Old 09-03-2010, 04:53 AM   #5551
Default Gear Diffs
Just a quick one about gear diffs....
Ive had 3 or 4 of these now and every signal one feels different when I get it out the packet. Even after a rebuild with the same oil they feel different also. Some feel really smooth whereas others feel notchy (but not where it locks up), but you can feel the gears turning, if that makes sense.
For example, when in the car, with one diff I turn the wheel and it turns the whole drive train (10.5 and pinion attached), but when turned in a diff action it feels nice and smooth, where as another will let me spin it without moving the drive train.
Is this normal?
CouldbeFaster is offline   Reply With Quote
Old 09-03-2010, 05:37 AM   #5552
stiltskin's Avatar
Trader Rating: 102 (100%+)
Is this normal?
Even though tolerances are pretty small, you will still see a difference between diffs. Shims may not be equal or maybe more lube in one. I ran 120k in the front last weekend and while rebuilding it, I took it apart about 3 times to get the right amount of lube in the diff. Too little lube and it will spin too free for the weight of oil. Too much lube and it will leak and feel funny. Trial and error.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 09-03-2010, 06:40 AM   #5553
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Originally Posted by Alienpower View Post
Brandnew
one piece spur/pulley for the Top Photon (pictured below). It is made from black acetal, a strong general engineering plastic and being one piece, is 100% concentric, machined to a very high standard. It has 12 holes drilled through the spur part to make the component as light as possible. It is available in various tooth sizes in both 64dp and 48dp
Made in EU!!
AP1006488 Top Photon one piece spur/pulley 64p - 88T
AP1006496 Top Photon one piece spur/pulley 64p - 96T
AP10064100 Top Photon one piece spur/pulley 64p - 100T
AP10064104 Top Photon one piece spur/pulley 64p - 104T
AP10064106 Top Photon one piece spur/pulley 64p - 106T
AP10064108 Top Photon one piece spur/pulley 64p - 108T
AP10064110 Top Photon one piece spur/pulley 64p - 110T
AP1004880 Top Photon one piece spur/pulley 48p - 80T
AP1004884 Top Photon one piece spur/pulley 48p - 84T
http://kingrc.cc
Originally Posted by yokemad View Post
Costs 4xspurgear !
Pls make it a bit more affordable,stripping spur gear is not very hard especially on a car has that much flex...
Looing at the site thay are about 20 euros ( about 25 us dollars).. Looks sweet...
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 09-03-2010, 06:56 AM   #5554
Costs 4xspurgear !
You´re stripping spur gears often?
I haven´t striped one since two years.
But I use the 48dp ones
Lutz is offline   Reply With Quote
Old 09-03-2010, 07:14 AM   #5555
yokemad's Avatar
Yes mate One of the team driver suggested me to use 48dp spur gear ,many team driver using 48dp over here...
5 euro or pound is ok but I can't afford 20 everytime...
But I must say I love that product ,a little pricey that's all...
Anyways ordered alloy pulley set I can't wait for delivery
yokemad is offline   Reply With Quote
Old 09-03-2010, 07:41 AM   #5556
pcar951's Avatar
Trader Rating: 19 (100%+)
Is this normal?
I've messed around with these diffs a bit, you're right, they're a little inconsistent. Mark the case when you're taking the diff apart and re-assemble it the same way. Don't over-tighten the case screws, it'll bind it up, just need the o-ring to make contact. Like Tony said, play around to get the right amount of lube. I've found that over-filling was causing my diffs to weep fluid, too little would likely melt them down. JMO
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 09-03-2010, 07:52 AM   #5557
Out of interest is that €5 for a spur ?
€20 would cover a spur and a set of centre pulleys I'm guessing if that's the case.
CPD Racing
chris_dono is offline   Reply With Quote
Old 09-03-2010, 08:20 AM   #5558
yokemad's Avatar
Yes mate true ...
That new item is one piece sandwich pulley and spur together very good idea should run true like that but if it goes wrong we need to bin it as it is with pulleys =€20
Not very big deal but you know
Old 09-03-2010, 08:38 AM   #5559
yokemad's Avatar
You know that gear diff gives too much extra rotation to the car ,thicker oil helps to slow it down but is there any alternative setup changes to archive that ?
Like toe-in angle etc...
I wish the size of the gear diff was similar to spec-r one
Thanx in advance...
Old 09-03-2010, 09:04 AM   #5560
ChadB.'s Avatar
Trader Rating: 21 (100%+)
Are you just filling it up to the cross bar?
Where is everybody getting there gear diffs from?
Chad Burdick
*Mugen Seiki*Flashpoint Racing Products*9th Annual Timezone Grand Prix July 13th-16th 2017*Unique Air Design*TimezoneRacing*RoseCityScaleRacers* Daves RC Track
ChadB. is offline   Reply With Quote
Old 09-03-2010, 10:03 AM   #5561
Timezone has gear diffs.
eXpress Motorsports
Timezone 2,Timezone Raceway Park,Rose City Scale Racing.
DaredevilD is offline   Reply With Quote
Old 09-03-2010, 11:42 AM   #5562
I got some from RacingArt Company and from topracing australia.
www.kingrc.cc and www.topracing.net.au
Old 09-03-2010, 11:43 AM   #5563
macdude's Avatar
How much more do the alloy pulleys weigh than the stock ones? Just curious if this would effect the total rotational mass of the drive train. Granted brushless motors are making things easier, but I just wonder if they really are worth putting on the car. Or just buying an extra set of the the stock ones. For quick gear changes.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 09-03-2010, 12:01 PM   #5564
yokemad's Avatar
To be honest I don't know the benefit of using alloy one...
I was thinking it may fit better to kawada spurgears but rcmarket said they didn't improve that point
Maybe you should try that one piece spurgears...
Old 09-03-2010, 12:11 PM   #5565
stiltskin's Avatar
Diffs are in stock at TOP USA. I remove the planetary gear and fill the sides to the top of the internal gear. I put it all back together and give it a few spins. This lets the oil work it's way through the whole case. It usually takes a little more fluid after this. I take it back apart and fill to the top of the internal gear again. Done. Don't overtighten the screws and tighten them opposite of each other a little at a time.
The center pulley is pretty nice. Fits very well and spins very free from obstruction. The best part is that you don't have to glue the sides on. I didn't have a scale to measure the difference, but the aluminum piece is heavier than the plastic original.
Tony Rumple
