Old 08-09-2010, 06:00 PM   #5221
Mark506's Avatar
Trader Rating: 41 (100%+)
Originally Posted by pcar951 View Post
Thought Martin Crisp was running Tamiya? Wow, things change.
+1, and racing stock? Thought he was a Mod one..
Mark Ament
l MOMO USA l OZ Racing l Willwood Brakes | Dunlop Tires |
The Raceway at Beaver: Forever In Blue Jeans
Mark506 is offline   Reply With Quote
Old 08-09-2010, 06:11 PM   #5222
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Its not stock anymore, Its Expert. And I would consider Martin an expert.
I don't blame him for running 2 classes after travelling 1500 miles.
I imagine a lot more sponsored guys will be running 17.5 expert at races from now on since 13.5 was thrown out the window.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 08-09-2010, 06:24 PM   #5223
Martin Crisp's Avatar
Default photon
Well, it was a great learning experience for my new ride. I love the adjustability of the photon! I think I needed just a little more time to get the steering I wanted, but it was getting close in my very last run of the mod and 17.5 expert a mains. I think I had too much droop as the car was too lazy in transitions in a couple of critical corners, but the balance was good.
Yeah I really was hoping there would have been a 13.5 class as the 17.5 is a little slow for my liking, but I figured I needed as much experience with the car as possible.
Martin Crisp is offline   Reply With Quote
Old 08-09-2010, 07:37 PM   #5224
pcar951's Avatar
Trader Rating: 19 (100%+)
Martin, how about posting your setup?
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 08-09-2010, 08:03 PM   #5225
OVA
OVA's Avatar
Trader Rating: 75 (100%+)
Good run ...martin....
OVA is offline   Reply With Quote
Old 08-09-2010, 08:32 PM   #5226
Martin - Any chance of an updated setup book? With quite a few new adjustments in cars nowadays, as well as the lighter weight and more powerful motors. It would be good to see your excellent setup book updated, i know myself and plenty of others would buy a new copy
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 08-10-2010, 06:55 AM   #5227
RC MARKET's Avatar
μ.PRO
LIGHT WT. GEAR DIFF. MAINTANANCE KIT (PRO STOCK ED.)
T.O.P. Racing "Photon" 1/10 EP Touring Car-mp-tp-0002.jpg
RC MARKET is offline   Reply With Quote
Old 08-11-2010, 05:18 AM   #5228
Luppi Stefano's Avatar
EJ Evans, what happend?
setup problems?
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 08-11-2010, 05:21 AM   #5229
Originally Posted by paraletic View Post
I also seen the manual never mentioned putting thread lock on the cv grub screws, but I put some on jus from past experience of cars
Just put some thread lock on the cv grub screws, but it caused the cv to stop working properly... its all bound up and is stopping the steering action in the front of the car...
anyone got any ideas on how to remove the thread lock?? haha...
anthony_ling is offline   Reply With Quote
Old 08-11-2010, 06:02 AM   #5230
paraletic's Avatar
You put to much on
you only need the smallest amount ie: a very thin smear, not a blob
get some motor spray and spray it in the cv, pull it apart then allow it to soak in a small container with some motor spray for a bit
then clean it with a clean cloth
assemble with smallest amount
once is assembled get a clean rag an wipe any residue off from the cv an ya set to go
Losi XXX-S G+..................Tamiya M03.......................TOP Photon
Losi XXX-4 G+.................HoBao ST Pro electric........Losi Micro SCT
Losi XXX-CR....................Losi Mini Baja.....................Losi XX-4 W/E
ASSociated RC12L4
T.O.P PHOTON EX & Tamiya M05 - currently undergoing rigorous crash testing!
paraletic is offline   Reply With Quote
Old 08-11-2010, 11:54 AM   #5231
I don't have my car in front of me so this will be by memory, but here it goes
Tires: Solaris
Front:
Camber -2
Springs: 324
Shock oil: 70 assoc
Shock position on arm: middle
Shock position on shock tower: 3 from outside
roll center settings:
- arms : Medium low
- upper links: inside shims 2mm, no outside shims
Upper link was located in inner most hole on camber plate
toe out: 0.5 deg
droop: 1.5mm (measured by the difference between the car at rest and when the car is lifted up to the point when the tires are just about to come off the setup board.)
ackerman:
- front hole in steering knuckle
- all the way forward on center steering assembly.
Spacers on hing pins : 2mm forward
Track width spacers: 0.5mm all the way around
Back:
Camber -2
Springs: 306
Shock oil: 55 assoc
Shock position on shock tower: 1 from inside
- arms : Medium high
- upper links: inside shims 3mm, 2mm outside shims
Track width spacers: 2mm on front, 3.5 on rear
toe in: 1.875 deg ((3.5 - 2)/0,8)
droop: 2.5 mm (measured by the difference between the car at rest and when the car is lifted up to the point when the tires are just about to come off the setup board.)
Spacers on hing pins : 2mm backward
The I did not try this setup until the last round of the triple A main, and it finally gave me a good amount of steering, but the car rolled too much, and I lost time in transitions. The steering was mainly achieved by going from 2mm to 3mm of spacers on the rear inside upper link, but with the droop settings so high, the car rolled too much and wanted to keep turning the corner on exit. If I had one more run, I would have gone to between 0.5mm and 1mm front droop and 1.5 mm rear droop.
Also I don't like the fact that I reduced the rear toe so much to get the steering, as this hurt my ability to get on the power in mod on exit of the corner, and also contributed to the car wanting to keep turning as it finished the corner, so I still need to figure out a combination that allows me to run at least 2.5 if not 3 degrees of rear toe. More time and I will figure it out
Old 08-11-2010, 03:29 PM   #5232
Yeah thanks for that, I went for the blob to start with!
I've got them soaking in WD40 at the moment..
Won't do that again..
What else should I thread lock on the photon?
done so far:
Middle Pulley mount,
Sway bar set screws..
CV set screws
how about the spool?
You put to much on
Old 08-11-2010, 04:18 PM   #5233
hana166's Avatar
Tires: Solaris
Front:
Camber -2
Springs: 324
Shock oil: 70 assoc
- arms : Medium low
toe out: 0.5 deg
ackerman:
Back:
Camber -2
Springs: 306
Shock oil: 55 assoc
Hi I'm really interested in how the top drivers work out the oil weights to use
Is there some generally accepted wisdom on selecting oil weight for a particular track layout or track surface
Or is it a matter of getting the weight transfer ideal for your approach to driving the circuit (driving style)
hana166 is offline   Reply With Quote
Old 08-11-2010, 04:21 PM   #5234
paraletic's Avatar
I never did the spool on mine (but I also havnt had a big run with it so hopefully it won't come loose- I used the tapered screws)
I put a small amount of thread lock on the bell crank screw (the one used to adjust the length etc from position a,b&c)
I also glued the nut into the bell crank for easier adjustment
and the front bumper nuts I glued them into the bumper aswell
did you put longer screws in the suspension mounts?
I didn't like that the screws only went into the bulkheads a couple of mm
the bulkheads are threaded all way threw so I put longer screws in for a bit of added security
also put longer screws into the front body posts, the kit ones seemed way to short for my liking
ASSociated RC12L4
Old 08-11-2010, 07:15 PM   #5235
pcar951's Avatar
Thanks for the setup Martin!
Is any one running the plastic drive cups on the spool? Mine seemed to "notch" very quickly.
Jim Chapman
