Old 08-02-2010, 09:08 PM   #5116
BoneCrusher's Avatar
Thanks for all the advice especially regarding spares and how to build shocks properly!
Just wondering what some of the regular Photon drivers use for Bodies for rubber carpet racing? ... Speed 6 / LTC-R / R9-R ?
If anyone is still using a ball diff, do you use the associated black grease in the thrust bearing or if Mr. Fairtrance wants to write another essay on this topic that would be fine too.
And going to 2 previous questions: Can you compensate with shock oils to make up for lack of harder springs? And if using Aluminum steering arms b/c the holes are different than the stock plastic ones can you compensate by changing the length of the bell crank?
All answers are much appreciated.
Ivan
ARC R10, 12R5.1, Tamiya Mini, MTS FFv2 Pro, Exotek F1
carcar.ca
BoneCrusher is offline   Reply With Quote
Old 08-03-2010, 12:46 AM   #5117
Ivan
For carpet racing it's mostly a speed 6 or if you like the feel of it, an ltc-r. I've not tried the R9-R though
As for the diff, yes black grease on the thrust, normal grease on the plates/balls
CPD Racing
chris_dono is offline   Reply With Quote
Old 08-03-2010, 01:31 AM   #5118
sosidge's Avatar
No, damping and springing are different things. A softly sprung yet heavily damped car will feel lazy, whereas a stiffly sprung lightly damped car will feel edgy.
No, you won't get a perfect compensation. Personally speaking I believe you will be able to get a completely satisfactory ackerman effect using either steering block, there is a lot of fine adjustment in the crank. If you need more aggressive steering, simply make the crank longer, or use a narrower insert.
Old 08-03-2010, 01:34 AM   #5119
RC MARKET's Avatar
Originally Posted by PDX-Spike View Post
Note that the 10K to 50K oil suggestion from RC Market is cSt, not SAE.
Yes is Xceed CST !
RC MARKET is offline   Reply With Quote
Old 08-03-2010, 02:48 AM   #5120
paraletic's Avatar
I've jus ordered myself a new photon so I'm tryin to get some info etc on it
I can't seem to find what the internal ratio is of this car, I checked on gear chart.com but it's not listed, only the scythe (are they the same ratio?)
will kimbrough spur gears fit the spur mount?
Are the steel dogbones up front a necesity?
I've ordered the T.O.P mid size servo saver
are there any other "must get" items
I'll be running this in 17.5 rubber asphault
cheers
Losi XXX-S G+..................Tamiya M03.......................TOP Photon
Losi XXX-4 G+.................HoBao ST Pro electric........Losi Micro SCT
Losi XXX-CR....................Losi Mini Baja.....................Losi XX-4 W/E
ASSociated RC12L4
T.O.P PHOTON EX & Tamiya M05 - currently undergoing rigorous crash testing!
paraletic is offline   Reply With Quote
Old 08-03-2010, 03:06 AM   #5121
defcone's Avatar
Trader Rating: 15 (100%+)
Originally Posted by stiltskin View Post
Did you take the internal gears apart? Make sure the shims are seated properly on the outdrive shaft.
When I took it apart, there were shims underneather the two gears which the outdrive shaft goes on and a bearing which slides on from the outside. If you're talking about the shims underneath the gear, then yes I have made sure it sits perfectly.
defcone is offline   Reply With Quote
Old 08-03-2010, 03:13 AM   #5122
sosidge's Avatar
2.0:1
I think Kimbrough's have the wrong hole count (6). The Photon has a four-peg spur adaptor. I use Kawada gears. Xenon and other Japanese gears should suit.
Unfortunately, you either need to modify the spur gear (ream out the holes) or the adaptor (trim the pegs) to get them to fit.
Unless you are a flawless driver who never, ever clips anything and never, ever gets clipped by anyone else - I would say yes!
cheers
The TOP saver is a repackaged Kimbrough and is a good choice. No other parts are necessary on the car and the only area that needs a little attention is the shock build as detailed a few posts above. So, get a set of fine 3mm shims, and you might like to get a small selection of alternative springs and 3mm spacers for tuning.
Old 08-03-2010, 03:39 AM   #5123
paraletic's Avatar
Cheers
are there optional sized diff pullies or such to lower the internal ratio?
ASSociated RC12L4
Old 08-03-2010, 04:52 AM   #5124
Trader Rating: 20 (100%+)
Default TOP Photon
I too have just picked up this chassis to run this summer. Its a new to me kit and was setup by the old owner to run 17.5 carpet with 2 runs on it. I plan on running 13.5 tarmac. Can someone direct me to a set up using stock kit parts only.
I plan on stocking up on some parts today and I looking for advice on what spares to buy and tunning options. I am not a great driver so look like steel bones should be at the TOP of my list. I do plan on running carpet in the fall. So a recommend spring selection would help.
TLR 22
Desc410r
zleader_99 is offline   Reply With Quote
Old 08-03-2010, 06:02 AM   #5125
sosidge's Avatar
Cheers
Not that I know of - why would you want to change it?
Old 08-03-2010, 06:05 AM   #5126
sosidge's Avatar
Kit setup in the back of the manual will be a good starting point and will use all the kit parts!
For springs, it depends on how high the grip is. Here in the UK we tend to have lower grip than in the US so only the grade between the kit springs really gets used. From reading US setups, the front end seems to get set a lot harder for the higher grip, but for our tracks, the car doesn't steer if set up that hard!
Old 08-03-2010, 06:07 AM   #5127
RC MARKET's Avatar
Cheers
Later !
U interest use which gear ratio ?
Old 08-03-2010, 06:10 AM   #5128
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I use kimbrough gears 99 percent of the time with no problem. All you have to do is ream out the 4 holes that the spur gear holder goes into and you are all set. It takes about 30 seconds to do this.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 08-03-2010, 03:18 PM   #5129
Default love the photon
I'm currently building the photon and enjoying it, until I got to the roll bar links... I had taken note of the many build tips/blogs around on the build and pre-threaded the plastic link with a 3x10m hex screw several times before attempting to screw in the hollow alu roll bar link.. I got it 99% in and was wanting to get the link flush/square and broke it... these things are made of butter.
The (rubber) kit came with steel outdrives for the spool, should I use these?
Does the steel outdrive use a different screw (into the pulley)?
and... I'm a little confused with the universal shafts and the amendments to the manual..
Should I be using the 46mm in the front and the shorter in the rear + put the plastic C - on the dogbone for the rear... ?
There is a set of shims for the universal shafts.... (one only) should I use these on the shorter rear outdrives to remove the play between the hub and the hex wheel adapter?
anthony_ling is offline   Reply With Quote
Old 08-03-2010, 04:26 PM   #5130
Luppi Stefano's Avatar
I Broke too, Used a hotbodies parts, most strong than TOP parts...
Yes Use a Steel Outdrive
use silver flat head Screw in spool bag
yes, alu 46mm in front, alu 44.5 in rear with C-blade
in my kit not found a shim, but put 0,2 in rear and 0,1 in front
is LTD rubber version, Right?
careful not to tighten too much ball cup shocks.
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
