T.O.P. Racing "Photon" 1/10 EP Touring Car
#511
I dont disagree it's a fine line. You never want to be at the track without a spare but at the same time you dont want to overspend on spares. I usually draw the line at suspension parts to start and any small/unique screws or shims that could be easily lost when working on a car. Then I see what happens. If something does break or wear out then I will usually buy 2 of those just to be safe.
#512
The kit will come with clamping wheel hubs (hexes) like Josh stated.
Spare parts I would recommend are the same as I would for any touring car:
TC-PMES01 F & R Suspension Arm ( each 1pc )
TC-PMFS01 Castor Block - 4
TC-PMGS01 Steering Block & Rear Hub Carrier ( each 1pc )
TC-PMK104 Spool Outdrive ( 4pcs)
Optional Parts I would recommend are:
TC-PSB014 1.4mm Stabilizer Bar ( 2pcs )
TC-PSB016 1.6mm Stabilizer Bar ( 2pcs )
Here is a list of springs we make for rubber. 306 and 344 come standard with the kit.
PS-TR15550 Shock Spring (14 x 1.5 x 5.50) 393gf/mm , 22.0lb/in
PS-TR15575 Shock Spring (14 x 1.5 x 5.75) 367gf/mm , 20.5lb/in
PS-TR15600 Shock Spring (14 x 1.5 x 6.00) 344gf/mm , 19.2lb/in
PS-TR15625 Shock Spring (14 x 1.5 x 6.25) 324gf/mm , 18.1lb/in
PS-TR15650 Shock Spring (14 x 1.5 x 6.50) 306gf/mm , 17.1lb/in
PS-TR15675 Shock Spring (14 x 1.5 x 6.75) 289gf/mm , 16.2lb/in
#513
the spool outrive is alum,platic?
#515
ok artwork
thank
olivier
thank
olivier
#518
TC-PMES01 F & R Suspension Arm ( each 1pc ) $ 8.49
TC-PMFS01 Castor Block - 4 $6.99
TC-PMGS01 Steering Block & Rear Hub Carrier ( each 1pc ) $6.99
TC-PMK104 Spool Outdrive ( 4pcs) $6.99
TC-PSB014 1.4mm Stabilizer Bar ( 2pcs ) $4.99
TC-PSB016 1.6mm Stabilizer Bar ( 2pcs ) $4.99
PS-TR15550 Shock Spring (14 x 1.5 x 5.50) 393gf/mm , 22.0lb/in $4.99
PS-TR15575 Shock Spring (14 x 1.5 x 5.75) 367gf/mm , 20.5lb/in $4.99
PS-TR15600 Shock Spring (14 x 1.5 x 6.00) 344gf/mm , 19.2lb/in $4.99
PS-TR15625 Shock Spring (14 x 1.5 x 6.25) 324gf/mm , 18.1lb/in $4.99
PS-TR15650 Shock Spring (14 x 1.5 x 6.50) 306gf/mm , 17.1lb/in $4.99
PS-TR15675 Shock Spring (14 x 1.5 x 6.75) 289gf/mm , 16.2lb/in $4.99
#519
#520
HI E.J.EVANS
YOU HAVE A SETUP SHEET for 13.5/lipo and rubber(sorex 36r) please?
BEST REGARDS
OLIVIER
BEST REGARDS
OLIVIER
#522
Am I correct in assuming the listed spare suspension parts etc. are for the rubber chassis and the springs are packaged per pair? When I spoke with Michael, he said something about making up a spare parts and option part package. Are you still contemplating that?
#523
#524
someone wants their car to be all matchy matchy. I have considered this as well, my LRP gear looks great in the Tamiya but it's going to clash horribly with the TOP. I've also thought about getting all the parts stripped and anodized blue, but there seems to be A LOT of them
#525
HI E.J.EVANS
BEST REGARDS
OLIVIER
BEST REGARDS
OLIVIER
RUBBER:
FOAM:
PS-TF17625 Shock Spring (13 x 1.7 x 6.25) 626gf/mm , 35.0lb/in
PS-TF17650 Shock Spring (13 x 1.7 x 6.50) 591gf/mm , 33.1lb/in
PS-TF17675 Shock Spring (13 x 1.7 x 6.75) 560gf/mm , 31.3lb/in
PS-TF17700 Shock Spring (13 x 1.7 x 7.00) 532gf/mm , 29.8lb/in
PS-TF17725 Shock Spring (13 x 1.7 x 7.25) 507gf/mm , 28.3lb/in
PS-TF14575 Shock Spring (13 x 1.4 x 5.75) 347gf/mm , 19.4lb/in
PS-TF14600 Shock Spring (13 x 1.4 x 6.00) 325gf/mm , 18.2lb/in
PS-TF14625 Shock Spring (13 x 1.4 x 6.25) 306gf/mm , 17.1lb/in
PS-TF14650 Shock Spring (13 x 1.4 x 6.50) 294gf/mm , 16.2lb/in
PS-TF14675 Shock Spring (13 x 1.4 x 6.75) 274gf/mm , 15.3lb/in
I know someone will ask about crossing over springs from Rubber to Foam or vice versa...Josh will have to answer that. LOL
Does T.O.P. USA plan to offer online shopping anytme soon?
