Old 08-16-2010, 09:51 AM   #5311
yokemad's Avatar
Hi Guys
How do you measure rear droop with that rear upright has a bridge under
do you usually remove rear upright And Measure it ? (Xray method :measure under the rear wishbone) or do you add certain amount on top of the reading ?
Thanx
yokemad is offline   Reply With Quote
Old 08-16-2010, 10:07 AM   #5312
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I hang the rear of the car off the setup board just enough that the arm is off when I check my droop.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 08-16-2010, 10:17 AM   #5313
stiltskin's Avatar
Trader Rating: 102 (100%+)
Originally Posted by yokemad View Post
Hi Guys
Thanx
I measure under the loop to make sure that both arms are equal. For most setups, I will measure uptravel above ride height and then verify adjustments under the loop.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 08-16-2010, 10:19 AM   #5314
yokemad's Avatar
so If I want to match to my xray setup Its ok to remove the rear hub and measure ...
Old 08-16-2010, 12:34 PM   #5315
pcar951's Avatar
Trader Rating: 19 (100%+)
I've found that on the Hudy blocks measuring with the Hudy droop guage, 1mm to the bottom of the loop gives you about 2mm actual up-travel. Rear droop is a bit of a PITA on the Photon but, once you're used to it, it's easy to work with.
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 08-16-2010, 12:59 PM   #5316
hana166's Avatar
There is a little flat on the outside edge of the wishbone, allows me to use the normal droop gauges that most people are already used to. Nice and easy
hana166 is offline   Reply With Quote
Old 08-16-2010, 05:32 PM   #5317
RCFREAK's Avatar
Trader Rating: 17 (100%+)
Hey guys.. anyone selling a Stock LIPO chassis thats clean? (this is the one that comes with the new kit) lmk...
thanks!!
Arv.
RC AMERICA// EA MOTORSPORTS// KO PROPO// ORCA
RCFREAK is offline   Reply With Quote
Old 08-16-2010, 05:59 PM   #5318
Trader Rating: 25 (100%+)
Arvin you have a pm
matt rem is offline   Reply With Quote
Old 08-16-2010, 09:22 PM   #5319
Jerry P's Avatar
Trader Rating: 44 (100%+)
Originally Posted by BlackedOutREVO View Post
Not to hijack your guys thread but I have a ton of photon stuff. Stock and cefx. Two full cars one stock and one is the evo and parts that I haven't posted up yet. Pm me if interested
You have a pm.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 08-16-2010, 11:57 PM   #5320
E.J. Evans's Avatar
Send a message via Yahoo to E.J. Evans
Hi Guys
Thanx
I go off the connector piece that hangs down. I run anywhere between .5 to 1.5.
T.O.P. Racing | APEX Hobbies | R1 | Solaris | NorCal Hobbies |
Solaris Racing Products (SRP) Solaris Spec Tires!
www.solarisrp.com | www.apexhobbies.com | www.topracingusa.com
E.J. Evans is offline   Reply With Quote
Old 08-17-2010, 04:19 AM   #5321
Luppi Stefano's Avatar
I have problem With Rear Toe-in
i have 1mm RF an 3mm RR
but
on Setup Gauge Station
SX is 2 DX 3.2
Car is New, NO Yoke no Crash
Help me
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 08-17-2010, 05:57 AM   #5322
Super Moderator
Marcos.J's Avatar
Trader Rating: 178 (100%+)
but
SX is 2 DX 3.2
Help me
i had the same issue, measured the shims, some have slightly different measurements,some shims vary , i had some that were 1.0mm and some where 1.1mm
Old 08-17-2010, 06:07 AM   #5323
yokemad's Avatar
you know those two Red O Rings comes with Gear Diff we use them as a spacer on both side before installing the ballbearings is that right?
Cheers
Old 08-17-2010, 06:09 AM   #5324
hana166's Avatar
Cheers
Yes you racing it tonight?
Old 08-17-2010, 06:31 AM   #5325
yokemad's Avatar
Yups
Looking for some setup ideas now
do you use top bladders or Tamiya ones? or should I go for Tamiya shocks
