a rubber car..
Thanks for your input.
Mr.A Morris is offline   Reply With Quote
Old 09-03-2010, 07:27 PM   #5568
Super Moderator
Marcos.J's Avatar
Trader Rating: 166 (100%+)
OFNA 120,000 diff lock fluid , any hobby store should have it
Old 09-03-2010, 07:36 PM   #5569
wayne breault's Avatar
Default Axel pin holder
I just received my axel pin holders, they came with no directions. Can anyone tell me how to install them? I know you use their pins, do I still use the set screws? Which way does the flange on the holder go? Thanks.
wayne breault is offline   Reply With Quote
Old 09-03-2010, 07:43 PM   #5570
stiltskin's Avatar
Trader Rating: 102 (100%+)
Welcome to the club. Nothing is required, the car is pretty good right out of the box. Some things that I can recommend are:
Shims of all sizes for adjustments.
Axle pin covers- they replace the need for a set screw to hold the pin in. Frees up the cvd and easier maintenance.
Aluminum bell crank- stock bellcrank seems to be the weakest part of the car, although I've only broken one and that was the first day that I ran the car.
Gear diffs are a nice option. I've really enjoyed running them recently.
If you're building the car from scratch, make sure that you prethread the sway bar ball cup before threading the red aluminum insert into them. Otherwise, they WILL break. Even after prethreading, don't rush the assembly.
Replace the set screws in the steering bellcrank/ackerman piece with a round head screw to prevent stripping the set screw through the ackerman piece.
Use a small brushed motor shim under the shock pistons to take up the slop.
It's too late to think of anything else. My brain isn't working right now. Good luck with the car. I'm sure you'll enjoy it.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 09-03-2010, 07:44 PM   #5571
stiltskin's Avatar
Use the new pin that came with the covers. Build just like normal WITHOUT the set screw. Slide the cover on from the wheel nut side and the wheel bearing will hold it in place.
Tony Rumple
Old 09-03-2010, 11:44 PM   #5572
just received my gear diff , what weight oil are people using in them for carpet on rubber tyres........
shaun207 is offline   Reply With Quote
Old 09-04-2010, 07:33 AM   #5573
RBR
Hi
I notice that the front steering block will hit the front sway bar link when the link is position straight (90 degree to the chassis) and the turning angle is quite limited. is this ok? what is the normal steering angle when using hudy set up tool?
RBR is offline   Reply With Quote
Old 09-04-2010, 09:35 AM   #5574
Originally Posted by RBR View Post
Hi
My steering arms hit the rollbar mount at full lock too, it's not too much to worry about though
CPD Racing
chris_dono is offline   Reply With Quote
Old 09-04-2010, 10:13 AM   #5575
sosidge's Avatar
Hi
I have the drop links canted forward on my car. They still move freely, and the steering is not interfered with.
Old 09-04-2010, 10:32 AM   #5576
RBR
When you canted forward the drop links, you are actually stiffening the front sway bar which adds more rear grip and this will actuall have less steering, isn't it?
Old 09-04-2010, 12:51 PM   #5577
sosidge's Avatar
Sure, it makes the bar run a little stiffer. However if you are capable of discerning a 2mm lever length difference on a bent-wire bar you are a far superior driver to me! I'll take that over fouling the steering arm every time.
Old 09-04-2010, 09:29 PM   #5578
RBR
Is your rear sway bar canted backward to match the front or u left it at 90degree?
Old 09-05-2010, 12:42 AM   #5579
sosidge's Avatar
I have the rear canted as well.
Old 09-05-2010, 06:06 PM   #5580
stiltskin's Avatar
Ready to roll.
T.O.P. Racing "Photon" 1/10 EP Touring Car-img_0517.jpg
Tony Rumple
