Old 08-03-2010, 04:46 PM   #5131
Originally Posted by Luppi Stefano View Post
is LTD rubber version, Right?
careful not to tighten too much ball cup shocks.
Yes! Thanks for the tips...i'm building the Shocks tonight! I've got some Losi 40WT oil from my Nitro days... will this be ok for a asphalt outdoor track (with the 1mm 3 hole pistons ) ?
anthony_ling is offline   Reply With Quote
Old 08-03-2010, 05:36 PM   #5132
paraletic's Avatar
The reason i want to know about lowering the internal ratio is the rumours of possibly a stock class without timing an turbo etc
then I'd prob need to run a higher fdr
what fdr's are you achieving from this car?
ATM I'm running a hobbywing with boost-turbo etc so shouldn't be an issue buy if I run a spec stock class in future would be good to know I can achieve the higher fdr's
thanks
Losi XXX-S G+..................Tamiya M03.......................TOP Photon
Losi XXX-4 G+.................HoBao ST Pro electric........Losi Micro SCT
Losi XXX-CR....................Losi Mini Baja.....................Losi XX-4 W/E
ASSociated RC12L4
T.O.P PHOTON EX & Tamiya M05 - currently undergoing rigorous crash testing!
paraletic is offline   Reply With Quote
Old 08-03-2010, 05:47 PM   #5133
Luppi Stefano's Avatar
Use Losi 40WT too!
I used a 1,2mm 3 holes piston
new shocks are fantastic!
I run 25% rebound, for use zero Rebound, with 1mm hole on caps.
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 08-03-2010, 05:47 PM   #5134
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
PRS Makes spurs as low as like 72 that will fit on this car along with pinions up to 62 or maybe even higher. Getting the right gear ratio wont be an issue with the 2.0 internal
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 08-03-2010, 05:55 PM   #5135
thanks
why is a problem?
use a little spur gear...
with 100 spur and 40T pinion --- 5 FDR
with 88 spur and 40t pinion --- 4,4 FDR
88 spur 45 pinion --- 3,9 FDR
Lab F1-01
Old 08-03-2010, 06:13 PM   #5136
paraletic's Avatar
Ok thanks
your talking 64pitch are you?
I've only ever ran 48pitch so that's all the pinions etc I have (will Robinson pinions fit ok on this car?)
is a fdr of 3.2:1 or 3.5:1 achievable?
That's what I used run with my lrp sphere
ASSociated RC12L4
Old 08-03-2010, 09:24 PM   #5137
toby333's Avatar
Ok thanks
I was running FDR 3.7 48pitch (37t pinion/70t spur) with my novak gtb/17.5 not that long ago. The lowest ratio my gear chart shows is 3.2 (40t/64t). And the robinson pinions are fine. I've got one in my photon at the moment.
toby333 is offline   Reply With Quote
Old 08-04-2010, 05:38 AM   #5138
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
ROche heavyduty axle for Photon
Give the best while u can !
kschu is offline   Reply With Quote
Old 08-04-2010, 06:15 AM   #5139
I have no idea what dogbone would fit on that. And what is the purpose for a "heavy duty" axle. I have been running this car for over a year now and have hit stuff HARD and never damaged an axle in any way shape or form.
Old 08-04-2010, 06:45 AM   #5140
FLATMAN's Avatar
FLATMAN is offline   Reply With Quote
Old 08-04-2010, 06:58 AM   #5141
Jerry P's Avatar
Trader Rating: 44 (100%+)
Anyone know where i could pick up a kit or 2. I'm going to IIC and would like a Second car and a third too. I'm just being impatient because I'm on the wAiting list for 2 with top USA.
Regards
Jerry
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 08-04-2010, 08:22 AM   #5142
It looks similar to the xray optional ones that came out for the 008/9
CPD Racing
chris_dono is offline   Reply With Quote
Old 08-04-2010, 08:36 AM   #5143
Bishop's Avatar
Come Friday night mine hits the local track, although some zoom and less 'hit' would be nice, and it won't be all that fast just yet, I think I'm in the wrong FDR range and don't have the program box yet, but the 60A HW and 10.5 SP should give it some go, urged on by a 5000/50C pack...
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 08-04-2010, 08:41 AM   #5144
I dont know how you are going to feel about that body. I have almost heard of noone that likes the way the R9-R feels. The R9-F on rubber tires was freaking awesome but the R lacks rear bite.
Go with the LTC-R or the Speed 6 if you can. You will be able to dial yourself in much quicker with either of those bodies. The ltc-r is my favorite and has been for the past year and a half.
Old 08-04-2010, 09:04 AM   #5145
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
Good to know the R9-F fits on with rubber tires. I never would have thought of that. Steering with the R9-R is great but it is real hard to get the rear to hang on. Are there any trick to make the F fit with rubber tires? I though it would scrub, especially at the front.
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
