Old 08-17-2010, 07:30 PM   #5341
el salvador's Avatar
Default Un-even Rear Toe Issue again revisited!
My previous post #5334 was an attempt to suggest other possibilities for this Rear Toe discrepiency. Also note that I said that this issue was more profound on the original 2.5mm 6 cell "Slotted" Plate. Without reassembling the car with this plate, and without disassembling the car far enough to get accurate/dependable measurements with Digital Calipers, "I", can tell you all, THAT, I can measure .20mm less distance between the Rear Bulkheads, THUS, suggesting that the Bulkheads are not parallel. And NO, the car has not been severely Crashed, Tweeked, or any such thing.
Ultimately, for me, the solution was as simple as just taking the .40mm shim washer that should be located on the Left Rear corner, (this was the only change I made), and installing it on the Left/Front (of that Rear Arm) location, and thats it! This essentially kicks that Arm back to compensate.
I do realize that this "Issue" could bother some Racers and if so, so be it.
As for me, I will not allow this deter me from enjoying a "Very Good Car"!
ARC R8 X2/ Max RP9 or O.S. R2101 ,Capricorn LAB C02-TOP Elite R, ARC R11....
"Every Cemetery in Chicago Votes Democrat!"
el salvador is offline   Reply With Quote
Old 08-18-2010, 02:55 AM   #5342
sosidge's Avatar
Originally Posted by hana166 View Post
Does anyone understand exactly the difference between the top springs gamma beta etc?
I'm looking for a detailed explanation so I can understand when to use what type of spring
So far Xray is my favourite on carpet but I'm looking to expand my experience and knowledge
Gamma is the rubber tyre series.
Alpha/Beta are foam front/rears.
They are wound slightly differently (the Gamma are basically copies of the HPI springs, not sure what the Alpha/Beta are mimicking but they have a smaller internal diameter), but are both linear and should perform according to their rates.
The Gamma springs give ample tuning opportunities for rubber tyres. Here in the UK I've never gone beyond the kit springs or the one rate in between.
Old 08-18-2010, 05:32 AM   #5343
Luppi Stefano's Avatar
I misured distance between Rear Bulkheads, but is parallel...
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 08-18-2010, 06:20 AM   #5344
hana166's Avatar
Thanks very much for your answer. Gamma it is then. On with the experiment
hana166 is offline   Reply With Quote
Old 08-18-2010, 09:31 AM   #5345
darrenoakley's Avatar
To be honest in our club most guys use the hpi pro 4 springs. I was using all the Top Racing ones but found it difficult to exchange set ups as the springs are numbered not colored.
The only problem is getting hold of anything from HPI in the uk at the moment.
there is a good exel spreedsheet for the top springs on the Tchub though.
Xray x11
Xray T3 011
darrenoakley is offline   Reply With Quote
Old 08-18-2010, 09:35 AM   #5346
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I have tried HPI springs and find them no different at all. The top springs are almost exactly the same as hpi springs and the spring rates are very close too.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 08-18-2010, 09:43 AM   #5347
Lightbulb
Well then, Feel Free to find another "Rock to Look Under", just "Say'n" what I've found with my Kit! It's probably older than yours. (1st batch)!
I also note, when discussing this issue, (at that Time), with some of my local/more experienced Racers, an opinion offered by one of them was, "This is not so unusual, the early Xray cars had similar issues as well! just adjust the Car as needed".
Old 08-18-2010, 10:00 AM   #5348
HPI Gold - 344 TOP
HPI Pink - 324 TOP
HPI silver -306 TOP
HPI Blue - 289 TOP
I see Them , Same Colis, Same Long
It's HPI spring!
Lab F1-01
Old 08-18-2010, 10:03 AM   #5349
thank's for explanation
Lab F1-01
Old 08-18-2010, 10:16 AM   #5350
hana166's Avatar
Very useful info. I have Gold and Silver HPI they are good, and have a very different feel to the Xray spring. At some tracks the HPI is better.
Now I can use a black version in exchange which is much nicer I think
I'm doing very well with the car getting in the A all the time now but I reckon I need to rethink my ideas about set up and driving style in order to go to the next level, there is still some way to go to reach the really fast guys
Looking at springs and rollcentres again to find just that little touch of extra cornerspeed. A tiny 0.05 sec faster in 10 corners = half a second - massive
Really studying this now
Old 08-18-2010, 10:19 AM   #5351
hana166's Avatar
HPI Gold - 344 TOP
HPI Pink - 324 TOP
HPI silver -306 TOP
HPI Blue - 289 TOP
It's HPI spring!
Brilliant, thanks !
Is xray 3.0 close to HPI gold ?
Is xray 2.6 close to HPI silver ?
Old 08-18-2010, 11:08 AM   #5352
Brilliant, thanks !
yes!
Lab F1-01
Old 08-18-2010, 12:58 PM   #5353
more like silver/blue than gold/silver
CPD Racing
chris_dono is offline   Reply With Quote
Old 08-18-2010, 01:13 PM   #5354
OVA
OVA's Avatar
Trader Rating: 72 (100%+)
Hey Lyn
Mine is the 1st batch and I was the first one received the kit in the NW and no issued here ...
OVA is offline   Reply With Quote
Old 08-18-2010, 01:22 PM   #5355
no silver and blue it's similar 2.6 and 2.4
Lab F1-01
SEO by vBSEO 3.5.0
