Old 08-17-2010, 07:06 AM   #5326
hana166's Avatar
Shock are personal preference, each brand has a different feeling.
Tamiya/Xray spring is good on carpet
Use the ball diff today its just gonna complicate things with the gear diff
hana166 is offline   Reply With Quote
Old 08-17-2010, 09:35 AM   #5327
Luppi Stefano's Avatar
Originally Posted by Marcos.J View Post
i had the same issue, measured the shims, some have slightly different measurements,some shims vary , i had some that were 1.0mm and some where 1.1mm
Shims ara perfect!
switch Suspension Mount
but sx is 2 and dx reduced to 2,8
WHY?
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 08-17-2010, 09:52 AM   #5328
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
Originally Posted by Luppi Stefano View Post
Shims ara perfect!
WHY?
I'm stuck I don't know what else to say
Old 08-17-2010, 10:15 AM   #5329
I also don't know what else to say....
Lab F1-01
Old 08-17-2010, 10:28 AM   #5330
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Switch the bulkheads and check again
check each screw to see if it is bent
check the suspenion mounts
check the hinge pins to see if they are bent
Check the arms
Check the rear hubs
Verify that the spacers and collars are the right thinkness
Check the carbon fibre wings
Just a suggestion....
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 08-17-2010, 10:43 AM   #5331
bkspeedo's Avatar
I have problem With Rear Toe-in
i have 1mm RF an 3mm RR
but
on Setup Gauge Station
SX is 2 DX 3.2
Car is New, NO Yoke no Crash
Help me
I had the same issue, it was the plastic hinge pin holder that was bad. Replaced it and all was perfect.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 08-17-2010, 11:21 AM   #5332
Super Moderator
Marcos.J's Avatar
mine was with the shims
Old 08-17-2010, 11:40 AM   #5333
great!
Now buy a Spare Part
Lab F1-01
Old 08-17-2010, 12:39 PM   #5334
el salvador's Avatar
Exclamation Un-Equal Rear Toe Issue
I encountered this Issue almost a year ago, as I own One of the First Batch Rubber Spec Kits sold thru A Main Hobbies. I recieved this car in July of last year, took my time assembling it but saved it for the upcoming Winter Carpet Season.
It wasn't till another owner ask,(on RC Tech), if anyone noticed this issue that, (Note- I confess to not paying attention to Rear Toe as like a "Pillow Ball" Rear Suspension Nitro Car would require), the overhead visual reference that had Haunted me, compelled me to check the Toe on a Setup Station.
To cut to the Chase, what I was able to determine is that the Kit 2.5mm 6 cell Slotted Chassis Plate shows the Left/Rear Bulkhead to be located and or holes Drilled Wrong. The First of the 2.5mm LiPo Plates also appear to have nearly as much production Error, (I can measure .20mm less distance between Front and Rear of the Rear Two Bulkheads! (suggesting the Rear Bulkheads are Not parallel).
I brought this Issue up with Michael @TOP, and eventhough I did not get a reasonable explaination, in all fairness to Michael and TOP USA, I know they are really busy keeping up with demand.
And please, don't anybody misunderstand, this is not a big deal as the Rear Hinge pin holders can be "Shimmed" to compensate for this, and by NO MEANS, should detract from an "OUTSTANDING CAR"!
I'm a little disappointed thou that TOP has yet to correct this Issue!
ARC R8 X2/ Max RP9 or O.S. R2101 ,Capricorn LAB C02-TOP Elite R, ARC R11....
"Every Cemetery in Chicago Votes Democrat!"
el salvador is offline   Reply With Quote
Old 08-17-2010, 02:05 PM   #5335
but I have a New Lipo Chassis...
Lab F1-01
Old 08-17-2010, 02:32 PM   #5336
bkspeedo's Avatar
I also have the new 2.25mm stiff lipo chassis and the bulk heads not being parallel does not appear to be an issue, but a good thing to look at.
When i initially built the car the toe was perfect, drove the car, had a few mishaps, the tow was not symmetrical. The same thing happened with an Xray 007. Come to find out if you break a rear arm it puts a lot of stress on the plastic hinge pin holders causing the hole to get deformed throwing off toe.
The nice thing about plastic holders is there cheap, other cars with aluminum holders require a more expensive part to be replace.
I would try the high or low holders in the rear to make sure this is the problem before buying new holders.
Brent Klingforth
5280 Raceway
Old 08-17-2010, 03:17 PM   #5337
i Try Hig e low, 1 difference too
iTry change a Chassis...
1 difference...
plastic holders not are the problem...
Lab F1-01
Old 08-17-2010, 04:01 PM   #5338
hana166's Avatar
Default Springs
Does anyone understand exactly the difference between the top springs gamma beta etc?
I'm looking for a detailed explanation so I can understand when to use what type of spring
So far Xray is my favourite on carpet but I'm looking to expand my experience and knowledge
Old 08-17-2010, 04:08 PM   #5339
paraletic's Avatar
I'd be checking if an arm or rear hub hasn't been missaligned when it was drilled
swap the hubs from left to right etc an check again
If still no good flip the arms across an re check
hav you checked with another setup station to?
Losi XXX-S G+..................Tamiya M03.......................TOP Photon
Losi XXX-4 G+.................HoBao ST Pro electric........Losi Micro SCT
Losi XXX-CR....................Losi Mini Baja.....................Losi XX-4 W/E
ASSociated RC12L4
T.O.P PHOTON EX & Tamiya M05 - currently undergoing rigorous crash testing!
paraletic is offline   Reply With Quote
Old 08-17-2010, 05:17 PM   #5340
Yes, have Swap arm, no change...
front TOE is perfect...
last week have testing with old Setup Station, 1 difference
I don't know what to think!
however, the car on the track is very well!
Have tested on Asphal 2 week later(with toe in problem!) and is very Easy to drive and damn Faster...
Lab F1-01
