Old 08-04-2010, 10:14 AM   #5146
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I dont know if the R9-F fits with rubber tires I have not tried, I was talking about with Foam tires the F is good.
I would HIGHLY Suggest everyone stick to the Speed 6 or the LTC-R for your rubber tire needs.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 08-04-2010, 11:41 AM   #5147
Bishop's Avatar
Originally Posted by L.Fairtrace View Post
I dont know how you are going to feel about that body. I have almost heard of noone that likes the way the R9-R feels. The R9-F on rubber tires was freaking awesome but the R lacks rear bite.
Go with the LTC-R or the Speed 6 if you can. You will be able to dial yourself in much quicker with either of those bodies. The ltc-r is my favorite and has been for the past year and a half.
I bought the R9 because I wanted a matching shell for the R5 I also got for my Mugen, it's not a strong club level race scene so I doubt it will be an issue yet, if the racing with it gets serious I'll get a LTC, I need the practice painting and cutting anyway.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 08-04-2010, 02:34 PM   #5148
pcar951's Avatar
Trader Rating: 19 (100%+)
I found the R9R worked well on carpet if you're looking for extra steering. The problem is obviously too much front down force at higher speeds, but it was great for 17.5. Worked best with the body mounted as far back as possible and the wing pushed back as well. IMO
Still....the best overall body is the LTC-R, as Larry said.
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 08-04-2010, 08:38 PM   #5149
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Mine feels great now that I've mounted it up higher, on the wall, in the pits.
If only endurance racing was a thing.
Greg Sharpe is offline   Reply With Quote
Old 08-04-2010, 09:28 PM   #5150
Aja Archibald's Avatar
I agree with Larry, I ran the R9 R at nats and it was horrible.
Went to LTC R and was a half second faster. Wow what a different.
Team Schumacher USA www.racing-cars.com// Team Sweep Racing Tires USA www.sweepracingusa.com// Hobbywing UK // Atomic USA www.rcatomic.com // SkyRocket Racing www.skyrocketracing.com // UPGRADE RC Products www.upgrade-Rc.com // Champion Hobby // Maj's Hobby // Crispy Critters // AbsoluteHobbyz.com // LAB Motors // Clockwork Racing Engines
Aja Archibald is offline   Reply With Quote
Old 08-04-2010, 10:45 PM   #5151
pakk's Avatar
Trader Rating: 79 (100%+)
I have to keep re tightening the out drives on my spool. Anyone got a fix for this?
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 08-04-2010, 11:00 PM   #5152
toby333's Avatar
Try longer screws, as long as they don't meet in the middle of the spool. From memory I think you have to use counter sunk ones.
toby333 is offline   Reply With Quote
Old 08-05-2010, 12:18 AM   #5153
paraletic's Avatar
Default Typo or wrong bits??
Ok so I'm assembling my new kit, so far been a pretty easy build
until step 22 of the book
it states a 1.5mm collar front and rear of the arm
in my kit I hav (2) 1.5mm and (2) 2mm collar left
not 4- 1.5mm collars
in the pictures it shows two different thickness colars being used, thin at the front and thicker behind
so is it just a typo in the list?
I've already found a few differences in what I've been supplied to what's listed
Losi XXX-S G+..................Tamiya M03.......................TOP Photon
Losi XXX-4 G+.................HoBao ST Pro electric........Losi Micro SCT
Losi XXX-CR....................Losi Mini Baja.....................Losi XX-4 W/E
ASSociated RC12L4
T.O.P PHOTON EX & Tamiya M05 - currently undergoing rigorous crash testing!
paraletic is offline   Reply With Quote
Old 08-05-2010, 01:54 AM   #5154
*SBH*'s Avatar
Hi Paraletic
You have to use 2mm in one end and 1,5mm on the other end. (Or if You like, use several thin washers, but total must be 3,5mm)
*SBH* is offline   Reply With Quote
Old 08-05-2010, 02:39 AM   #5155
xray racer's Avatar
Trader Rating: 22 (100%+)
Use a self-tapping screw or bolt if possible, and i always put a drop of CA on the end of the threads for good measure.
Originally the problem was the screws were bottoming out on each other, and not holding the outdrives in place properly, so check that this is not the case still.
Cheers
Robbie
Robbie Lloyd
Yokomo * HobbyWing * Sanwa
xray racer is offline   Reply With Quote
Old 08-05-2010, 02:45 AM   #5156
dontfeelcold's Avatar
Trader Rating: 20 (100%+)
Stick your head into your radio bag, the fix for everything is in there
dontfeelcold is offline   Reply With Quote
Old 08-05-2010, 04:40 AM   #5157
xray racer's Avatar
Haha... so i've been told! ... you wait til nationals, i'll be wearing one!
Robbie Lloyd
Old 08-05-2010, 07:14 AM   #5158
pakk's Avatar
Cheers
Robbie
That is exactly what it feels like is happening. The screws are bottoming out on each other in there. And it is just tight enough initially to keep everything nice and snug, but it backs out after a few packs. I'll look for a little shorter screw.
*Photon* *SC10 4x4*
RCRD
Old 08-05-2010, 07:27 AM   #5159
RaceAce701's Avatar
Trader Rating: 83 (99%+)
yep iv also found that that to be the best solution
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 08-05-2010, 07:31 AM   #5160
sosidge's Avatar
Have you replaced the spool moulding? Each time you tighten and re-tighten the screws the grip on them is going to get looser.
SEO by vBSEO 3.5.0
